Rotating cylinder in karman Vortex street
Hello everyone and good day.
I have a code for simulating Karman vortex street (2D) and wanted to give the cylinder a small rotation, So I thought I could give a constant speed to Dirichlet BC of the cylinder face and wanted to know if I could change it like this: bcu_cyl_wall = DirichletBC(V, Constant((0.2, 0.2)), surfaces, cylinder_noslip_tag)
    u_, p_ = Function(V), Function(Q)  # Solve into these
    dt = Constant(solver_params['dt'])
    U  = Constant(0.5)*(u_n + u)
    n  = FacetNormal(mesh)
    f  = Constant((0, 0))
    epsilon = lambda u :sym(nabla_grad(u))
    sigma = lambda u, p: 2*mu*epsilon(u) - p*Identity(2)
    # Define variational problem for step 1
    F1 = (rho*dot((u - u_n) / dt, v)*dx
          + rho*dot(dot(u_n, nabla_grad(u_n)), v)*dx
          + inner(sigma(U, p_n), epsilon(v))*dx
          + dot(p_n*n, v)*ds - dot(mu*nabla_grad(U)*n, v)*ds
          - dot(f, v)*dx)
    a1, L1 = lhs(F1), rhs(F1)
    a2 = dot(nabla_grad(p), nabla_grad(q))*dx
    L2 = dot(nabla_grad(p_n), nabla_grad(q))*dx - (1/dt)*div(u_)*q*dx
    a3 = dot(u, v)*dx
    L3 = dot(u_, v)*dx - dt*dot(nabla_grad(p_ - p_n), v)*dx
    inflow_profile = flow_params['inflow_profile'](mesh, degree=2)
    # Define boundary conditions, first those that are constant in time
    bcu_inlet = DirichletBC(V, inflow_profile, surfaces, inlet_tag)
    # No slip
    bcu_wall = DirichletBC(V, Constant((0, 0)), surfaces, wall_tag)
    # Fixing outflow pressure
    bcp_outflow = DirichletBC(Q, Constant(0), surfaces, outlet_tag)
Thank you and I would be grateful if someone could help me with this too:
