Hi guys! I used FEniCS to study the Hopf bifurcation in 2D cavity and the results came out well. I used MUMPS here, which is unaffordable for the next 3D studies. I could solve the operator split+IMEX with conjugate gradient correctly. However since I want to use residual based methods for variational multiscale later on, I need to solve the monolithic block of Navier Stokes. All my experiments with GMRES are failing.
Below is a typical failing 2D code. Basically I have exhausted the ‘shoot in the dark’ GPT ideas on preconditioners so I guess I need to study it in depth. I am quite weak at the theory of Krylov solvers, thus I am really sorry that I cannot explain these choices properly: if I should read any theory first, please suggest a good resource to start reading and I can get back with a much better response.
#!/usr/bin/env python3
# 2D Lid-driven cavity (unit square) | TH Pk/P{k-1} | Fully-implicit BDF2
import os, json
# ----------------------- User parameters ---------------------------------
nx, ny = 48, 48
k = 2
Re = 100.0
dt_value = 0.1
T_end = 20.0 # keep small while testing
n_frames = 50
out_dir = "ldc_bdf2_TH_SUPG_gmres_blockLU_xdmf"
lid_speed = 1.0
# SUPG toggle and coefficients
enable_supg = True
Ct_val = 4.0
Cnu_val = 4.0
# Solver controls
use_gmres = True # True: GMRES+FieldSplit, False: global MUMPS (direct)
use_block_lu = True # True: LU on A00 and LU on Schur (robust; slow)
newton_atol = 1e-8
newton_rtol = 1e-8
newton_maxi = 40
dt_first_step_scale= 1.0 # e.g. 0.5 for an easier first step
# PSD settings
do_psd = True
T_meas_start = 0.5*T_end
fmin, fmax = 0.0, 5.0
# Checkpoint / restart
use_checkpoint = True
checkpoint_int = 10
resume_from_ckpt = True
T_extend_after_restart = 0.0
combine_history_for_psd = True
# ----------------------- PETSc options (our own prefix) ------------------
from dolfin import PETScOptions
PETScOptions.clear()
prefix = "ns_" # private prefix bound to our KSP
if use_gmres:
prefix = "ns_"
# --- Outer Krylov ---
PETScOptions.set(prefix + "ksp_type", "fgmres")
PETScOptions.set(prefix + "ksp_rtol", "1e-8")
PETScOptions.set(prefix + "ksp_atol", "0.0")
PETScOptions.set(prefix + "ksp_max_it", "500")
PETScOptions.set(prefix + "ksp_converged_reason")
# keep default right-preconditioning (do NOT force left here)
# --- Monolithic FieldSplit(Schur) ---
PETScOptions.set(prefix + "pc_type", "fieldsplit")
PETScOptions.set(prefix + "pc_fieldsplit_detect_saddle_point")
PETScOptions.set(prefix + "pc_fieldsplit_type", "schur")
PETScOptions.set(prefix + "pc_fieldsplit_schur_factorization_type", "lower")
PETScOptions.set(prefix + "pc_fieldsplit_off_diag_use_amat", "1")
# IMPORTANT: precondition with A11 so the pressure PC factors A11, not S
PETScOptions.set(prefix + "pc_fieldsplit_schur_precondition", "a11")
# Use exact A^{-1} (since A00 is LU)
PETScOptions.set(prefix + "mat_schur_complement_ainv_type", "full")
# --- Velocity block A00: LU (MUMPS if available) ---
PETScOptions.set(prefix + "fieldsplit_0_ksp_type", "preonly")
PETScOptions.set(prefix + "fieldsplit_0_pc_type", "lu")
PETScOptions.set(prefix + "fieldsplit_0_pc_factor_mat_solver_type", "mumps")
# --- Pressure block preconditioner (A11): LU (MUMPS) ---
PETScOptions.set(prefix + "fieldsplit_1_ksp_type", "preonly")
PETScOptions.set(prefix + "fieldsplit_1_pc_type", "lu")
PETScOptions.set(prefix + "fieldsplit_1_pc_factor_mat_solver_type", "mumps")
# Diagnostics: you should see "KSP Object: (ns_)" and field splits
PETScOptions.set(prefix + "ksp_view")
PETScOptions.set(prefix + "pc_view")
# ----------------------- Setup & I/O -------------------------------------
assert k >= 2, "Use k >= 2 (Taylor–Hood)."
