Regarding the FEniCSx demo: Elasto-plastic analysis of a 2D von Mises material - Elasto-plastic analysis of a 2D von Mises material — Computational Mechanics Numerical Tours with FEniCSx, I have two questions:
- In the legacy demo (Elasto-plastic analysis of a 2D von Mises material — Numerical tours of continuum mechanics using FEniCS master documentation), it is said the plastic strain (in quadrature function space) must first be projected onto the previously defined DG FunctionSpace:
p_avg.assign(project(p, P0)); file_results.write(p_avg, t), how to do this in FEniCSx? - Following item1, I defined a project function, but when trying to save the vector function in VTK file, the kernel died. please see the following code.
import basix
import dolfinx.fem.petsc
hsize = 0.2
Re = 1.3
Ri = 1.0
gdim = 2
model_rank = 0
if MPI.COMM_WORLD.rank == 0:
gmsh.option.setNumber("General.Terminal", 0) # to disable meshing info
gmsh.model.add("Model")
geom = gmsh.model.geo
center = geom.add_point(0, 0, 0)
p1 = geom.add_point(Ri, 0, 0)
p2 = geom.add_point(Re, 0, 0)
p3 = geom.add_point(0, Re, 0)
p4 = geom.add_point(0, Ri, 0)
x_radius = geom.add_line(p1, p2)
outer_circ = geom.add_circle_arc(p2, center, p3)
y_radius = geom.add_line(p3, p4)
inner_circ = geom.add_circle_arc(p4, center, p1)
boundary = geom.add_curve_loop([x_radius, outer_circ, y_radius, inner_circ])
surf = geom.add_plane_surface([boundary])
geom.synchronize()
gmsh.option.setNumber("Mesh.CharacteristicLengthMin", hsize)
gmsh.option.setNumber("Mesh.CharacteristicLengthMax", hsize)
gmsh.model.addPhysicalGroup(gdim, [surf], 1)
gmsh.model.addPhysicalGroup(gdim - 1, [x_radius], 1, name="bottom")
gmsh.model.addPhysicalGroup(gdim - 1, [y_radius], 2, name="left")
gmsh.model.addPhysicalGroup(gdim - 1, [inner_circ], 3, name="inner")
domain, _, facets = io.gmshio.model_to_mesh(
gmsh.model, MPI.COMM_WORLD, model_rank, gdim=gdim
gmsh.finalize()
E = fem.Constant(domain, 70e3) # in MPa
nu = fem.Constant(domain, 0.3)
lmbda = E * nu / (1 + nu) / (1 - 2 * nu)
mu = E / 2.0 / (1 + nu)
sig0 = fem.Constant(domain, 250.0) # yield strength in MPa
Et = E / 100.0 # tangent modulus
H = E * Et / (E - Et) # hardening modulus
deg_u = 2
shape = (gdim,)
V = fem.functionspace(domain, ("P", deg_u, shape))
Vx, _ = V.sub(0).collapse()
Vy, _ = V.sub(1).collapse()
bottom_dofsy = fem.locate_dofs_topological((V.sub(1), Vy), gdim - 1, facets.find(1))
top_dofsx = fem.locate_dofs_topological((V.sub(0), Vx), gdim - 1, facets.find(2))
# used for post-processing
def bottom_inside(x):
return np.logical_and(np.isclose(x[0], Ri), np.isclose(x[1], 0))
bottom_inside_dof = fem.locate_dofs_geometrical((V.sub(0), Vx), bottom_inside)[0]
u0x = fem.Function(Vx)
u0y = fem.Function(Vy)
bcs = [
fem.dirichletbc(u0x, top_dofsx, V.sub(0)),
fem.dirichletbc(u0y, bottom_dofsy, V.sub(1)),
n = ufl.FacetNormal(domain)
q_lim = float(2 / np.sqrt(3) * np.log(Re / Ri) * sig0)
loading = fem.Constant(domain, 0.0)
deg_quad = 2 # quadrature degree for internal state variable representation
W0e = basix.ufl.quadrature_element(
domain.basix_cell(), value_shape=(), scheme="default", degree=deg_quad
We = basix.ufl.quadrature_element(
domain.basix_cell(), value_shape=(4,), scheme="default", degree=deg_quad
W = fem.functionspace(domain, We)
W0 = fem.functionspace(domain, W0e)
sig = fem.Function(W)
sig_old = fem.Function(W)
n_elas = fem.Function(W)
beta = fem.Function(W0)
p = fem.Function(W0, name="Cumulative_plastic_strain")
dp = fem.Function(W0)
