Problem with boundary condition. Error: "Unable to compile C++ code with dijitso"
I want to solve the Poisson for a new function defined as newDivision, but fenics cannot integrate this solution. How could I reformulate my problem?
def newDivision(y,x):
if abs(x)<10**(-8):
z = 40000
return z
    z= y/x
    return z
mesh = UnitSquareMesh(8, 8)
#mesh = UnitSquareMesh(i, i)
V = FunctionSpace(mesh, ‘Lagrange’, 1)
u_D = Expression(‘newDivision(x[1]/x[0])’, degree=4)
def boundary(x, on_boundary):
return on_boundary
Define variational problem
f = Expression(‘0’, degree=0)
a = dot(grad(u), grad(v))dx
L = f
v*dx
Compute solution
solve(a == L, u, bc)
Plot solution and mesh
plot(u)
plot(mesh)
Compute error in L2 norm
error= errornorm(u_D, u, ‘L2’)
Please properly format your code using 3x ` encapsulation, as explained in: Extended Syntax | Markdown Guide
to ensure proper formatting
I did some modifications in your code. The below works on my side:
class newDivision(UserExpression):
    def eval(self, value, x):
        if  x[0] <= 10 ** (-8):
            value[0] = 40000
            value[0] = x[1] / x[0]
    def value_shape(self):
        return ()
bcs = newDivision()
    return on_boundary
bc = DirichletBC(V, bcs, boundary)
f = Constant (0)
a = dot(grad(u), grad(v))*dx
L = f*v * dx
File( "Results.pvd") << u
