Basic queries from the fenics book, chapter 1, Set #3
1.) A minimal example of discontinuos Galerkin method. I receive
ValueError: z array must not contain non-finite values within the triangulation
A minimum working example is
Nx = 4
Ny = 5
mesh = UnitSquareMesh(Nx, Ny)
V = FunctionSpace(mesh, 'DG', 1)
# Define boundary conditions
u0 = Expression('1 + x[0]*x[0] + 2*x[1]*x[1]', degree = 2)
def u0_boundary(x, on_boundary):
    return on_boundary
bc = DirichletBC(V, u0, u0_boundary)
f = Constant(-6.0)
a = inner(nabla_grad(u), nabla_grad(v))*dx
L = f*v*dx
# Compute solution
solve(a == L, u, bc)
plot(u)
2.) What is the proper way to look for documentation for dolfin? This is for me so that I can look for documentation by myself in the future and not to ask everything in the forum. For example, I’d like to look for the syntax of errornorm. I cannot find it from here
https://fenicsproject.org/documentation/
Choosing all four of the links in the section The FEniCS API Documentation, and searching for errornorm, I find nothing.
However, someway googling I found this
https://fenicsproject.org/docs/dolfin/1.4.0/python/programmers-reference/fem/norms/errornorm.html?highlight=errornorm#dolfin.fem.norms.errornorm
3.) I receive a NameError
NameError: name ‘umr’ is not defined
Also I am not sure what does it mean by the
degree = int(sys.argv[1])
This is exactly produced from the fencis book, page 26, program d6_p2D.py. Here is the minmal working code.
FEniCS tutorial demo program: Poisson equation with Dirichlet conditions.
As d5_p2D.py, but with a more complicated solution, error computations
and convergence studies.
import sys
def compute(nx, ny, degree):
mesh = UnitSquare(nx, ny)
V = FunctionSpace(mesh, ‘Lagrange’, degree=degree)
    return on_boundary
bc = DirichletBC(V, Constant(0.0), u0_boundary)
# Exact solution
omega = 1.0
u_e = Expression('sin(omega*pi*x[0])*sin(omega*pi*x[1])',
                 omega=omega)
#f = Function(V,
#    '2*pow(pi,2)*pow(omega,2)*sin(omega*pi*x[0])*sin(omega*pi*x[1])',
#    {'omega': omega})
f = 2*pi**2*omega**2*u_e
L = f*v*dx
# Compute solution
problem = LinearVariationalProblem(a, L, u, bc)
solver =  LinearVariationalSolver(problem)
solver.solve()
#plot(u, title='Numerical')
# Compute gradient
#gradu = project(grad(u), VectorFunctionSpace(mesh, 'Lagrange', degree))
# Compute error norm
# Function - Expression
error = (u - u_e)**2*dx
E1 = sqrt(assemble(error))
# Explicit interpolation of u_e onto the same space as u:
u_e_V = interpolate(u_e, V)
error = (u - u_e_V)**2*dx
E2 = sqrt(assemble(error))
# Explicit interpolation of u_e to higher-order elements,
# u will also be interpolated to the space Ve before integration
Ve = FunctionSpace(mesh, 'Lagrange', degree=5)
u_e_Ve = interpolate(u_e, Ve)
error = (u - u_e_Ve)**2*dx
E3 = sqrt(assemble(error))
# errornorm interpolates u and u_e to a space with
# given degree, and creates the error field by subtracting
# the degrees of freedom, then the error field is integrated
# TEMPORARY BUG - doesn't accept Expression for u_e
#E4 = errornorm(u_e, u, normtype='l2', degree=3)
# Manual implementation
def errornorm(u_e, u, Ve):
    u_Ve = interpolate(u, Ve)
    e_Ve = Function(Ve)
    # Subtract degrees of freedom for the error field
    e_Ve.vector()[:] = u_e_Ve.vector().array() - u_Ve.vector().array()
    # More efficient computation (avoids the rhs array result above)
    #e_Ve.assign(u_e_Ve)                      # e_Ve = u_e_Ve
    #e_Ve.vector().axpy(-1.0, u_Ve.vector())  # e_Ve += -1.0*u_Ve
    error = e_Ve**2*dx
    return sqrt(assemble(error, mesh=Ve.mesh())), e_Ve
E4, e_Ve = errornorm(u_e, u, Ve)
# Infinity norm based on nodal values
E5 = abs(u_e_V.vector().array() - u.vector().array()).max()
print 'E2:', E2
print 'E3:', E3
print 'E4:', E4
