Reproducing Stable and unstable finite elements for the Maxwell eigenvalue problem in Fenicsx
I am trying to reproduce this tutorial about stable and unstable finite elements for Maxwell’s equations in Fenicsx. However, I am struggling with the set up of the SLEPc solver. So far, I have the following MWE, where only the Lagrangian elements are working yet:
from slepc4py import SLEPc
from dolfinx import mesh
from dolfinx.fem import FunctionSpace, VectorFunctionSpace, form, dirichletbc, locate_dofs_geometrical, locate_dofs_topological
from dolfinx.fem.petsc import assemble_matrix
from ufl import FiniteElement, VectorElement, TestFunction, TrialFunction, curl, dot, dx, grad, inner
def eigenvalues(V, bcs):
    a = form(inner(curl(u), curl(v))*dx)
    b = form(inner(u, v)*dx)
    A = assemble_matrix(a, bcs)
    B = assemble_matrix(b, bcs)
    B.assemble()
    # [bc.zero(B) for bc in bcs] # in the fenics tutorial they zero out the corresponding lines, why?
    solver = SLEPc.EPS()
    solver.create()
    solver.setOperators(A, B)
    solver.setProblemType(SLEPc.EPS.ProblemType.GHEP)
    solver.setWhichEigenpairs(SLEPc.EPS.Which.TARGET_MAGNITUDE)
    solver.setTarget(5.5)
    neigs = 12
    solver.setDimensions(nev=neigs, ncv=2*neigs)
    solver.setFromOptions()
    solver.solve()
    print(solver.getConverged())
    # Return the computed eigenvalues in a sorted array
    computed_eigenvalues = []
    for i in range(min(neigs, solver.getConverged())):
        r = solver.getEigenvalue(i)  # ignore the imaginary part
        computed_eigenvalues.append(r)
    return np.sort(np.array(computed_eigenvalues))
ncells = 40
corners = [[0.0, 0.0], [np.pi, np.pi]]
msh = mesh.create_rectangle(MPI.COMM_WORLD, corners, [ncells, ncells])
V = VectorFunctionSpace(msh, ("CG", 1))
# V = FunctionSpace(msh, ("N1curl", 1))
def top(x):
    return np.logical_and(
        np.isclose(x[1], np.pi), x[0] < np.pi
def bottom(x):
        np.isclose(x[1], 0.0), x[0] > 0
def right(x):
        np.isclose(x[0], np.pi), x[1] < np.pi
def left(x):
        np.isclose(x[0], 0.0), x[1] > 0
bd_markers_y = [top, bottom]
bd_markers_x = [left, right]
bcs = []
for bd_marker in bd_markers_y:
    bd_facets = mesh.locate_entities_boundary(msh, msh.topology.dim-1, bd_marker)
    bd_dofs_x = locate_dofs_topological(V.sub(0), msh.topology.dim-1, bd_facets)
    bc = dirichletbc(ScalarType(0), bd_dofs_x, V.sub(0))
    bcs.append(bc)
for bd_marker in bd_markers_x:
    bd_facets = mesh.locate_entities_boundary(msh, msh.topology.dim - 1, bd_marker)
    bd_dofs_y = locate_dofs_topological(V.sub(1), msh.topology.dim - 1, bd_facets)
    bc = dirichletbc(ScalarType(0), bd_dofs_y, V.sub(1))
    bcs.append(bc)
ev = eigenvalues(V, bcs)
print(ev)
More precisely, I have two questions
  1. In the tutorial, the lines corresponding to the BCs in the operator B are zeroed out. How can this be done in Fenicsx?
  2. When I comment out the lines
I get the 12 eigenvalues with the largest magnitude as expected. However, when I include the lines, no eigenvalue converges. What could be the cause of this?
I can only answer this point of your question.
You can set the keyword argument diagonal=0 in assemble_matrix, dolfinx.fem.petsc — DOLFINx 0.5.1 documentation
i.e.
B = assemble_matrix(b, bcs, diagonal=0)
As you have not supplied a reproducible example for the other parts of the code, I cannot really give you any further guidance (i.e. I cannot run your code, as Im missing imports and definitions of variables).
As far as I know, setWhichEigenpairs and setTarget are useful when using spectral transformation in SLEPc, which you are not using here. To do that, add the following lines to your code:
solver.create()
# Add this #
solver.setType(SLEPc.EPS.Type.KRYLOVSCHUR)
st = solver.getST()
st.setType(SLEPc.ST.Type.SINVERT)
neigs = 12
Also, this post may be useful:
I updated this demo here: GitHub - jpdean/maxwell_eigenvalue
@jpdean Quick follow-up question: In the old version, there was the following line
The explanation for it was
We zero out the rows of B
corresponding to constrained boundary degrees of freedom, so as not to introduce spurious eigenpairs with nonzero boundary DOFs.
In your implementation, this translates to
# Zero rows of boundary DOFs of B. See [1]
B = assemble_matrix(b, bcs, diagonal=0.0)
Could you quickly explain, what this does exactly and why it is equivalent?
When assemble_matrix is called on a form where the trial and test spaces are the same, the rows and columns of the degrees of freedom constrained by Dirichlet boundary conditions are zeroed out and, by default, a 1 is placed on the diagonal. This ensures that the constrained degrees of freedom have the correct value when the right hand side vector is modified appropriately (i.e. by apply_lifting and set_bc). Here however, we don’t want ones on the diagonal, so we pass the optional argument diagonal = 0.0 when calling assemble_matrix.
