Hello everyone,
I am trying to implement the variable stiffness i.e. change the stiffness after some load step in FEniCS.To implement this, I am using User Expression, it was giving me the error. The same expression without User Expression operation works fine. Please help me to fix the issue, I am new to the FEniCS.
The minimal code is as follow,
from ufl import nabla_div
from ufl import replace
import sys, os, shutil, math
from numpy.linalg import eig
from numpy import array
import time
from ufl import eq
from ufl import le
from ufl import ge
# Define Material Properties
E_1 = 22700. # Young's Modulus
nu_1 = 0.2 # Poisson ratio
mu = E_1/(2.0*(1.0 + nu_1)) #lame's constant
lmbda = (E_1 * nu_1)/((1.0 - 2.0*nu_1)*(1.0 + nu_1)) #lame's constant
# Mesh Data
mesh = Mesh('mesh_Ln5.xml') # Import mesh
ndim = mesh.topology().dim() # Dimension of a geometry
thickness = 50.
# Create function space for 2D elasticity + Damage
V_u = VectorFunctionSpace(mesh, 'CG', 1) # Vector function space for displacement field
# Define the function, test and trial fields (alpha is phase field)
u, du, v = Function(V_u), TrialFunction(V_u), TestFunction(V_u)
u.rename('displacement','displacement')
tol = 1E-5 # Tolerance for boundary identification
tol_v = 1e-20 # Tolerance for square-root calculation
def boundary_D_l(x, on_boundary): # Find bottom edge of specimen
return x[0] >= 54.0 - tol and x[0] <= 56.0 - tol and x[1] <= 0.0 + tol
def boundary_D_r(x, on_boundary): # left lower corner to fix
return x[0] >= 654.0 - tol and x[0] <= 656.0 - tol and x[1] <= 0.0 + tol
def boundary_D_t(x, on_boundary): # Find location of traction/displacement
return x[1] >= 150.0-tol and x[0] >= 354.98-tol and x[0] <= 355.02+tol
bcl = DirichletBC(V_u, Constant((0.0 ,0.0)), boundary_D_l, method='pointwise') # Apply boundary condition
bcr = DirichletBC(V_u.sub(1), Constant(0.0), boundary_D_r, method='pointwise') # Apply boundary condition
# Calculation of positive part of strain
def eps_positive(u):
A = sym(grad(u))
a = A[0,0]
b = A[0,1]
c = A[1,0]
d = A[1,1]
eig_1 = ((tr(A) + sqrt(tr(A)**2-4*det(A) + tol_v))/2) # Evaluation of Eigen value
eig_2 = ((tr(A) - sqrt(tr(A)**2-4*det(A) + tol_v))/2) # Evaluation of Eigen value
phi_1 = (eig_1 - b - d)/(a + c - eig_1)
phi_2 = (eig_2 - b - d)/(a + c - eig_2)
eig_v_1 = [phi_1/sqrt(phi_1**2 + 1), 1/sqrt(phi_1**2 + 1)] # Evaluation of Eigen vector
eig_v_2 = [phi_2/sqrt(phi_2**2 + 1), 1/sqrt(phi_2**2 + 1)] # Evaluation of Eigen vector
# Positive Strain Tensor
sn_P = 0.5*(eig_1 + abs(eig_1))*np.outer(eig_v_1,eig_v_1) + 0.5*(eig_2 + abs(eig_2))*np.outer(eig_v_2,eig_v_2)
sn_1 = as_matrix(sn_P.tolist())
return sn_1
# Calculation of negative part of strain
def eps_negative(u):
A = sym(grad(u))
a = A[0,0]
b = A[0,1]
c = A[1,0]
d = A[1,1]
# Negative Strain Tensor
sn_N = 0.5*(eig_1 - abs(eig_1))*np.outer(eig_v_1,eig_v_1) + 0.5*(eig_2 - abs(eig_2))*np.outer(eig_v_2,eig_v_2)
sn_1 = as_matrix(sn_N.tolist())
return sn_1
def eps(u):
"""Strain tensor as a function of the displacement"""
return sym(grad(u))
# expressions_with variable_stiffness
class el_en_1(UserExpression):
def __init__(self, u_sol, **kwargs):
super().__init__(**kwargs)
self.u_sol = u_sol
def eval(self, value, x):
value = 0.5*lmbda*(0.5*(tr(eps(u_sol)) + abs(tr(eps(u_sol)))))**2 + mu*tr(eps_positive(u_sol)*eps_positive(u_sol))
def value_shape(self):
return (2,)
class el_en_2(UserExpression):
self.u_sol = u_sol
value = 0.5*lmbda*(0.5*(tr(eps(u_sol)) - abs(tr(eps(u_sol)))))**2 + mu*tr(eps_negative(u_sol)*eps_negative(u_sol))
return (2,)
ele_ene_1 = el_en_1(u_sol=u,element = V_u.ufl_element())
ele_ene_2 = el_en_2(u_sol=u,element = V_u.ufl_element())
#print(ele_ene_1.shape)
elastic_energy_1 = ele_ene_1#0.5*lmbda*(0.5*(tr(eps(u)) + abs(tr(eps(u)))))**2 + mu*tr(eps_positive(u)*eps_positive(u)) # Positive part of strain energy density
elastic_energy_2 = ele_ene_2#0.5*lmbda*(0.5*(tr(eps(u)) - abs(tr(eps(u)))))**2 + mu*tr(eps_negative(u)*eps_negative(u)) # negative part of strain energy density
elastic_energy = (elastic_energy_1 + elastic_energy_2)*thickness*dx # total strain energy density (bulk energy density)
total_energy = elastic_energy
# First and second directional derivative wrt u
E_u = derivative(total_energy,u,v) # first directional derivatives of total energy with respect of displacement test function v
Jd = derivative(E_u, u, du)
# define loading steps
num_steps = 200 # total number of load steps
total_disp = -0.2 # total applied displacement
steps_loading = 200
disp_steps = total_disp/(steps_loading)
u_R = Expression(('disp_app'),disp_app = disp_steps, n=0., degree=0) # Define loading as expression so that it can be updated for next step
bct = DirichletBC(V_u.sub(1), u_R, boundary_D_t, method='pointwise') # define boundary condition
bc_disp = [bcl, bcr, bct] # Apply boundary conditions
# Solver for displacement field
problem_u = NonlinearVariationalProblem(E_u, u, bc_disp, Jd)
solver_u = NonlinearVariationalSolver(problem_u)
prm = solver_u.parameters
prm["newton_solver"]["relative_tolerance"] = 5E-1
prm["newton_solver"]["absolute_tolerance"] = 5E-3
prm["newton_solver"]["convergence_criterion"] = "residual"
prm["newton_solver"]["error_on_nonconvergence"] = True
prm["newton_solver"]["linear_solver"] = 'mumps'
prm["newton_solver"]["lu_solver"]["symmetric"] = False
prm["newton_solver"]["maximum_iterations"] = 2000
prm["newton_solver"]["relaxation_parameter"] = 1.0
prm["newton_solver"]["krylov_solver"]["nonzero_initial_guess"] = True
for n in range(num_steps):
u_R.disp_app = disp_steps*(n+1)
solver_u.solve()
The error is as follow,
Thank you
Manish Kumar
