Read complex geometry using meshio
Hi everyone,
I’m trying to read in a slightly complex geometry from the following GMSH file, in which i declared only small parts of it as boundary, the rest is my interior:
$MeshFormat
2.2 0 8
$EndMeshFormat
$PhysicalNames
3
2 2 "Neumann"
2 3 "Robin"
3 1 "Volume"
$EndPhysicalNames
$Nodes
2191
1 1.45935 0.948814 -0.69911
2 1.44345 0.948814 -0.69911
3 1.29746 0.23 -0.63
4 1.34746 0.23 -0.68
2190 3.34704 0.23 0.712405
2191 3.36103 0.23 0.742412
$EndNodes
$Elements
7503
1 2 2 3 3 55 60 62
2 2 2 3 3 55 63 60
3 2 2 3 3 63 53 59
4 2 2 3 3 63 59 60
5 2 2 3 3 3 5 55
6 2 2 3 3 5 63 55
7 2 2 3 3 5 6 53
8 2 2 3 3 5 53 63
9 2 2 3 3 75 78 169
10 2 2 3 3 78 234 469
11 2 2 3 3 78 74 77
12 2 2 3 3 77 234 78
13 2 2 3 3 234 77 170
14 2 2 3 3 77 73 170
15 2 2 3 3 169 234 170
16 2 2 3 3 169 170 172
17 2 2 2 2 1620 1621 1622
18 2 2 2 2 1621 1876 1622
19 2 2 2 2 1725 1876 1621
20 4 2 1 1 10 23 1 11
21 4 2 1 1 23 1 11 35
22 4 2 1 1 35 23 1 2
23 4 2 1 1 35 37 23 2
7501 4 2 1 1 2185 2188 2190 2189
7502 4 2 1 1 2187 2185 2190 2186
7503 4 2 1 1 2188 2191 2190 2189
$EndElements
with the following python code
import dolfin as df
pathname = './CarInteriorMesh/'
filename = 'Mesh'  # file to be opened
msh = meshio.read(pathname + filename + '.msh')
meshio.write(pathname + filename + '_xdmf.xdmf',
             meshio.Mesh(points=msh.points,
                             cells={'tetra': msh.cells['tetra']},
                             cell_data={
                                 'tetra': {'name_to_read': msh.cell_data['tetra']['gmsh:physical']}}))
meshio.write(pathname + filename + '_Boundary_xdmf.xdmf',
                         cells={'triangle': msh.cells['triangle']},
                         cell_data={
                            'triangle': {'name_to_read': msh.cell_data['triangle']['gmsh:physical']}}))
mesh = df.Mesh()
with df.XDMFFile(pathname + filename + '_xdmf.xdmf') as infile:
    infile.read(mesh)
mvc = df.MeshValueCollection('size_t', mesh, 3)
with df.XDMFFile(pathname + filename + '_Boundary_xdmf.xdmf') as infile:
    infile.read(mvc, 'name_to_read')
mf = df.cpp.mesh.MeshFunctionSizet(mesh, mvc)
cf = df.cpp.mesh.MeshFunctionSizet(mesh, mvc)
ds_excited = df.Measure('ds', domain=mesh, subdomain_data=mf, subdomain_id=2)
ds_admittance = df.Measure('ds', domain=mesh, subdomain_data=mf, subdomain_id=3)
dx_volume = df.Measure('dx', domain=mesh, subdomain_data=cf, subdomain_id=1)
Edit: The error occurs in
and i get the following error:
*** Error:   Unable to find entity in map.
*** Reason:  Error reading MeshValueCollection.
*** Where:   This error was encountered inside HDF5File.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
I just don’t understand why FEniCS/Dolfin is not able to find an entity, i have declared everything i need in my gmsh-file.
I am able to read other GMSH-generated meshes without problems but this one won’t work.
Thanks in advance, any help is highly appreciated!
For the boundary data, you Need to create a separate MeshValueCollection, with argument 2, instead of 3.
When i write
mesh = df.Mesh()
    infile.read(mesh)
mvc_b = df.MeshValueCollection('size_t', mesh, 2)
    infile.read(mvc_b, 'name_to_read')
mf = df.cpp.mesh.MeshFunctionSizet(mesh, mvc_b)
i still get the same error message
*** Process: 0
Could you supply the full error message, right now this does not tell which line causes the error.
The syntax for reading your mesh and cell/facet functions should be the same as in Complex PDE on GMSH generated mesh
Code:
import dolfin as df
pathname = './Mesh/'
filename = 'Mesh'
dim = 3
                         cell_data={
                         cell_data={
mesh = df.Mesh()
# print(type(mesh))
    infile.read(mesh)
mvc = df.MeshValueCollection('size_t', mesh, dim)
mvc_boundary = df.MeshValueCollection('size_t', mesh, dim - 1)
# mvc.dim()
    infile.read(mvc_boundary, 'name_to_read')  # this is where the error occurs
mf = df.cpp.mesh.MeshFunctionSizet(mesh, mvc_boundary)
Error message:
RuntimeError:
*** Process: 0
*** Git changeset:  473fc681d80577c29aa757c3b36ffec0b3f067e9
Hi again,
even when i’m writing my code like this, i still get the same error message as above (i commented the line where the error occurs).
import dolfin as df
filename = 'Mesh'
dim = 3
                         cell_data={
                         cell_data={
mesh = df.Mesh()
    infile.read(mesh)
mvc = df.MeshValueCollection('size_t', mesh)
mvc_2 = df.MeshValueCollection("size_t", mesh, dim)
    infile.read(mvc_2, 'name_to_read')
df.plot(mesh)
I really don’t understand what i’m doing wrong.
