Solving Stokes equation with SUPG - Error in Newton Solver
Hello Fenics Community,
I am solving stokes equation using SUPG stabilization. I am setting this problem for lid-driven cavity flow problem. I am using mixed finite element spaces. I am facing issues in the Nonlinear solver. The solver is not converging. I have tried changing solver options, but failed. Can someone help me with it? Am I missing anything in the formulation or solver setup?
I am using FeNiCSx 0.9.0. The MWE is as follows:
from dolfinx import fem, mesh, nls, io
# Create mesh (Unit square domain)
domain = mesh.create_unit_square(MPI.COMM_WORLD, 50, 50)
def noslip_boundary(x):
    return np.isclose(x[1], 0.0) | np.isclose(x[0], 0.0) | np.isclose(x[0], 1.0)
def lid_boundary(x):
    return np.isclose(x[1], 1.0)
noslip_facets = mesh.locate_entities_boundary(domain, domain.topology.dim - 1, noslip_boundary)
lid_facets = mesh.locate_entities_boundary(domain, domain.topology.dim - 1, lid_boundary)
# Define equal-order elements (P1-P1 discretization)
P1v = element("Lagrange", domain.basix_cell(), 2,  shape=(domain.geometry.dim,) )  # Velocity (P1)
P1p = element("Lagrange", domain.basix_cell(), 1)  # Pressure (P1)
TH = mixed_element([P1v, P1p])
VQ= fem.functionspace(domain, TH)
(v, q) =ufl.TestFunctions(VQ)
# Define solution function
up = fem.Function(VQ)  # Nonlinear unknown (velocity-pressure)
u, p = ufl.split(up)
# Fluid properties
nu_val = 0.01  # Kinematic viscosity
f = fem.Constant(domain, PETSc.ScalarType((0.0, 0.0)))  # Body force
# SUPG stabilization parameters
h = ufl.CellDiameter(domain)
vel_norm = ufl.sqrt(ufl.inner(u, u) + 1e-6)
Pe = vel_norm * h / (2 * nu_val)
Pe = ufl.max_value(Pe, 1e-6)  # Avoid zero Pe
tau_SUPG = h / (2 * vel_norm) * (ufl.exp(Pe) - ufl.exp(-Pe)) / (ufl.exp(Pe) + ufl.exp(-Pe)) - 1/Pe
# Weak form of Stokes equations
F = (nu_val * ufl.inner(ufl.grad(u), ufl.grad(v)) * ufl.dx
     - p * ufl.div(v) * ufl.dx
     - q * ufl.div(u) * ufl.dx
     - ufl.inner(f, v) * ufl.dx)
# SUPG stabilization term
R_m = -nu_val * ufl.div(ufl.grad(u)) + ufl.grad(p) - f
F_SUPG = tau_SUPG * ufl.inner(R_m, ufl.dot(u, ufl.grad(v))) * ufl.dx
F += F_SUPG
# Get subspace of V
V0 = VQ.sub(0)
V, _ = V0.collapse()
# Get subspace of Q
Q0 = VQ.sub(1)
Q, _ = Q0.collapse()
# Define boundary conditions
zero_velocity = fem.Function(V)
zero_velocity.interpolate(lambda x: np.zeros((2, x.shape[1])))
lid_velocity = fem.Function(V)
lid_velocity.interpolate(lambda x: np.stack((np.ones_like(x[0]), np.zeros_like(x[1]))))
noslip_dofs = fem.locate_dofs_topological(V, domain.topology.dim - 1, noslip_facets)
lid_dofs = fem.locate_dofs_topological(V, domain.topology.dim - 1, lid_facets)
bc_noslip = fem.dirichletbc(zero_velocity, noslip_dofs)
bc_lid = fem.dirichletbc(lid_velocity, lid_dofs)
bcs = [bc_noslip, bc_lid]
if len(bcs) == 0:
    raise ValueError("No boundary conditions found. Check domain boundaries.")