print 'E5:', E5
# H1 seminorm
error = inner(grad(e_Ve), grad(e_Ve))*dx
E6 = sqrt(assemble(error))
# Collect error measures in a dictionary with self-explanatory keys
errors = {'u - u_e': E1,
          'u - interpolate(u_e,V)': E2,
          'interpolate(u,Ve) - interpolate(u_e,Ve)': E3,
          'error field': E4,
          'infinity norm (of dofs)': E5,
          'grad(error field)': E6}
return errors
Perform experiments
h = # element sizes
E = # errors
for nx in [4, 8, 16, 32, 64, 128, 264]:
h.append(1.0/nx)
E.append(compute(nx, nx, degree)) # list of dicts
Convergence rates
from math import log as ln # log is a dolfin name too
error_types = E[0].keys()
for error_type in sorted(error_types):
print ‘\nError norm based on’, error_type
for i in range(1, len(E)):
Ei = E[i][error_type] # E is a list of dicts
Eim1 = E[i-1][error_type]
r = ln(Ei/Eim1)/ln(h[i]/h[i-1])
print ‘h=%8.2E E=%8.2E r=%.2f’ % (h[i], Ei, r)
4.) I cannot install scitools to work with the example in the fenics book, vcp2D.py. From my google search, I find one way to install, if it the same thing, I am not sure
pip install scitools3
From the google website, following the instructions I cannot install the package
https://code.google.com/archive/p/scitools/wikis/Installation.wiki
To quote
Packages
Debian
SciTools is now available in Debian. To install, simply run sudo apt-get install python-scitools
Here is the full code from the book
The Poisson equation with a variable coefficient.
-div(p*grad(u)) = f on the unit square.
u = u0 on x=0,
u0 = u = 1 + x^2 + 2y^2, p = x + y, f = -8x - 10y.
import numpy
plot = lambda *args, **kwargs: None
nx = 2
ny = 3
nx = 10
ny = 10
V = FunctionSpace(mesh, 'Lagrange', 1)
u0 = Expression('1 + x[0]*x[0] + 2*x[1]*x[1]')
class DirichletBoundary(SubDomain):
        return on_boundary
u0_boundary = DirichletBoundary()
p = Expression('x[0] + x[1]')
f = Expression('-8*x[0] - 10*x[1]')
a = p*inner(nabla_grad(u), nabla_grad(v))*dx
L = f*v*dx
# Compute solution
# Compute gradient
V_g = VectorFunctionSpace(mesh, 'Lagrange', 1)
v = TestFunction(V_g)
w = TrialFunction(V_g)
a = inner(w, v)*dx
L = inner(-p*grad(u), v)*dx
flux = Function(V_g)
solve(a == L, flux)
# Alternative
flux = project(-p*grad(u), VectorFunctionSpace(mesh, 'Lagrange', 1))
plot(u, title='u')
plot(flux, title='flux field')
flux_x, flux_y = flux.split(deepcopy=True)  # extract components
plot(flux_x, title='x-component of flux (-p*grad(u))')
plot(flux_y, title='y-component of flux (-p*grad(u))')
plot(mesh)
# Alternative computation of the flux
flux2 = project(-p*grad(u), VectorFunctionSpace(mesh, 'Lagrange', 1))
print mesh
# Dump solution and flux to the screen with errors
u_array = u.vector().array()
flux_x_array = flux_x.vector().array()  # ok if deepcopy
flux_y_array = flux_y.vector().array()
# if not deepcopy of flux_x, flux_y:
#q = flux.vector().array()
#q.shape = (2, len(q)/2)
#flux_x_array = q[0,:]
#flux_y_array = q[1,:]
if mesh.num_cells() < 1600:
    coor = mesh.coordinates()
    for i in range(len(u_array)):
        x, y = coor[i]
        print 'Node (%.3f,%.3f): u = %.4f (%9.2e), '\
              'flux_x = %.4f  (%9.2e), flux_y = %.4f  (%9.2e)' % \
              (x, y, u_array[i], 1 + x**2 + 2*y**2 - u_array[i],
               flux_x_array[i], -(x+y)*2*x - flux_x_array[i],
               flux_y_array[i], -(x+y)*4*y - flux_y_array[i])
# Plot solution and flux
import scitools.BoxField
import scitools.easyviz as ev
X = 0; Y = 1; Z = 2
# Note: avoid * import from easyviz as DOLFIN and has already
# defined plot, figure, mesh
u2 = u if u.ufl_element().degree() == 1 else \
     interpolate(u, FunctionSpace(mesh, 'Lagrange', 1))
# alternatively: interpolate onto a finer mesh for higher degree elements
u_box = scitools.BoxField.dolfin_function2BoxField(
