I’m creating a notched domain using pygmsh and, following Mesh generation and conversion with GMSH and PYGMSH | Jørgen S. Dokken, I am attempting to convert it to xdmf fo ruse in a fenics code. My code is as follows:
import pygmsh
res = 0.05
geometry = pygmsh.geo.Geometry()
model = geometry.__enter__()
L = 1;
w = 0.5
nl = 0.1
nh = 0.1
points = [model.add_point((-L/2, -w/2, 0), mesh_size=res),
model.add_point((L/2, -w/2, 0), mesh_size=res),
model.add_point((L/2, w/2, 0), mesh_size=res),
model.add_point((nl/2, w/2, 0), mesh_size=res),
model.add_point((0, w/2-nh, 0), mesh_size=res),
model.add_point((-nl/2, w/2, 0), mesh_size=res),
model.add_point((-L/2, w/2, 0), mesh_size=res)]
edges = [model.add_line(points[i], points[i+1])
for i in range(-1, len(points)-1)]
notched_bdry = model.add_curve_loop(edges)
interior = model.add_plane_surface(notched_bdry)
model.synchronize()
volume_marker = 6
model.add_physical([notched_bdry], "Interior")
model.add_physical([edges[0]], "Left")
model.add_physical([edges[2]], "Right")
model.add_physical([edges[1],edges[3],edges[4],edges[5],edges[6]], "Neutral")
geometry.generate_mesh(dim=2)
gmsh.write("mesh.msh")
gmsh.clear()
geometry.__exit__()
mesh_from_file = meshio.read("mesh.msh")
out_mesh = meshio.Mesh(points=points, cells={cell_type: cells}, cell_data={"name_to_read":[cell_data]})
return out_mesh
line_mesh = create_mesh(mesh_from_file, "line", prune_z=True)
meshio.write("facet_mesh.xdmf", line_mesh)
triangle_mesh = create_mesh(mesh_from_file, "triangle", prune_z=True)
and this produces the error:
ValueError Traceback (most recent call last)
Cell In [1], line 55
52 line_mesh = create_mesh(mesh_from_file, "line", prune_z=True)
53 meshio.write("facet_mesh.xdmf", line_mesh)
---> 55 triangle_mesh = create_mesh(mesh_from_file, "triangle", prune_z=True)
56 meshio.write("mesh.xdmf", triangle_mesh)
Cell In [1], line 47, in create_mesh(mesh, cell_type, prune_z)
45 def create_mesh(mesh, cell_type, prune_z=False):
46 cells = mesh.get_cells_type(cell_type)
---> 47 cell_data = mesh.get_cell_data("gmsh:physical", cell_type)
48 points = mesh.points[:,:2] if prune_z else mesh.points
49 out_mesh = meshio.Mesh(points=points, cells={cell_type: cells}, cell_data={"name_to_read":[cell_data]})
File ~/miniconda3/lib/python3.9/site-packages/meshio/_mesh.py:249, in Mesh.get_cell_data(self, name, cell_type)
248 def get_cell_data(self, name: str, cell_type: str):
--> 249 return np.concatenate(
250 [d for c, d in zip(self.cells, self.cell_data[name]) if c.type == cell_type]
251 )
File <__array_function__ internals>:180, in concatenate(*args, **kwargs)
ValueError: need at least one array to concatenate
