Problems with convergence of the elasticity equation
This is an attempt at verifying the mesh convergence results for the Elasticity equation (Ch.42 Finite Elements II: Galerkin Approximation, Elliptic and Mixed PDEs Finite Elements II: Galerkin Approximation, Elliptic and Mixed PDEs - Archive ouverte HAL or home page of Alexandre Ern)
using a manufactured problem.
The problem is pretty straightforward and the implementation follows the demos and tutorials very closely. However the expected rates of convergence are not observed.
Any feedback, pointers to fix this are greatly appreciated. Thanks.
Since it is a check for convergence, unfortunately the code looks lengthy than a typical MWE.
Checked MWE with the docker image dolfinx/dolfinx:v0.6.0-r1
(note: I have checked with many different manufactured problems, I can post if you would like to have a look:
ones with nonhomogeneous boundary, and trigonometric functions insead of 2nd degree polynomials)
Imports and error computations:
import pandas as pd
from dolfinx.mesh import (create_unit_square, CellType, GhostMode,
                          locate_entities_boundary)
from dolfinx.fem import (Function, FunctionSpace,
                         dirichletbc, form, locate_dofs_topological)
from dolfinx.fem import assemble_scalar
from dolfinx import fem
from ufl import inner, dot, nabla_grad, nabla_div, Identity, dx
pd.set_option('display.float_format', '{:1.6e}'.format)
def error_L2(uh, u_ex, W=None, degree_raise=3):
    msh = uh.function_space.mesh
    # Interpolate approximate solution
    u_W = Function(W)
    u_W.interpolate(uh)
    # Interpolate exact solution
    u_ex_W = Function(W)
    u_ex_W.interpolate(u_ex)
    # Compute the error in the higher order function space
    e_W = Function(W)
    e_W.x.array[:] = u_W.x.array - u_ex_W.x.array
    # Integrate the error
    error = form(inner(e_W, e_W) * dx)
    error_local = assemble_scalar(error)
    error_global = msh.comm.allreduce(error_local, op=MPI.SUM)
    return np.sqrt(error_global)
def error_H1(uh, u_ex, W=None):
    u_W = Function(W)
    u_W.interpolate(uh)
    e_W = Function(W)
    error = form(inner(e_W, e_W) * ufl.dx + inner(nabla_grad(e_W), nabla_grad(e_W)) * dx)
def error_max(uh, u_ex, W=None, degree_raise=3):
    u_W = Function(W)
    u_W.interpolate(uh)
    e_W = Function(W)
    error_max = np.max(np.abs(e_W.x.array))
    error_max = msh.comm.allreduce(error_max, op=MPI.MAX)
    return error_max
def epsilon(w):
    return 0.5*(nabla_grad(w) + nabla_grad(w).T)
def sigma(w, dim, lamda, mu):
    return lamda*nabla_div(w)*Identity(dim) + 2*mu*epsilon(w)
Exact solution and data are
class u_expression():
    def __init__(self, U=[20.0, 10.0]):
        self.U = U
    def eval(self, x):
        return (-self.U[0]*x[0]*(1-x[0])*x[1]*(1-x[1]),
                -self.U[1]*x[0]*(1-x[0])*x[1]*(1-x[1]))
class f_expression():
    def __init__(self, U=[20.0, 10.0], LAMBDA=20.0, MU=10.0):
        self.U = U
        self.LAMBDA = LAMBDA
        self.MU = MU
    def eval(self, x):
        return (- 2*self.U[0]*(1-x[1])*x[1]*(self.LAMBDA+2*self.MU)
                                        + self.U[1]*((1-2*x[0])*(1-2*x[1])*(self.LAMBDA + self.MU) - 2*self.MU*(1-x[0])*x[0]),
                - 2*self.U[1]*(1-x[0])*x[0]*(self.LAMBDA+2*self.MU)
                                        + self.U[0]*((1-2*x[0])*(1-2*x[1])*(self.LAMBDA + self.MU) - 2*self.MU*(1-x[1])*x[1]),
