I’ve got a problem regarding a custom implementation of a mesh quality measure. I’ve developed this under Linux (installed fenics with conda), and tested it there (with the ubuntu ppa images) and it works.
Now, I was also testing this under Windows 10, using the docker image quay.io/fenicsproject/stable:latest
and unfortunately, the program does not work.
To reproduce this problem, I have the following MWE
_cpp_code_mesh_quality = """
#include <pybind11/eigen.h>
namespace py = pybind11;
#include <dolfin/mesh/Mesh.h>
#include <dolfin/mesh/MeshFunction.h>
#include <dolfin/mesh/Cell.h>
using namespace dolfin;
dolfin::MeshFunction<double>
quality(std::shared_ptr<const Mesh> mesh)
MeshFunction<double> cf(mesh, mesh->topology().dim(), 0.0);
for (CellIterator cell(*mesh); !cell.end(); ++cell)
cf[*cell] = 1.0;
return cf;
PYBIND11_MODULE(SIGNATURE, m)
m.def("quality", &quality);
obj = compile_cpp_code(_cpp_code_mesh_quality)
mesh = UnitSquareMesh(10,10)
mf = obj.quality(mesh)
which should just return a MeshFunction which has values 1.0 everywhere. This works fine under my Linux installation, but with the Docker image I get the following error:
File "mwe_meshqual.py", line 41, in <module>
TypeError: quality(): incompatible function arguments. The following argument types are supported:
1. (arg0: dolfin::Mesh) -> dolfin::MeshFunction<double>
Invoked with: <dolfin.cpp.generation.UnitSquareMesh object at 0x7f460bb8ba98>
So, apparently the class for this is not correct, but I have no clue why there is a different behavior between docker and my installation (I also use fenics 2019.1.0, which is the same used for docker)
Thanks a lot for your time.