os.makedirs(out_dir, exist_ok=True)
ckpt_dir = os.path.join(out_dir, "checkpoints")
if use_checkpoint:
os.makedirs(ckpt_dir, exist_ok=True)
ckpt_h5 = os.path.join(ckpt_dir, "state.h5")
ckpt_meta = os.path.join(ckpt_dir, "state.json")
mesh = UnitSquareMesh(nx, ny)
# Light corner grading (optional)
corner_pts = [Point(0.0, 0.0), Point(1.0, 0.0), Point(1.0, 1.0), Point(0.0, 1.0)]
for r in (0.20, 0.10, 0.05):
markers = MeshFunction("bool", mesh, mesh.topology().dim(), False)
for cell in cells(mesh):
mp = cell.midpoint()
if min(mp.distance(P) for P in corner_pts) < r:
markers[cell] = True
mesh = refine(mesh, markers)
dim = mesh.topology().dim()
I = Identity(dim)
# Spaces
V_el = VectorElement("Lagrange", mesh.ufl_cell(), k)
Q_el = FiniteElement("Lagrange", mesh.ufl_cell(), k-1)
W = FunctionSpace(mesh, MixedElement([V_el, Q_el]))
V = FunctionSpace(mesh, V_el)
Q = FunctionSpace(mesh, Q_el)
Ssc = FunctionSpace(mesh, FiniteElement("Lagrange", mesh.ufl_cell(), k))
# Quadrature
quad_deg_form = max(3*k, 6)
dx_form = Measure("dx", domain=mesh, metadata={"quadrature_degree": quad_deg_form})
# Unknowns/tests
w = Function(W) # (u, p)
u, p = split(w)
v, q = TestFunctions(W)
# Physics / time
nu = Constant(1.0/Re)
dt = Constant(dt_value)
Ct = Constant(Ct_val)
Cnu = Constant(Cnu_val)
f = Constant((0.0, 0.0))
# BDF2 history
u_n = Function(V); u_n.vector().zero()
u_nm1 = Function(V); u_nm1.vector().zero()
# BCs
noslip = DirichletBC(W.sub(0), Constant((0.0, 0.0)),
"near(x[0],0.0) || near(x[0],1.0) || near(x[1],0.0)")
lid_bc = DirichletBC(W.sub(0), Constant((lid_speed, 0.0)), "near(x[1],1.0)")
p_pin = DirichletBC(W.sub(1), Constant(0.0),
"near(x[0],0.0) && near(x[1],0.0)", "pointwise")
bcs = [noslip, lid_bc, p_pin]
# Helpers
def conv(vec): # (u·∇)u
return grad(vec) * vec
# Time operators
du_bdf1 = (u - u_n)/dt
du_bdf2 = (3.0*u - 4.0*u_n + u_nm1)/(2.0*dt)
# Strong momentum residuals
r_m_bdf1 = du_bdf1 + conv(u) - nu*div(grad(u)) + grad(p) - f
r_m_bdf2 = du_bdf2 + conv(u) - nu*div(grad(u)) + grad(p) - f
# Galerkin part
F_bdf1 = ( inner(du_bdf1, v)*dx_form
+ inner(conv(u), v)*dx_form
+ nu*inner(grad(u), grad(v))*dx_form
- div(v)*p*dx_form
- q*div(u)*dx_form )
F_bdf2 = ( inner(du_bdf2, v)*dx_form
- div(v)*p*dx_form
# SUPG (momentum only)
if enable_supg:
h = CellDiameter(mesh)
G = (1.0/(h*h)) * I
GG = inner(G, G)
u_tau = u
tau_M = 1.0 / sqrt(Ct/dt**2 + inner(u_tau, G*u_tau) + (Cnu*nu)**2 * GG)
supg_test = grad(v) * u
F_bdf1 += inner(tau_M*supg_test, r_m_bdf1) * dx_form
F_bdf2 += inner(tau_M*supg_test, r_m_bdf2) * dx_form
# Jacobians
dw = TrialFunction(W)
J_bdf1 = derivative(F_bdf1, w, dw)
J_bdf2 = derivative(F_bdf2, w, dw)
# Writers
from dolfin import XDMFFile, MPI
comm = MPI.comm_world
xdmf_path = os.path.join(out_dir, "ldc_series.xdmf")
xdmf = XDMFFile(comm, xdmf_path)
xdmf.parameters["flush_output"] = True
xdmf.parameters["functions_share_mesh"] = True
xdmf.parameters["rewrite_function_mesh"] = False
def save_fields(u_fun, p_fun, t):
u_fun.rename("u", "u"); p_fun.rename("p", "p")
xdmf.write(u_fun, t); xdmf.write(p_fun, t)
ux, uy = u_fun.split(deepcopy=True)
ux.rename("ux","ux"); xdmf.write(ux, t)
uy.rename("uy","uy"); xdmf.write(uy, t)
umag = project(sqrt(inner(u_fun, u_fun)), Ssc)
umag.rename("umag","umag"); xdmf.write(umag, t)
# Time plan / restart
n_steps_nominal = int(round(T_end/dt_value))