def solve(mesh=None, degree=2, boundary=None, tags_u=None):
    fdim = mesh.topology.dim - 1
    element = ufl.VectorElement("Lagrange", mesh.ufl_cell(), degree)
    # Solution Function
    u_n = Function(V, name="u_n")
    # boundary data
    u_D = Function(V)
    u_D.interpolate(u_e.eval)
    facets = locate_entities_boundary(mesh, fdim, boundary)
    dofs = locate_dofs_topological(V, fdim, facets)
    bcs = [fem.dirichletbc(value=u_D, dofs=dofs)]
    f = Function(V)
    f.interpolate(f_e.eval)
    # Assembly of stiffness matrix
    block = inner(sigma(u, 2, LAMBDA, MU), epsilon(v)) * dx
    rhs = inner(f, v) * dx
    A_form = form(block)
    L_form = form(rhs)
    A_mat = fem.petsc.assemble_matrix(A_form, bcs=bcs)
    A_mat.assemble()
    b_vec = fem.petsc.create_vector(L_form)
    # Direct solver
    solver.setOperators(A_mat)
    solver.setType("preonly")
    solver.getPC().setType("lu")
    with b_vec.localForm() as loc_b:
        loc_b.set(0)
    fem.petsc.assemble_vector(b_vec, L_form)
    fem.petsc.apply_lifting(b_vec, [A_form], bcs=[bcs])
    b_vec.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
    fem.petsc.set_bc(b_vec, bcs)
    solver.solve(b_vec, u_n.vector)
    u_n.x.scatter_forward()
    return u_n, solver
Convergence check
boundary = lambda x: np.isclose(x[0], 0) | np.isclose(x[0], 1) | np.isclose(x[1], 0) | np.isclose(x[1], 1)
ns_list = [2**i for i in range(3,8)]
degree = 2
LAMBDA = 20.0
MU = 10.0
U = [20.0, 10.0]
u_e = u_expression(U=U)
f_e = f_expression(U=U, LAMBDA=LAMBDA, MU=MU)
df = pd.DataFrame([], columns=["ns", "error_L2", "error_H1", "error_max"])
for cnt, ns in enumerate(ns_list):
    mesh = create_unit_square(MPI.COMM_WORLD,
                              ns, ns,
                              CellType.triangle, GhostMode.none)
    element = ufl.VectorElement("Lagrange", mesh.ufl_cell(), degree+3)
    V_ex = FunctionSpace(mesh, element)
    # Function
    u_ref = Function(V_ex)
    u_ref.interpolate(u_e.eval)
    u_n, solver = solve(mesh, degree=degree, boundary=boundary)
    df.loc[cnt, "ns"] = ns
    df.loc[cnt, "error_L2"] = error_L2(u_n, u_ref, V_ex)
    df.loc[cnt, "error_H1"] = error_H1(u_n, u_ref, V_ex)
    df.loc[cnt, "error_max"] = error_max(u_n, u_ref, V_ex)
print(df)
The result:
ns	error_L2	error_H1	error_max
0	8	9.993293e-02	4.757606e-01	1.288192e-01
1	16	1.000108e-01	4.743987e-01	1.289061e-01
2	32	1.000236e-01	4.744044e-01	1.289178e-01
3	64	1.000255e-01	4.744200e-01	1.289195e-01
4	128	1.000258e-01	4.744235e-01	1.289197e-01
I ran into the classic problem, I guess I was too hasty to put my question here.
I had written down the Navier-Cauchy equations wrong all along since a long long time, which worked for a manufactured problem with certain symmetry. :grinning:
I overlooked checking that up. I guess that should have been the first step instead of hallucinating about how the dofs are organized in VectorFunctionSpaces :grinning:.
        self.U = U
        self.MU = MU
    def eval(self, x):
        return (- 2*self.U[0]*((1-x[1])*x[1]*(self.LAMBDA+2*self.MU) + self.MU*x[0]*(1-x[0]))
                                        + self.U[1]*(1-2*x[0])*(1-2*x[1])*(self.LAMBDA + self.MU),
                - 2*self.U[1]*((1-x[0])*x[0]*(self.LAMBDA+2*self.MU) + self.MU*x[1]*(1-x[1]))
                                        + self.U[0]*(1-2*x[0])*(1-2*x[1])*(self.LAMBDA + self.MU),
Thanks for reading.