u = fem.Function(V, name="Total_displacement")
du = fem.Function(V, name="Iteration_correction")
Du = fem.Function(V, name="Current_increment")
v = ufl.TrialFunction(V)
u_ = ufl.TestFunction(V)
P0 = fem.functionspace(domain, ("DG", 0))
p_avg = fem.Function(P0, name="Plastic_strain")
def eps(v):
e = ufl.sym(ufl.grad(v))
return ufl.as_tensor([[e[0, 0], e[0, 1], 0], [e[0, 1], e[1, 1], 0], [0, 0, 0]])
def elastic_behavior(eps_el):
return lmbda * ufl.tr(eps_el) * ufl.Identity(3) + 2 * mu * eps_el
def as_3D_tensor(X):
return ufl.as_tensor([[X[0], X[3], 0], [X[3], X[1], 0], [0, 0, X[2]]])
def to_vect(X):
return ufl.as_vector([X[0, 0], X[1, 1], X[2, 2], X[0, 1]])
ppos = lambda x: ufl.max_value(x, 0)
def constitutive_update(Δε, old_sig, old_p):
sig_n = as_3D_tensor(old_sig)
sig_elas = sig_n + elastic_behavior(Δε)
s = ufl.dev(sig_elas)
sig_eq = ufl.sqrt(3 / 2.0 * ufl.inner(s, s))
f_elas = sig_eq - sig0 - H * old_p
dp = ppos(f_elas) / (3 * mu + H)
n_elas = s / sig_eq * ppos(f_elas) / f_elas
beta = 3 * mu * dp / sig_eq
new_sig = sig_elas - beta * s
return to_vect(new_sig), to_vect(n_elas), beta, dp
def sigma_tang(eps):
N_elas = as_3D_tensor(n_elas)
return (
elastic_behavior(eps)
- 3 * mu * (3 * mu / (3 * mu + H) - beta) * ufl.inner(N_elas, eps) * N_elas
- 2 * mu * beta * ufl.dev(eps)
ds = ufl.Measure("ds", domain=domain, subdomain_data=facets)
dx = ufl.Measure(
"dx",
domain=domain,
metadata={"quadrature_degree": deg_quad, "quadrature_scheme": "default"},
Residual = ufl.inner(eps(u_), as_3D_tensor(sig)) * dx - ufl.inner(
-loading * n, u_
) * ds(3)
tangent_form = ufl.inner(eps(v), sigma_tang(eps(u_))) * dx
basix_celltype = getattr(basix.CellType, domain.topology.cell_type.name)
quadrature_points, weights = basix.make_quadrature(basix_celltype, deg_quad)
map_c = domain.topology.index_map(domain.topology.dim)
num_cells = map_c.size_local + map_c.num_ghosts
cells = np.arange(0, num_cells, dtype=np.int32)
def interpolate_quadrature(ufl_expr, function):
expr_expr = fem.Expression(ufl_expr, quadrature_points)
expr_eval = expr_expr.eval(domain, cells)
function.x.array[:] = expr_eval.flatten()[:]
class CustomLinearProblem(fem.petsc.LinearProblem):
def assemble_rhs(self, u=None):
"""Assemble right-hand side and lift Dirichlet bcs.
Parameters
u : dolfinx.fem.Function, optional
For non-zero Dirichlet bcs u_D, use this function to assemble rhs with the value u_D - u_{bc}
where u_{bc} is the value of the given u at the corresponding. Typically used for custom Newton methods
with non-zero Dirichlet bcs.
# Assemble rhs
with self._b.localForm() as b_loc:
b_loc.set(0)
fem.petsc.assemble_vector(self._b, self._L)
# Apply boundary conditions to the rhs
x0 = [] if u is None else [u.vector]
fem.petsc.apply_lifting(self._b, [self._a], bcs=[self.bcs], x0=x0, scale=1.0)
self._b.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
x0 = None if u is None else u.vector
fem.petsc.set_bc(self._b, self.bcs, x0, scale=1.0)
def assemble_lhs(self):
self._A.zeroEntries()
fem.petsc.assemble_matrix_mat(self._A, self._a, bcs=self.bcs)
self._A.assemble()
def solve_system(self):
# Solve linear system and update ghost values in the solution
self._solver.solve(self._b, self._x)
self.u.x.scatter_forward()
tangent_problem = CustomLinearProblem(
tangent_form,
-Residual,
u=du,
bcs=bcs,
petsc_options={
"ksp_type": "preonly",
"pc_type": "lu",
def project(source_function, target_space):
Project a function from its current function space onto a target function space.