save_idx = np.linspace(0, n_steps_nominal, num=max(2, n_frames), dtype=int)
start_step = 0; t0 = 0.0
if resume_from_ckpt and use_checkpoint and os.path.exists(ckpt_h5) and os.path.exists(ckpt_meta):
if comm.rank == 0: print("Loading checkpoint:", ckpt_h5)
H = HDF5File(comm, ckpt_h5, "r")
H.read(u_n, "/u_n"); H.read(u_nm1, "/u_nm1"); H.close()
if comm.rank == 0:
with open(ckpt_meta, "r") as f: meta = json.load(f)
start_step = int(meta.get("step", 0)); t0 = float(meta.get("time", 0.0))
start_step = comm.bcast(start_step, root=0); t0 = comm.bcast(t0, root=0)
extend_steps = int(round(T_extend_after_restart/dt_value)) if T_extend_after_restart > 0.0 else 0
n_steps = max(n_steps_nominal, start_step + extend_steps)
if comm.rank == 0:
print(f"=== LDC TH P{k}/P{k-1} | SUPG={'on' if enable_supg else 'off'} ===")
print(f"Mesh {nx}x{ny} | Re={Re} | dt={dt_value} | total steps target={n_steps} | resume at step {start_step}")
print(f"Quadrature degree (form) = {quad_deg_form}")
if enable_supg: print(f"Tezduyar tau: Ct={Ct_val}, Cnu={Cnu_val}")
print(f"Output -> {xdmf_path}")
# ----------------------- Explicit Newton + our KSP -----------------------
from dolfin import PETScKrylovSolver, PETScLUSolver, assemble_system, assemble
def newton_solve(F_form, J_form, w, bcs, atol=1e-8, rtol=1e-8, maxi=40):
"""Solve F(w)=0 with assembled J and either GMRES+FieldSplit or global LU."""
def res_norm():
r = assemble(F_form)
for bc in bcs: bc.apply(r)
return r.norm("l2")
if use_gmres:
solver = PETScKrylovSolver()
solver.ksp().setOptionsPrefix(prefix)
solver.ksp().setFromOptions()
solver = PETScLUSolver("mumps")
solver.parameters["reuse_factorization"] = False
dw = Function(w.function_space())
r0 = res_norm()
if MPI.comm_world.rank == 0:
print(f" Newton iteration 0: r (abs) = {r0:.3e}")
for it in range(1, maxi+1):
A, b = assemble_system(J_form, -F_form, bcs)
solver.set_operator(A)
solver.solve(dw.vector(), b)
w.vector().axpy(1.0, dw.vector())
r = res_norm()
print(f" Newton iteration {it}: r (abs) = {r:.3e} | r/r0 = {r/r0:.3e}")
if r < atol or r/r0 < rtol:
break
# ----------------------- Time loop ---------------------------------------
t = t0
first_dt = float(dt_value) * dt_first_step_scale
for n in range(start_step+1, n_steps+1):
if n == 1 and start_step == 0 and dt_first_step_scale != 1.0:
dt.assign(first_dt)
dt.assign(dt_value)
t = n*float(dt_value)
if comm.rank == 0:
print("\n--- Step {}/{} t = {:.6f} ---".format(n, n_steps, t))
w.vector().zero()
assign(w.sub(0), u_n)
if n == 1 and start_step == 0:
newton_solve(F_bdf1, J_bdf1, w, bcs, atol=newton_atol, rtol=newton_rtol, maxi=newton_maxi)
newton_solve(F_bdf2, J_bdf2, w, bcs, atol=newton_atol, rtol=newton_rtol, maxi=newton_maxi)
u_new, p_new = w.split(deepcopy=True)
# totals
keTot = assemble(0.5*inner(u_new, u_new) * dx)
ensTot = assemble(0.5*curl(u_new)**2 * dx)
if comm.rank == 0:
time_series = globals().get("time_series", []); time_series.append(t)
keTot_series = globals().get("keTot_series", []); keTot_series.append(keTot)
ensTot_series = globals().get("ensTot_series", []); ensTot_series.append(ensTot)
globals()["time_series"], globals()["keTot_series"], globals()["ensTot_series"] = time_series, keTot_series, ensTot_series
if n in save_idx:
save_fields(u_new, p_new, t)