        u2, mesh, (nx,ny), uniform_mesh=True)
# Write out u at mesh point (i,j)
i = nx; j = ny
print 'u(%g,%g)=%g' % (u_box.grid.coor[X][i],
                       u_box.grid.coor[Y][j],
                       u_box.values[i,j])
ev.contour(u_box.grid.coorv[X], u_box.grid.coorv[Y], u_box.values,
           14, savefig='tmp0.eps', title='Contour plot of u',
           clabels='on')
ev.figure()
ev.surf(u_box.grid.coorv[X], u_box.grid.coorv[Y], u_box.values,
        shading='interp', colorbar='on',
        title='surf plot of u', savefig='tmp3.eps')
ev.figure()
ev.mesh(u_box.grid.coorv[X], u_box.grid.coorv[Y], u_box.values,
        title='mesh plot of u', savefig='tmp4.eps')
# Extract and plot u along the line y=0.5
start = (0,0.5)
x, uval, y_fixed, snapped = u_box.gridline(start, direction=X)
if snapped:
    print 'Line at %s adjusted (snapped) to y=%g' % (start, y_fixed)
ev.figure()
ev.plot(x, uval, 'r-', title='Solution',
        legend='finite element solution')
# Plot the numerical (projected) and exact flux along this line
ev.figure()
flux2_x = flux_x if flux_x.ufl_element().degree() == 1 else \
          interpolate(flux_x, FunctionSpace(mesh, 'Lagrange', 1))
flux_x_box = scitools.BoxField.dolfin_function2BoxField(
        flux2_x, mesh, (nx,ny), uniform_mesh=True)
x, fluxval, y_fixed, snapped = \
        flux_x_box.gridline(start, direction=0)
y = y_fixed
flux_x_exact = -(x + y)*2*x
ev.plot(x, fluxval, 'r-',
        x, flux_x_exact, 'b-',
        legend=('numerical (projected) flux', 'exact flux'),
        title='Flux in x-direction (at y=%g)' % y_fixed,
        savefig='tmp1.eps')
# Plot flux along a line with many points also in the interior of
# the elements
# NOTE (FIXME): Strange artifacts at the end of the line!!!
n = 101
#n = 10
x = numpy.linspace(0, 1, n)
y = numpy.zeros(x.size) + 0.5  # y[i] = 0.5
xy_coor = numpy.array([x, y]).transpose()
#print 'xy_coor:', xy_coor
flux_x_line = numpy.zeros(x.size)
for i in range(len(flux_x_line)):
    flux_x_line[i] = flux_x(xy_coor[i])
flux_x_exact = -(x + y_fixed)*2*x
ev.figure()
ev.plot(x, flux_x_line, 'r-',
        legend=('projected flux evaluated at %d points' % n, 'exact flux'),
        title='Flux at y=%g' % y[0],
        safefig='tmp2.eps')
# Verification
u_e = interpolate(u0, V)
u_e_array = u_e.vector().array()
print 'Max error:', numpy.abs(u_e_array - u_array).max()
#interactive()
raw_input('Press Return: ')  # some curve plot engines need this for a lasting plot on the screen
  1. As you are using discontinous finite elements, the variational form you propose is invalid. See for instance the poisson dg demo.
  2. Running the following in your terminal will give you the documentation of errornorm:
    python3 -c "from dolfin import errornorm; help(errornorm)"
  3. (and 4.) As the FEniCS book was published almost 10 years ago, in 2011, I strongly suggest looking at some of the later tutorials/books published, as the user interface has changed drastically since then.
I would only use the FEniCS book as a reference to easily understand different aspects of the FEM, but not use its code.
Just to add to Dokken, I would recommend using Visual Studio Code (https://code.visualstudio.com/). The python extension module enables you to view the documentation of the function in place and can be quite useful.
This should help you with understanding how to pass command line arguments in your code.
I don’t think this is actively maintained/developed.
The best way I would say is the source directory; see e.g. errornorm. A lot of the unchanged functions can also be looked up in dolfin-2017.2.0 release, though some things would have changed and you should read the change log for those.
Thank you @dokken, @bhaveshshrimali so much for being patient and kind to address my queries.