Parameters:
- source_function: fem.Function
The function to be projected.
- target_space: fem.FunctionSpace
The function space onto which the source function should be projected.
Returns:
- fem.Function
The projected function in the target function space.
# Create the projected function in the target space
projected_function = fem.Function(target_space)
# Define the test function and trial function in the target space
v = ufl.TestFunction(target_space)
u = ufl.TrialFunction(target_space)
# Define the variational problem (a is the bilinear form, L is the linear form)
a = ufl.inner(u, v) * ufl.dx
L = ufl.inner(source_function, v) * ufl.dx
# Solve the variational problem to project the source function onto the target space
problem = fem.petsc.LinearProblem(a, L, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
projected_function = problem.solve()
return projected_function
# alternative
def project1(v, V):
Project a function or expression `v` onto a function space `V`.
Parameters:
v : dolfinx.fem.Function or ufl.Expression
The function or expression to project.
V : dolfinx.fem.FunctionSpace
The target function space to project onto.
Returns:
u_proj : dolfinx.fem.Function
The projected function in the function space `V`.
# Define trial and test functions in the target function space
u = ufl.TrialFunction(V)
w = ufl.TestFunction(V)
# Define the bilinear form (left-hand side)
a = ufl.inner(u, w) * dx
# Define the linear form (right-hand side) using the function to project
L = ufl.inner(v, w) * dx
# Convert the forms to dolfinx.fem.Form objects
a_form = dolfinx.fem.form(a)
L_form = dolfinx.fem.form(L)
# Assemble the system matrix A and the right-hand side vector b
A = dolfinx.fem.petsc.assemble_matrix(a_form)
b = dolfinx.fem.petsc.assemble_vector(L_form)
# Create a function in the target space to hold the projected result
u_proj = dolfinx.fem.Function(V)
# Solve the linear system to compute the projection
solver = PETSc.KSP().create(V.mesh.comm)
solver.setOperators(A)
solver.solve(b, u_proj.vector)
u_proj.x.scatter_forward()
return u_proj
SigOut = fem.functionspace(domain, ("DG", 0, (4, )))
sigmaout=fem.Function(SigOut, name="Stresses")
vtk = io.VTKFile(domain.comm, "results1/elastoplastic.pvd", "w")
Nitermax, tol = 200, 1e-6 # parameters of the Newton-Raphson procedure
Nincr = 20
load_steps = np.linspace(0, 1.1, Nincr + 1)[1:] ** 0.5
results = np.zeros((Nincr + 1, 3))
# we set all functions to zero before entering the loop in case we would like to reexecute this code cell
sig.vector.set(0.0)
sig_old.vector.set(0.0)
p.vector.set(0.0)
u.vector.set(0.0)
n_elas.vector.set(0.0)
beta.vector.set(0.0)
Δε = eps(Du)
sig_, n_elas_, beta_, dp_ = constitutive_update(Δε, sig_old, p)
for i, t in enumerate(load_steps):
loading.value = t * q_lim
# compute the residual norm at the beginning of the load step
tangent_problem.assemble_rhs()
nRes0 = tangent_problem._b.norm()
nRes = nRes0
Du.x.array[:] = 0
niter = 0
while nRes / nRes0 > tol and niter < Nitermax:
# solve for the displacement correction
tangent_problem.assemble_lhs()
tangent_problem.solve_system()
# update the displacement increment with the current correction
Du.vector.axpy(1, du.vector) # Du = Du + 1*du
Du.x.scatter_forward()
# interpolate the new stresses and internal state variables
interpolate_quadrature(sig_, sig)
interpolate_quadrature(n_elas_, n_elas)
interpolate_quadrature(beta_, beta)
# compute the new residual
nRes = tangent_problem._b.norm()
niter += 1
# Update the displacement with the converged increment
u.vector.axpy(1, Du.vector) # u = u + 1*Du
# Update the previous plastic strain
interpolate_quadrature(dp_, dp)
p.vector.axpy(1, dp.vector)
# Update the previous stress
sig_old.x.array[:] = sig.x.array[:]
p_avg.interpolate(project(p, P0))
vtk.write_function(p_avg,t)
sigmaout.interpolate(project(sig,SigOut))
vtk.write_function(sigmaout,t)
vtk.close()