# Define nonlinear problem
uh = fem.Function(VQ)
duh = ufl.TrialFunction(VQ)
dF = ufl.derivative(F, uh, duh)
problem = fem.petsc.NonlinearProblem(F, uh, bcs=bcs, J=dF)
#nls.petsc.NewtonSolver(MPI.COMM_WORLD, problem)
solver.rtol = 1e-3  # Looser relative tolerance
solver.atol = 1e-3  # Looser absolute tolerance
solver.max_it = 200  # Allow more iterations
solver.report = True  # Print iteration details
ksp = solver.krylov_solver
opts = PETSc.Options()
opts[f"{option_prefix}ksp_type"] = "preonly"  # Use a direct solver (no Krylov iterations)
opts[f"{option_prefix}pc_type"] = "lu"        # LU factorization (direct solve)
opts[f"{option_prefix}pc_factor_mat_solver_type"] = "mumps"  # Use MUMPS as the direct solver
ksp.setFromOptions()
# Compute the solution
solver.solve(uh)
# Extract velocity and pressure solutions
uh_velocity = fem.Function(V)
uh_pressure = fem.Function(Q)
uh_velocity.interpolate(uh.sub(0))
uh_pressure.interpolate(uh.sub(1))
# Save results
with io.XDMFFile(MPI.COMM_WORLD, "velocity.xdmf", "w") as file:
    file.write_mesh(domain)
    file.write_function(uh_velocity)
with io.XDMFFile(MPI.COMM_WORLD, "pressure.xdmf", "w") as file:
    file.write_function(uh_pressure)
This code is not properly formatted. Please use
```python
#add code here
and ensure that people can copy-paste, then run the code.
Thanks for pointing out. Fixed it!
Sorry I can’t run your code right now, but it might have to deal with your boundary dofs. Instead of:
Try:
zero_velocity = fem.Function(VQ)
zero_velocity.sub(0).interpolate(lambda x: np.zeros((2, x.shape[1])))
noslip_facets = mesh.locate_entities_boundary(msh, msh.topology.dim - 1, periodic_marker)
noslip_dofs = fem.locate_dofs_topological(VQ, msh.topology.dim - 1, noslip_facets)
bc_noslip = fem.dirichletbc(zero_velocity, noslip_dofs )
Same for lid. If you want to have the dof map between VQ and V, use:
V, V_map = VQ.sub(0).collapse()
Q, Q_map = VQ.sub(1).collapse()
Let me know !
Hi TheauC,
Thanks for the response. The problem still persist. The error is same as previous. I am copy-pasting it here.
File "/Users/tarungangwar/Documents/0_work/Research/Projects/try/stokes.py", line 118, in <module>
    solver.solve(uh)
  File "/Users/tarungangwar/anaconda3/envs/fenicsx-env/lib/python3.13/site-packages/dolfinx/nls/petsc.py", line 51, in solve
    n, converged = super().solve(u.x.petsc_vec)
RuntimeError: Newton solver did not converge because maximum number of iterations reached
Your dF is wrong.
It should be differentiated with respect to up, which is the variable you use within the residual formulation, not a new variable uh that is not used anywhere. ufl.derivative(F, uh, duh) is naturally zero, as F is not a function of uh.
As a side note, if I am not mistaken, you’ll want
F_SUPG = tau_SUPG * ufl.inner(R_m, ufl.dot(u, ufl.nabla_grad(v))) * ufl.dx
so, nabla_grad instead of grad. Acting on vectors, the resulting tensors are transposes of each other.
Also, (and I imagine this is besides the point, as you probably intend to use this code for Navier-Stokes,) SUPG for a Stokes formulation doesn’t actually stabilize. It needs the advection term of the PDE so that \int \tau R_m \cdot ((\mathbf{u}\cdot\nabla )\mathbf{v}) contributes a positive-definite term (namely \tau ((\tilde{\mathbf{u}}\cdot\nabla) \mathbf{u}) \cdot ( (\tilde{\mathbf{u}}\cdot\nabla ) \mathbf{v}) .
Hi Stein,
Thanks. I tried the above suggestions; but, the solver did not converge.
I did not know that you are still active on this forum. Yes, I want to eventually implement NS solver using SUPG. I am using Stokes to setup and test FeNiCSx mixed spaces and Nonlinear solver. Perhaps, I should first implement stokes with Taylor-Hood using linear solver and then proceed for more complex problems.
I could well imagine that is because of this:
(It actually destabilizes)
