Hi everyone,
I am solving the heat equation with a standard backward euler scheme, but I am getting some very strange results. My equation is
where \rho C_p = 3000000, \kappa = 50, u_{\text{amb}}=300, \beta = 15. I am assuming that the problem is because \rho C_p is so large, because the scheme works when all the coefficients are set to 1. Any insight would be appreciated!
Here is a minimum working example:
from dolfinx.fem import petsc
from ufl import TrialFunction, TestFunction, grad, dx, ds, inner
# material properties
rho_Cp = 3e6 # density * specific heat capacity
kappa = 50 # thermal conductivity
beta = 15 # convection coefficient
def calculate_errors(domain, x):
my_form = fem.form(inner(x, x) * dx)
return np.sqrt(domain.comm.allreduce(fem.assemble_scalar(my_form), op=MPI.SUM))
domain = mesh.create_unit_square(MPI.COMM_WORLD, 100, 100, mesh.CellType.triangle)
# Create initial condition (25 degrees C = approx 300K)
def initial_condition(x):
return 300 + 0*x[0]
u_amb = fem.Function(V, name="u_amb") # ambient temperature
u_amb.interpolate(initial_condition)
u_old = fem.Function(V, name="u_old") # initial temperature
u_old.interpolate(initial_condition)
u_new = fem.Function(V, name="uh") # name of solution function
u_new.interpolate(initial_condition)
# Create boundary condition
tdim = domain.topology.dim
fdim = tdim - 1
boundary_dofs = fem.locate_dofs_topological(V=V, entity_dim=1, entities=boundary_facets)
# writing the function to an xdmf file
xdmf_t = io.XDMFFile(domain.comm, "temperature.xdmf", "w", encoding=io.XDMFFile.Encoding.ASCII)
xdmf_t.write_mesh(domain)
xdmf_t.write_function(u_new, 0)
# Define temporal parameters (seconds)
t = 0 # Start time
T = 0.1 # Final time
num_steps = 10
tol = 1e-6
max_iterations = 100
for i in range(num_steps):
a = (rho_Cp * inner(u, v) * dx
+ dt * kappa * inner(grad(u), grad(v)) * dx
+ dt * beta * inner(u, v) * ds
L = (rho_Cp * inner(u_old, v) * dx + dt * beta * inner(u_amb, v) * ds
problem = petsc.LinearProblem(a, L)
u_new = problem.solve()
u_new.name = "uh"
u_old = u_new # Update solution at previous time step (u_n)
xdmf_t.write_function(u_new, t)
xdmf_t.close()
and I get this result
which shows some strange oscillations in the bottom right hand corner.
Please do let me know if you have any insight into why this is happening!
Many thanks,
Katie
