Problem with installing asimov-contact library bug in RayTracing.h
Hi, I recentely installed the latest version of fenicsx and I am trying to install the contact library at asimov-contact/cpp at main · Wells-Group/asimov-contact · GitHub
I followed the steps in Errors while running asimov-contact demos · Issue #168 · Wells-Group/asimov-contact · GitHub
git clone https://github.com/Wells-Group/asimov-contact.git
cd asimov-contact/cpp
mkdir build
cd build
cmake -DCMAKE_INSTALL_PREFIX=$CONDA_PREFIX ..
make -j4
and I had the following error
Consolidate compiler generated dependencies of target dolfinx_contact
[  5%] Building CXX object CMakeFiles/dolfinx_contact.dir/utils.cpp.o
[ 11%] Building CXX object CMakeFiles/dolfinx_contact.dir/contact_kernels.cpp.o
[ 17%] Building CXX object CMakeFiles/dolfinx_contact.dir/SubMesh.cpp.o
[ 23%] Building CXX object CMakeFiles/dolfinx_contact.dir/meshtie_kernels.cpp.o
In file included from /home/pietro/asimov-contact/cpp/utils.h:10,
                 from /home/pietro/asimov-contact/cpp/KernelData.h:11,
                 from /home/pietro/asimov-contact/cpp/meshtie_kernels.h:9,
                 from /home/pietro/asimov-contact/cpp/meshtie_kernels.cpp:7:
/home/pietro/asimov-contact/cpp/RayTracing.h:14:10: fatal error: spglog/spdlog.h: No such file or directory
   14 | #include <spglog/spdlog.h>
compilation terminated.
make[2]: *** [CMakeFiles/dolfinx_contact.dir/build.make:146: CMakeFiles/dolfinx_contact.dir/meshtie_kernels.cpp.o] Error 1
make[2]: *** Waiting for unfinished jobs....
                 from /home/pietro/asimov-contact/cpp/utils.cpp:7:
make[2]: *** [CMakeFiles/dolfinx_contact.dir/build.make:76: CMakeFiles/dolfinx_contact.dir/utils.cpp.o] Error 1
                 from /home/pietro/asimov-contact/cpp/contact_kernels.h:9,
                 from /home/pietro/asimov-contact/cpp/contact_kernels.cpp:7:
make[2]: *** [CMakeFiles/dolfinx_contact.dir/build.make:104: CMakeFiles/dolfinx_contact.dir/contact_kernels.cpp.o] Error 1
                 from /home/pietro/asimov-contact/cpp/SubMesh.cpp:8:
make[2]: *** [CMakeFiles/dolfinx_contact.dir/build.make:160: CMakeFiles/dolfinx_contact.dir/SubMesh.cpp.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:83: CMakeFiles/dolfinx_contact.dir/all] Error 2
make: *** [Makefile:136: all] Error 2
I tried also to install and include #include <spglog/spdlog.h>
but it didn’t work. Someone is facing the same problem and have an idea of how to solve it?
Many Thanks
I am not involved in the project, but looking at its git history it seems to me that the repository you cloned is compatible with dolfinx main branch, while you are using conda, which uses a dolfinx released version (0.8.0, maybe? Please check in your conda list).
Furthermore, are you sure that
comes from the most recent commit, and you have no local changes? There seems to be a typo spglog (instead of spdlog) in the directory name, and I just cloned the repository myself and can’t find that same typo.