# checkpoint
if use_checkpoint and (n % checkpoint_int == 0 or n == n_steps):
if comm.rank == 0:
print(f"[checkpoint] step={n}, t={t:.6f}")
H = HDF5File(comm, ckpt_h5, "w")
H.write(u_new, "/u_n"); H.write(u_n, "/u_nm1"); H.close()
if comm.rank == 0:
with open(ckpt_meta, "w") as f:
json.dump({"step": n, "time": t, "dt": float(dt)}, f)
# shift BDF2 history
u_nm1.assign(u_n); u_n.assign(u_new)
xdmf.close()
# ----------------------- Post: plots, CSV, PSD ---------------------------
import matplotlib
matplotlib.use("Agg")
ts = np.array(time_series, float)
keT = np.array(keTot_series, float)
ensT = np.array(ensTot_series, float)
csv_tot = os.path.join(out_dir, "globals_totals_timeseries.csv")
if combine_history_for_psd and os.path.exists(csv_tot) and ts.size == 0:
try:
data_prev = np.loadtxt(csv_tot, delimiter=",", skiprows=1)
if data_prev.ndim == 1 and data_prev.size >= 3: data_prev = data_prev.reshape(1, -1)
if data_prev.shape[1] >= 3:
ts = data_prev[:,0]; keT = data_prev[:,1]; ensT = data_prev[:,2]
print(f"Loaded previous totals ({ts.size} samples) from {csv_tot}")
except Exception as e:
print(f"Warning: could not load previous totals CSV ({e}). Proceeding without.")
np.savetxt(csv_tot, np.column_stack([ts, keT, ensT]),
delimiter=",", header="t,KE_total,Enstrophy_total", comments="")
print(f"\nSaved totals time series: {csv_tot}")
plt.figure(figsize=(9,4.2), dpi=140)
plt.plot(ts, keT, lw=1.6)
plt.xlabel("t"); plt.ylabel("∫ 0.5 |u|^2 dx")
plt.title("Total kinetic energy vs time")
plt.grid(True, alpha=0.25); plt.tight_layout()
plt.savefig(os.path.join(out_dir, "ke_total_vs_time.png")); plt.close()
plt.plot(ts, ensT, lw=1.6)
plt.xlabel("t"); plt.ylabel("∫ 0.5 ω^2 dx")
plt.title("Total enstrophy vs time")
plt.savefig(os.path.join(out_dir, "enstrophy_total_vs_time.png")); plt.close()
if do_psd and len(ts) >= 64:
m = ts >= T_meas_start
if np.count_nonzero(m) < 64: m = np.arange(len(ts)) >= len(ts)//2
ts2 = ts[m]; ke2 = keT[m]
if len(ts2) >= 64:
dt_samp = np.median(np.diff(ts2))
y = ke2 - np.mean(ke2)
n = len(y); nseg = max(128, int(n//4)); step = nseg//2
win = np.hanning(nseg)
accP = None; freqs = None; nacc = 0
for start in range(0, n - nseg + 1, step):
seg = y[start:start+nseg]
Y = np.fft.rfft(seg * win)
f = np.fft.rfftfreq(nseg, d=dt_samp)
P = (np.abs(Y)**2) / np.sum(win**2)
accP = P if accP is None else accP + P
freqs = f; nacc += 1
P = accP / max(nacc,1)
band = (freqs >= fmin) & (freqs <= fmax)
f_plot = freqs[band]; P_plot = P[band]
if f_plot.size > 0 and f_plot[0] == 0.0: P_plot[0] = 0.0
if f_plot.size > 1:
kpk = int(np.argmax(P_plot)); fpk = float(f_plot[kpk])
print(f"PSD peak frequency f ~ {fpk:.6f} (Strouhal)")
np.savetxt(os.path.join(out_dir, "ke_total_psd.csv"),
np.column_stack([f_plot, P_plot]),
delimiter=",", header="f,PSD", comments="")
plt.figure(figsize=(8.5,4.2), dpi=140)
plt.plot(f_plot, P_plot, lw=1.8)
if f_plot.size > 1:
plt.axvline(f_plot[np.argmax(P_plot)], ls="--", lw=1.0)
plt.xlim(fmin, fmax)
plt.xlabel("frequency f (Strouhal)"); plt.ylabel("PSD [arb. units]")
plt.title("Welch PSD of total kinetic energy")
plt.savefig(os.path.join(out_dir, "ke_total_psd.png")); plt.close()
print("PSD: not enough samples after burn-in.")
print("PSD skipped or insufficient samples.")
print("\nAll done. Open in ParaView:", os.path.join(out_dir, "ldc_series.xdmf"))
