Poor precision on tutorial with different function
Hi, I tried to use the tutorial on Dirichlet, Neumann and Robin boundary conditions to solve a different pde but the precision is poor and I can’t understand why.
Thanks in advance for the help, it’s been two weeks since I started trying to solve this…
(If it can help, I think the problem is in the Robin bc because by substituting them with Dirichlet/Neumann it works)
The pde is the following:
immagine
For simplicity I used a non-homogeneous Robin bc but with the homogeneous condition the precision is still low.
My code (slight modification of the tutorial) is
import pyvista
from dolfinx.fem import (Constant,  Function, FunctionSpace, assemble_scalar,
                         dirichletbc, form, locate_dofs_topological)
from dolfinx.mesh import create_unit_square, locate_entities, meshtags
from ufl import (FacetNormal, Measure, SpatialCoordinate, TestFunction, TrialFunction,
                 div, dot, dx, grad, inner, lhs, rhs)
V = FunctionSpace(mesh, ("CG", 1))
    n_temp = 1.4
    reff= -1.44*n_temp**-2+0.71*n_temp**-1+0.668+0.0636*n_temp
    temp = (1+reff)/(1-reff)
    A = Constant(mesh, ScalarType(temp))
    u_ex = lambda x: x[0]**3*x[1]+x[0]**2*x[1]+2*x[1]**2+10*x[1]
    n = ufl.FacetNormal(mesh)
    g = -ufl.dot(ufl.grad(u_ex(x)),n)
    mu_s = Constant(mesh, ScalarType(1.22))
    D = Constant(mesh, ScalarType(1/(3*1.22)))
    mu_a = Constant(mesh, ScalarType(0.011))
    S = -ufl.div(D*ufl.grad(u_ex(x)))+mu_a*u_ex(x)
    F = D * ufl.inner(ufl.grad(u), ufl.grad(v)) * ufl.dx + mu_a * ufl.inner(u,v) * ufl.dx - ufl.inner(S, v) * ufl.dx r
boundaries = [(1, lambda x: np.isclose(x[0], 0)),
              (2, lambda x: np.isclose(x[0], 1)),
              (3, lambda x: np.isclose(x[1], 0)),
              (4, lambda x: np.isclose(x[1], 1))]
fdim = mesh.topology.dim - 1
    facets = locate_entities(mesh, fdim, locator)
    facet_indices.append(facets)
facet_indices = np.array(np.hstack(facet_indices), dtype=np.int32)
facet_markers = np.array(np.hstack(facet_markers), dtype=np.int32)
facet_tag = meshtags(mesh, fdim, facet_indices[sorted_facets], facet_markers[sorted_facets])
ds = Measure("ds", domain=mesh, subdomain_data=facet_tag)
class BoundaryCondition():
    def __init__(self, type, marker, values):
        self._type = type
        if type == "Dirichlet":
            u_D = Function(V)
            u_D.interpolate(values)
            facets = np.array(facet_tag.indices[facet_tag.values == marker])
            dofs = locate_dofs_topological(V, fdim, facets)
            self._bc = dirichletbc(u_D, dofs)
        elif type == "Neumann":
                self._bc = inner(values, v) * ds(marker)
        elif type == "Robin":
            self._bc = values[0] * inner(u-values[1], v)* ds(marker)
            raise TypeError("Unknown boundary condition: {0:s}".format(type))
    @property
    def bc(self):
        return self._bc
    @property
    def type(self):
        return self._type
rob = D*ufl.inner(ufl.grad(u_ex(x)),n)+u_ex(x)/(2*A)
boundary_conditions = [BoundaryCondition("Dirichlet", 1, u_ex),
                       BoundaryCondition("Dirichlet", 2, u_ex),
                       BoundaryCondition("Robin", 3, (1/(2*A*D), 2*A*rob)),
                       BoundaryCondition("Neumann", 4, g)]
bcs = []
for condition in boundary_conditions:
    if condition.type == "Dirichlet":
        bcs.append(condition.bc)
        F += condition.bc
