Hi, i’m currently having trouble running dolfinx complex mode in parallel.
Everything works has expected while running in serial with the solution converging to the analytical one, but when i switch to run with mpi problems start to occur. I either get a segmentation fault or the simulation runs endlessly without giving any error message, depending on the solver i choose. This exact behavior also occurs when i try to run the demo “Electromagnetic scattering from a wire with scattering boundary conditions”, where the simulation in parallel runs endlessly without giving any error message (i don’t change anything in the file). I don’t know exactly what is happening, if it’s a problem with my installation or some feature that is not yet implemented.
My second environment using dolfinx in real mode doesn’t have this problem and i can even solve the same problem using a mixed space formulation in parallel, although i would much rather use dolfinx in complex mode as it seems more efficient from the tests made in serial.
Any advice would be great, thanks.
