I am getting the following error:
IndexError: Values to set must be a 1D array
The lines of code causing the error are these ones:
self.Vect = VectorFunctionSpace(mesh, ‘P’, 1)
q_function = Function(self.Vect)
q_function.vector()[:] = q
Isn’t it possible to use .vector()[:] with 2D arrays?
please read Read before posting: How do I get my question answered? . The code you provide is not reproducible, and not correctly formatted.
In general, the answer to
is no. It would be good to clarify why you would want it to be a 2D array. Is it because you interpret the first column of the 2D array is the first component of q, and the second column is the second component?
Yes, I want the first column of the 2D array to be the first component of q, and the second column to be the second component. Here is a MWE:
width = 1000 # Width of the mesh (um)
height = 1000 # Height of the mesh (um)
c_0 = 1.4e-05
dt = 0.1
dt_environment = 1
t = 0.0
mesh = RectangleMesh(Point(0, 0), Point(width,height), 10, 10)
W_D1 = FunctionSpace(mesh, 'P', 1)
Vect = VectorFunctionSpace(mesh, 'P', 1)
v = TestFunction(W_D1)
u = Function(W_D1)
u_old = Function(W_D1)
u_initial= f"{c_0}"
u_aux = Expression(u_initial,degree=1, L = width)
u_0 = interpolate(u_aux, W_D1)
u.assign(u_0)
u_old.assign(u_0)
q = np.zeros([mesh.num_vertices(),2])
for vertex in vertices(mesh):
q[vertex_to_dof_map(W_D1)[vertex.index()],:] = np.random.uniform()
q_function = Function(Vect)
# q_function.vector()[:] = q
q_function = project(q,Vect)
F_D1 = (
inner(u - u_old, v) * dx
+ dt * q_function * grad(v) * dx
# Solver
for time in np.arange(0, dt_environment, dt):
set_log_level(30)
solver_parameters = {
"newton_solver": {
"linear_solver": "gmres",
"preconditioner": "ilu",
"maximum_iterations": 1000,
"relaxation_parameter": 0.7,
"relative_tolerance": 1e-7,
"absolute_tolerance": 1e-8
solve(F_D1 == 0, u, solver_parameters=solver_parameters)
u.vector()[:] = np.maximum(u.vector().get_local(), 0)
u_old.assign(u)
dokken
August 25, 2024, 5:26pm
4
Consider the following approach:
mesh = RectangleMesh(Point(0, 0), Point(width, height), 10, 10)
Vect = VectorFunctionSpace(mesh, "P", 1)
u = Function(Vect)
u1 = u.sub(1, deepcopy=True)
print(u1.vector().get_local())
# Modify u1
u1.vector()[:] = 2
# Create assigner from u1 to u
assigner = FunctionAssigner(Vect.sub(1), u1.function_space())
assigner.assign(u.sub(1), u1)
# Assign to u
print(u.vector().get_local())
File("u.pvd") << u
