Hi! I am using FEniCS version 2017.2.0 and I try solver the lid-driven cavity problem with transient Navier-Stokes equation with stabilization SUPG/PSPG/LSIC.
My code:
from future import print_function
import math
------------- Problem data (cavity) -----------------------
N = 16 # mesh division number
f = Constant((0.0,0.0)) # body force
Re = 1000.0 # Reynolds number
nu = 1.0/Re # kinematic viscosity
Vmax = 1.0 # maximum velocity
T = 2.5 # final time
def inicial_condition():
v0 = Constant((0.0, 0.0))
return v0
class Lid(SubDomain):
return(on_boundary and near (x[1], 1.0))
class Walls(SubDomain):
return on_boundary and (near(x[0], 0.0) or near(x[0], 1.0) or near(x[1], 0.0))
def zero(x):
return (near(x[0], 0.0) and near(x[1], 0.0))
def boundary_condition(W):
# Dirichlet value
g1 = Constant ((1.0, 0.0))
g2 = Constant ((0.0, 0.0))
g3 = Constant (0.0)
# conditions
bc1 = DirichletBC(W.sub(0), g1, Lid())
bc2 = DirichletBC(W.sub(0), g2, Walls())
bc3 = DirichletBC(W.sub(1), g3, zero, âpointwiseâ)
bcs = [bc1, bc2, bc3]
return bcs
--------------- code -------------------
mesh = UnitSquareMesh(N, N)
h = 1.0/N
time step
dt = 0.2*(h/Vmax)
n_aux = T/dt + 1.0
n = int(n_aux)
dt = T/n
t_range = np.linspace(0,T,n+1) [1:]
define function space
P1v = VectorElement(âLagrangeâ, mesh.ufl_cell(), 1)
P1 = FiniteElement(âLagrangeâ, mesh.ufl_cell(), 1)
TH = P1v*P1
W = FunctionSpace(mesh, TH)
trial and test function
vp = TrialFunction(W)
(v, p) = split(vp)
(w, q) = TestFunctions(W)
vp_ = Function(W)
#v_, p_ = split(vp_)
set conditions
v0 = inicial_condition()
vn = interpolate(v0, W.sub(0).collapse())
bcs = boundary_condition(W)
Galerkin formulation
F = (inner(v - vn, w)/dt + inner(dot(vn,nabla_grad(v)), w) + nu*inner(grad(w), grad(v)) - inner(p,div(w)) - inner(q,div(v)) - inner(f, w))*dx
Stabilization parameters
vnorm = sqrt(dot(v, v))
momentum residue
R = (1.0/dt)(v-vn) + dot(v,nabla_grad(v)) - nudiv(grad(v)) + grad§ - f
PSPG
tau_pspg = ((2.0/dt)2 + (2.0vnorm/h)*2 + 9.0(4.0nu/(h2))2)(-0.5)#1.0/sqrt( pow(2.0/dt,2) + pow(2.0vnorm)/h,2) + 9.0pow((4.0nu)/(h**2),2))
F_pspg = tau_pspginner(R, grad(q))*dx
SUPG
tau_supg = ((2.0/dt)2 + (2.0vnorm/h)*2 + 9.0(4.0nu/(h2))2)(-0.5)
F_supg = tau_supg*inner(R, dot(v, grad(w)))*dx
LSIC
tau_lsic = (vnormh)/2.0
F_lsic = tau_lsicinner(div(v), div(w))*dx
Add stabilization terms
F += -F_pspg + F_supg + F_lsic
Jacobian
F1 = action(F, vp_)
J = derivative(F1, vp_, vp)
time loop
for t in t_range:
print(â\nt = {}\nâ.format(t))
problem = NonlinearVariationalProblem(F1, vp_, bcs, J)
prm = solver.parameters
prm[ânonlinear_solverâ]=ânewtonâ
prm[ânewton_solverâ][âabsolute_toleranceâ] = 1E-4
prm[ânewton_solverâ][ârelative_toleranceâ] = 1E-4
prm[ânewton_solverâ][âmaximum_iterationsâ] = 20
prm[ânewton_solverâ][ârelaxation_parameterâ] = 1.0
prm[ânewton_solverâ][âlinear_solverâ] = âgmresâ
prm[ânewton_solverâ][âkrylov_solverâ][âabsolute_toleranceâ] = 1E-8
prm[ânewton_solverâ][âkrylov_solverâ][ârelative_toleranceâ] = 1E-8
prm[ânewton_solverâ][âkrylov_solverâ][âmaximum_iterationsâ] = 1000
prm[ânewton_solverâ][âkrylov_solverâ][âmonitor_convergenceâ] = True
prm[ânewton_solverâ][âkrylov_solverâ][ânonzero_initial_guessâ] = False
#prm[ânewton_solverâ][âkrylov_solverâ][âgmresâ][ârestartâ] = 40
prm[ânewton_solverâ][âpreconditionerâ] = âiluâ
#prm[ânewton_solverâ][âkrylov_solverâ][âpreconditionerâ][âstructureâ] = âsame_nonzero_patternâ
#prm[ânewton_solverâ][âkrylov_solverâ][âpreconditionerâ][âiluâ][âfill_levelâ] =0
PROGRESS = 16
set_log_level(PROGRESS)
solver.solve()
v_ , p_ = vp_.split(True)
print(v_.vector().array())
t = t + dt
vn.assign(v_)
plt.figure()
plot(v_)
plt.figure()
plot(p_)
The parameters commented in solver donât work.
The error:
Newton iteration 0: r (abs) = -nan (tol = 1.000e-04) r (rel) = -nan (tol = 1.000e-04)
PETSc Krylov solver starting to solve 867 x 867 system.
File âcavidade_SUPG.pyâ, line 124, in
solver.solve()
RuntimeError:
*** Reason: Solution failed to converge in 0 iterations (PETSc reason DIVERGED_NANORINF, residual norm ||r|| = 0.000000e+00).
*** Where: This error was encountered inside PETScKrylovSolver.cpp.
*** Process: 0
*** DOLFIN version: 2017.2.0
*** Git changeset: unknown
I donât know what is wrong, because appear -nan in first iteration of Newton.
