I have successfully solved the coupled 1D wave equation using the backward Euler similar to the examples in the documentation, but my implementation using the Runge-Kutta scheme is giving wrong results - the velocity never gets updated and remains zero and the wave is not propagating as expected.
The formulation is
\begin{eqnarray}
\mathbf{v}_t &=& -\frac{1}{\rho}\nabla p, \\
p_t &=& -\rho c^2\nabla \cdot \mathbf{v},
\end{eqnarray}
where p is the pressure, \mathbf{v} is the velocity, c is the speed of sound and \rho is the density of the medium.
The weak formulation takes the form
\begin{eqnarray}
\int_x \mathbf{v}_t \phi dx &=& -\frac{1}{\rho}\int \nabla p \phi d x \\
\int_\Omega p_t d x &=& -\rho c^2 \left[ \int_\Gamma \phi \mathbf{\hat{n}} \cdot \mathbf{v} ds - \int_\Omega \mathbf{v} \cdot \nabla \phi dx \right]
\end{eqnarray}
The RK4 for a time step \Delta t is given as
\begin{eqnarray}
u_{n+1} = u_{n} + \frac{\Delta t}{6}\left(k_1 + 2k_2 + 2k_3 + k_4 \right)
\end{eqnarray}
where
\begin{eqnarray}
k_1 &=& f(t_n, u_n) \\
k_2 &=& f(t_n + \Delta t/2, u_n + \frac{\Delta t}{2} k_1) \\
k_3 &=& f(t_n + \Delta t/2, u_n + \frac{\Delta t}{2} k_2) \\
k_4 &=& f(t_n + \Delta t, u_n + \Delta t k_3)
\end{eqnarray}
Inspired by Q1 and Firedrake I have implemented a RK4 solver for Neumann BCs where
\begin{eqnarray}
a_p(u,P_p) &=& \int p_t dx \\
a_v(u,P_v) &=& \int v_t dx \\
F_p(u,P_p) &=& -\frac{1}{\rho}\int \nabla p \phi d x \\
F_v(u,P_v) &=& \rho c^2 \int_\Omega \mathbf{v} \cdot \nabla \phi dx,
\end{eqnarray}
which differs from the implicit implementation when using the backward Euler.
I would appreciate if someone could help me figuring out what the problem could be (also, what the purpose of loc_b.set(0) is), the code is listed below:
from dolfinx import fem, mesh
rho = 1.2
c = 343
fmax = 1000
sigma0 = 0.2
ppw = 8
CFL = 0.1
# Define temporal parameters
t = 0 # Start time
T = 20.0/c # Final time
dx = c/fmax/ppw
dt = CFL*dx/c
num_steps = int(np.ceil(T/dt))
# Define mesh
xminmax = [-2,2]
nx = int(np.ceil((xminmax[1]-xminmax[0])/dx))
domain = mesh.create_interval(MPI.COMM_WORLD, nx, xminmax)
xdmf = io.XDMFFile(domain.comm, "wave_equation.xdmf", "w")
xdmf.write_mesh(domain)
P_v = ufl.FiniteElement("CG", domain.ufl_cell(), 1)
P_p = ufl.FiniteElement("CG", domain.ufl_cell(), 1)
element = ufl.MixedElement([P_v, P_p])
ME = fem.FunctionSpace(domain, element)
def initial_condition1D(x, x0=0.0):
return np.exp(-((x[0]-x0)/sigma0)**2)
# Variational problem
du = ufl.TrialFunction(ME)
u = fem.Function(ME)
u.x.array[:] = 0
v,p = u.split()
p.name, v.name = "pressure", "velocity"
p.interpolate(initial_condition1D)
phi = ufl.TestFunction(ME)
phi_v,phi_p = ufl.split(phi)
xdmf.write_function(p, t)
xdmf.write_function(v, t)
# du is change for a timestep defined as the mixed element with dv = du[0] and dp = du[1]
a_p = du[1]*phi_p * ufl.dx # p_t
a_v = du[0]*phi_v * ufl.dx # v_t
a_ = a_v + a_p
# u is the field defined as the mixed element with v = u[0] and p = u[1]
L_p = 1/rho * ufl.grad(u.sub(1))[0] * phi_p * ufl.dx # change in velocity p_t
L_v = -rho*c**2 * u.sub(0) * ufl.grad(phi_v)[0] * ufl.dx # change in pressure v_t
L_ = L_p + L_v
k2, k3, k4 = ufl.TrialFunction(ME), ufl.TrialFunction(ME), ufl.TrialFunction(ME)
u1, u2, u3 = fem.Function(ME), fem.Function(ME), fem.Function(ME)
a_k1 = fem.form(a_)
a_k2 = fem.form(ufl.replace(a_, {du: k2}))
a_k3 = fem.form(ufl.replace(a_, {du: k3}))
a_k4 = fem.form(ufl.replace(a_, {du: k4}))
L_k1 = fem.form(L_)
L_k2 = fem.form(ufl.replace(L_, {u: u1}))
L_k3 = fem.form(ufl.replace(L_, {u: u2}))
L_k4 = fem.form(ufl.replace(L_, {u: u3}))
A1 = fem.petsc.assemble_matrix(a_k1); A1.assemble()
A2 = fem.petsc.assemble_matrix(a_k2); A2.assemble()
A3 = fem.petsc.assemble_matrix(a_k3); A3.assemble()
A4 = fem.petsc.assemble_matrix(a_k4); A4.assemble()
b_k1 = fem.petsc.create_vector(L_k1)
b_k2 = fem.petsc.create_vector(L_k2)
b_k3 = fem.petsc.create_vector(L_k3)
b_k4 = fem.petsc.create_vector(L_k4)
# SOLVER - Using petsc4py to create a linear solver
du = fem.Function(ME) # displacement container for holding temp solutions
# Updating the solution and right hand side per time step
for i in range(num_steps):
# Solve for k1
with b_k1.localForm() as loc_b:
loc_b.set(0)
fem.petsc.assemble_vector(b_k1, L_k1) # Update the right hand side reusing the initial vector
solver.setOperators(A1); solver.solve(b_k1, du.vector) # Solve linear problem
k1 = du.x.array.copy()
u1.x.array[:] = (u.x.array + dt/2*du.x.array).copy() # u1 used for calculating k2
with b_k2.localForm() as loc_b:
loc_b.set(0)
fem.petsc.assemble_vector(b_k2, L_k2)
solver.setOperators(A2); solver.solve(b_k2, du.vector)
k2 = du.x.array.copy()
u2.x.array[:] = (u.x.array + dt/2*du.x.array).copy() # u2 used for calculating k3
with b_k3.localForm() as loc_b:
loc_b.set(0)
fem.petsc.assemble_vector(b_k3, L_k3)
solver.setOperators(A3); solver.solve(b_k3, du.vector)
k3 = du.x.array.copy()
u3.x.array[:] = (u.x.array + dt*du.x.array).copy() # u3 used for calculating k4
with b_k4.localForm() as loc_b:
loc_b.set(0)
fem.petsc.assemble_vector(b_k4, L_k4)
solver.setOperators(A4); solver.solve(b_k4, du.vector)
k4 = du.x.array.copy()
# Update u for time n+1
u.x.array[:] = (u.x.array + dt/6*(k1 + 2*k2 + 2*k3 + k4)).copy()
if i % 25 == 0:
# Write solutions to file
xdmf.write_function(p, t) # p and v are pointers to u
xdmf.write_function(v, t) # p and v are pointers to u
xdmf.close()
