Hello everyone,
In Fenics-Dolfin 2019.1.0 version, I wish to plot normed rate of change of a quantity (velocity) versus time. To do so HDF5 files are read which have been saved at particular time intervals and from which the data for velocity and timestamp is extracted.
When I try to obtain the normed rate of change of velocity for different domain sizes using a list domain which contains different domain sizes, I get the following error:
<ipython-input-1-260ec68159e8> in <module>
109 else:
110 tInterval = 'var'
--> 111 T,UDot = getNumSolution(Re,domain,cs,case,typeOfNorm,tInterval)
<ipython-input-1-260ec68159e8> in getNumSolution(Re, domain, cs, case, typeOfNorm, ti)
74 t = []
75 print(i)
---> 76 trimmedFileList,velocity,time = getSortedData(trimmedFileList,filePath)
77 uDot,t = NormOfUDot(velocity,time,typeOfNorm)
78 UDot.append(uDot)
<ipython-input-1-260ec68159e8> in getSortedData(tfl, fp)
37 time = []
38 for i in range(len(tfl)):
---> 39 u,t = readHDF5Files(fp+'/'+tfl[i])
40 velocity.append(u)
41 time.append(t)
<ipython-input-1-260ec68159e8> in readHDF5Files(filePath)
21 f.read(var,"var")
22 time = f.attributes("var/vector_0")['timestamp']
---> 23 u,p,c,q,phi = var.split(True)
24 return u,time
25
/usr/local/lib/python3.6/dist-packages/dolfin/function/function.py in split(self, deepcopy)
538 if num_sub_spaces == 1:
539 raise RuntimeError("No subfunctions to extract")
--> 540 return tuple(self.sub(i, deepcopy) for i in range(num_sub_spaces))
/usr/local/lib/python3.6/dist-packages/dolfin/function/function.py in <genexpr>(.0)
/usr/local/lib/python3.6/dist-packages/dolfin/function/function.py in sub(self, i, deepcopy)
517 if deepcopy:
518 return Function(self.function_space().sub(i),
--> 519 self.cpp_object().sub(i),
520 name='%s-%d' % (str(self), i))
521 else:
RuntimeError: *** Error: Duplication of MPI communicator failed (MPI_Comm_dup
However this works if the list domain has only one entry. How can I obtain data for all domain sizes at once?
Following is my code :
import math
import os
def get_space(mesh):
Q = FiniteElement("Lagrange", mesh.ufl_cell(), 1)
V = VectorElement("Lagrange", mesh.ufl_cell(), 2)
W = FunctionSpace(mesh,MixedElement([V,Q,Q,Q,Q]))
return W
def readHDF5Files(filePath):
mesh = Mesh()
f=HDF5File(mesh.mpi_comm(),filePath, 'r')
f.read(mesh,"mesh",False)
var = Function(get_space(mesh))
f.read(var,"var")
return u,time
def sortData(tfl,v,t):
sv = v
stfl = [x for _,x in sorted(zip(t,tfl))]
sv.sort(key=dict(zip(sv,t)).get)
st = sorted(t)
return stfl,sv,st
def getSortedData(tfl,fp):
velocity = []
time = []
velocity.append(u)
time.append(t)
tfl,velocity,time = sortData(tfl,velocity,time)
return tfl,velocity,time
def NormOfUDot(v,time,typeOfNorm):
normUDotArray = []
timeInstanceArray = []
for i in range(len(v)-1):
u = v[i+1]
old_u = v[i]
t = time[i+1]
old_t = time[i]
normUDot = norm((u.vector()-old_u.vector())/(t-old_t),typeOfNorm)
normUDotArray.append(normUDot)
timeInstanceArray.append(old_t)
return normUDotArray,timeInstanceArray
def getNumSolution(Re,domain,cs,case,typeOfNorm,ti):
UDot = []
T = []
trimmedFileList=[]
for i in domain:
filePath = 'LU_simulations/ref_mesh/'+str(i)+'/Re_'+Re+'_dt_'+ti+'_'+case+'Stat_'+str(cs)
allFiles = os.listdir(filePath+'/')
for jj in range(len(allFiles)):
if allFiles[jj].find('.h5')!=-1:
trimmedFileList.append(allFiles[jj])
uDot = []
t = []
print(i)
UDot.append(uDot)
T.append(t)
return T, UDot
####### Controls ########
Re = '1e-3'
case = 'MT' # For var time step var = mt or st
typeOfNorm = 'L2'
domain = [500,1000,2000,4000,8000]
# domain = [8000]
cs = 5 #fixed
if case == 'MT':
tInterval = '1'
plotTitle = 'Modertately thick limit'
elif case == 'ST':
tInterval = '10'
plotTitle = 'Super thick limit'
tInterval = 'var'
Does this happen because the object var in the function def readHDF5Files(filePath): gets overloaded or crosses a memory threshold? I would highly be grateful for any leads.
