I am trying to plot the gradient of a function I solved to observe the discontinuities in the shape functions. I am getting an error when I run the code.
I made the gradient as dTh and I am trying to plot that. My code is as follows:
Generate mesh
domain = IntervalMesh(1000, 0, 1)
SC = FunctionSpace(domain, ‘CG’, 1)
Define boundary and apply BC
def L_bc(x, on_boundary):
return near(x[0], 0) and on_boundary
def R_bc(x, on_boundary):
return near(x[0], 1) and on_boundary
bc = [DirichletBC(SC, Constant(0.), L_bc), DirichletBC(SC, Constant(0.), R_bc)]
Define
#f = Expression(‘exp(x[0]*x[0])’, degree=2)
#C = Expression(‘pow(x[0],3) + 10’, degree=3)
f = Expression(‘exp(-x[0])’, degree=2)
#C = Expression(‘2+x[0]exp(x[0])(x[0]-1)’, degree=2)
C = Expression(‘2*(6*x[0]x[0] - 6x[0] + 1) + x[0]x[0]exp(-x[0])(x[0]-1)(x[0]-1)’, degree=2)
Define test and trial functions
u = TrialFunction(SC)
v = TestFunction(SC)
Weak form
#a = dot(grad(w), grad(T))dx + CwTdx
sol = dot(grad(u), grad(v))dx + vfudx
#L = fwdx
L = vCdx
Compute solution
Th = Function(SC, name=“displacement_linear_1000”)
solve(sol == L, Th, bc)
sigma = grad(u)
x_plt = np.linspace(0, 1, 1000)
Th_plt = np.fromiter(map(Th, x_plt), dtype=np.double)
plt.plot(x_plt, Th_plt)
V = VectorFunctionSpace(domain, “DG”, 1)
dTh = project(grad(Th), V)
dTh_plt = np.fromiter(map(dTh, x_plt), dtype=np.double)
plt.plot(x_plt, dTh_plt)
file = File(“displacement_linear_1000.pvd”)
file << dTh