# Solve linear variational problem
a = lhs(F)
L = rhs(F)
problem = LinearProblem(a, L, bcs=bcs, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = problem.solve()
# Compute L2 error and error at nodes
V_ex = FunctionSpace(mesh, ("CG", 2))
u_exact = Function(V_ex)
u_exact.interpolate(u_ex)
error_L2 = np.sqrt(mesh.comm.allreduce(assemble_scalar(form((uh - u_exact)**2 * dx)), op=MPI.SUM))
u_vertex_values = uh.x.array
uex_1 = Function(V)
uex_1.interpolate(u_ex)
u_ex_vertex_values = uex_1.x.array
error_max = np.max(np.abs(u_vertex_values - u_ex_vertex_values))
error_max = mesh.comm.allreduce(error_max, op=MPI.MAX)
print(f"Error_L2 : {error_L2:.2e}")
print(f"Error_max : {error_max:.2e}")
Your code appears to compute a discrete approximation to the manufactured solution
u_{exact}(x) = x^3 y + x^2 y + 2y^2 + 10y
However, this solution is not the solution to the problem stated in your question:
I have provided two codes below: one to solve the problem stated in your question, and one to solve the manufactured solution present in your code.
1. Solving the problem stated in the question
If you wish to solve this problem:
you will need to modify your boundary conditions to have homogeneous Dirichlet, Neumann, and Robin bcs:
boundary_conditions = [BoundaryCondition("Dirichlet", 1, lambda x: np.zeros(x[0].size)),
                       BoundaryCondition("Dirichlet", 2, lambda x: np.zeros(x[0].size)),
                       BoundaryCondition("Robin", 3, (1/(2*A), Constant(mesh, 0.0))),]
                       # BoundaryCondition("Neumann", 4, g)]
(By removing the Neumann bc, a homogeneous Neumann bc is implied.) A complete code to solve this problem follows.
import pyvista
V = FunctionSpace(mesh, ("CG", 3))
n_temp = 1.4
g = -ufl.dot(D*ufl.grad(u_ex(x)),n)
        self._type = type
            u_D = Function(V)
    @property
    def bc(self):
        return self._bc
    @property
    def type(self):
        return self._type
rob = 2*A*D*ufl.inner(ufl.grad(u_ex(x)),n) + u_ex(x)
                       #BoundaryCondition("Neumann", 4, g)]
bcs = []
        F += condition.bc
a = lhs(F)
L = rhs(F)
uh.name = 'uh'
V_ex = FunctionSpace(mesh, ("CG", 3))
u_exact.name = 'u_exact'
uex_1 = Function(V)
Of course, this means that error calculated at the end of the code is meaningless, since you are comparing the discrete solution of your problem to an unrelated manufactured solution:
Error_L2 : 7.45e+00
Error_max : 1.40e+01
2. Computing the manufactured solution
Your code appears to be structured to compute a discrete approximation to the manufactured solution
similarly to the tutorial but with an altered PDE and a different manufactured solution.
If this is your goal, there are three errors to correct in your code:
  1. The definition of g, which should be (you need to add a factor of D):
  2. The definition of rob, which should be:
  3. The definition of the Robin boundary condition, which should be:
                           BoundaryCondition("Robin", 3, (1/(2*A), rob)),
The complete code to replicate the manufactured solution is below:
#import pyvista
n_temp = 1.4
        self._type = type
            u_D = Function(V)
    @property
    def bc(self):
        return self._bc
    @property
    def type(self):
        return self._type
bcs = []
        F += condition.bc
a = lhs(F)
L = rhs(F)
uh.name = 'uh'
uex_1 = Function(V)
Producing:
Error_L2 : 8.65e-03
Error_max : 5.59e-03
Thank you really much! The solution is perfect and crystal clear!