Since you have not supplied the full mesh-file, i really can’t Do anything other than pointing you to your previous thread, Where you were able to load facet and cell functions. Have you tried running that code with both the mesh that that i worked for and the one that you are working on now?
The thing is, that not the whole surface of the mesh is written in the .msh file as you can see here:
$Elements
7503
1 2 2 3 3 55 60 62
2 2 2 3 3 55 63 60
3 2 2 3 3 63 53 59
4 2 2 3 3 63 59 60
5 2 2 3 3 3 5 55
6 2 2 3 3 5 63 55
7 2 2 3 3 5 6 53
8 2 2 3 3 5 53 63
9 2 2 3 3 75 78 169
11 2 2 3 3 78 74 77
$EndElements
As you can see, there are only 19 facet elements out of 7503 total elements, where 7484 elements are volume elements, since i’m not able to generate facet data for the entire geometry.
So basically, only a small part of the boundary is available in the msh file.
May this cause the problem in FEniCS?
Why is that? Your mesh file should contain the full mesh.
I only have the original file as .nas file format with only volume information, but no information of the boundary, when opening the .nas file in the GMSH GUI and saving the file as .msh file format, consequently, there is only volume information available.
I was now trying to find only a few nodes manually on the boundary and mark them with different boundary types in the .msh file.
So it’s not possible to read the mesh in FEniCS correctly if i don’t have the whole boundary as information?
Thank you for your help anyway, i really appreciate it!
I have not worked with nas files myself, so i dont know how They work. However, if you do not have the whole boundary information, i think reading a facet-function will be tricky. I suggest asking the meshio-developers if They know how to handle those files. Or the Gmsh-developers.
OK thank you very much anyway for your help, i will try it like as you said!
Thanks again!
I’m experiencing the same error:
*** Process: 0
*** Git changeset: c5b9b269f4a6455a739109e3a66e036b5b8412f5
Here’s my gmsh geo file:
SetFactory(“OpenCASCADE”);
Circle(1) = {0, 0, 0, 1, 0, 2Pi};
Circle(2) = {0, 0, 0, 0.9, 0, 2
Pi};
Extrude {0, 0, 5} {
Curve{1};
Extrude {0, 0, 5} {
Curve{2};
Curve Loop(3) = {4};
Curve Loop(4) = {6};
Plane Surface(3) = {3, 4};
Curve Loop(5) = {1};
Curve Loop(6) = {2};
Plane Surface(4) = {5, 6};
Surface Loop(1) = {2, 3, 1, 4};
Volume(1) = {1};
Physical Surface(“Bottom”) = {3};
Physical Surface(“Top”) = {4};
Physical Surface(“Inner”) = {2};
Physical Surface(“Outer”) = {1};
Physical Volume(“Main”) = {1};
Physical Surface(“Bottom”) += {3};
Physical Surface(“Inner”) += {4, 2};
Physical Surface(“Outer”) += {1};
I’m using this meshio to read in the msh file as follows:
msh=meshio.read("Pipe.msh")
triangle_cells=[]
tetra_cells=[]
for cell in msh.cells:
    if cell.type == "triangle":
        if len(triangle_cells)==0:
            triangle_cells = cell.data
            triangle_cells = np.vstack([triangle_cells, cell.data])
    elif  cell.type == "tetra":
        if len(tetra_cells)==0:
            tetra_cells = cell.data
            tetra_cells = np.vstack([tetra_cells, cell.data])
    if key == "triangle":
    elif key == "tetra":
        tetra_data = msh.cell_data_dict["gmsh:physical"][key]
triangle_mesh =meshio.Mesh(points=msh.points,
                           cells={"triangle": triangle_cells},
mesh=Mesh()
file_in=XDMFFile("mesh.xdmf")
file_in.read(mesh)
Any suggestions?
For my specific case, the error is caused by the msh file. The geo file that I used contains physical surface groups detached from the volume’s actual surfaces. The error is disappeared with msh generated from the following geo code:
Mesh.Algorithm3D = 4; // 3D mesh algorithm (1=Delaunay, 4=Frontal, 5=Frontal Delaunay, 6=Frontal Hex, 7=MMG3D, 9=R-tree)
SetFactory("OpenCASCADE");
Mesh.CharacteristicLengthMax = 0.5;
Rectangle(1) = {-1, 0, 0, 0.1, 5, 0};
Extrude {{0, 1, 0}, {0, 0, 0}, Pi*2} {
  Curve{3}; Curve{2}; Curve{1}; Curve{4};
Surface Loop(1) = {5, 2, 3, 4};
Volume(1) = {1};
Physical Surface("Bottom") = {2};
Physical Surface("Top") = {4};
Physical Surface("Inner") = {7};
Physical Surface("Outer") = {6};
Physical Volume("Main") = {1};
