Seg error with Netwon Solverq
I am trying to solve the tutorial problem of
“Flow past a cylinder (DFG 2D-3 benchmark)”
using Newton solver to get solution of steady state Navier Stokes equation.
But I am getting segmentation error upon invoking the solve function.
The geometry generation is same as the tutorial i.e.
# # Modified
# the Test problem 2: Flow past a cylinder (DFG 2D-3 benchmark)  by Jørgen S. Dokken
# to solve steady state by Newtons iteration
import os
import tqdm.autonotebook
from basix.ufl import (element,mixed_element)
from dolfinx.io import (gmshio)
from dolfinx.fem import (Constant, Function, functionspace,dirichletbc,locate_dofs_topological,form)
from ufl import (TestFunction,TestFunctions, TrialFunction,split,div, dot, ds, dx, inner, grad, nabla_grad)
from dolfinx.cpp.mesh import to_type, cell_entity_type
                               create_vector, create_matrix, set_bc)
from dolfinx.graph import adjacencylist
from dolfinx.geometry import bb_tree, compute_collisions_points, compute_colliding_cells
from dolfinx.io import (VTXWriter, distribute_entity_data, gmshio)
from dolfinx.mesh import create_mesh, meshtags_from_entities
 #for nonlinear solution
from dolfinx import log
L = 2.2
H = 0.41
c_x = c_y = 0.2
r = 0.05
gdim = 2
mesh_comm = MPI.COMM_WORLD
model_rank = 0
    rectangle = gmsh.model.occ.addRectangle(0, 0, 0, L, H, tag=1)
    obstacle = gmsh.model.occ.addDisk(c_x, c_y, 0, r, r)
# The next step is to subtract the obstacle from the channel, such that we do not mesh the interior of the circle.
    fluid = gmsh.model.occ.cut([(gdim, rectangle)], [(gdim, obstacle)])
    gmsh.model.occ.synchronize()
# To get GMSH to mesh the fluid, we add a physical volume marker
fluid_marker = 1
    assert (len(volumes) == 1)
    gmsh.model.addPhysicalGroup(volumes[0][0], [volumes[0][1]], fluid_marker)
    gmsh.model.setPhysicalName(volumes[0][0], fluid_marker, "Fluid")
# To tag the different surfaces of the mesh, we tag the inflow (left hand side) with marker 2, the outflow (right hand side) with marker 3 and the fluid walls with 4 and obstacle with 5. We will do this by computing the center of mass for each geometrical entity.
inlet_marker, outlet_marker, wall_marker, obstacle_marker = 2, 3, 4, 5
inflow, outflow, walls, obstacle = [], [], [], []
    for boundary in boundaries:
        if np.allclose(center_of_mass, [0, H / 2, 0]):
            inflow.append(boundary[1])
        elif np.allclose(center_of_mass, [L, H / 2, 0]):
            outflow.append(boundary[1])
        elif np.allclose(center_of_mass, [L / 2, H, 0]) or np.allclose(center_of_mass, [L / 2, 0, 0]):
            walls.append(boundary[1])
            obstacle.append(boundary[1])
    gmsh.model.setPhysicalName(1, inlet_marker, "Inlet")
    gmsh.model.addPhysicalGroup(1, outflow, outlet_marker)
    gmsh.model.setPhysicalName(1, outlet_marker, "Outlet")
    gmsh.model.addPhysicalGroup(1, obstacle, obstacle_marker)
    gmsh.model.setPhysicalName(1, obstacle_marker, "Obstacle")
# In our previous meshes, we have used uniform mesh sizes. In this example, we will have variable mesh sizes to resolve the flow solution in the area of interest; close to the circular obstacle. To do this, we use GMSH Fields.
# Create distance field from obstacle.
# Add threshold of mesh sizes based on the distance field
# LcMax -                  /--------
# LcMin -o---------/
#       Point    DistMin DistMax
res_min = r / 3
    distance_field = gmsh.model.mesh.field.add("Distance")
    gmsh.model.mesh.field.setNumbers(distance_field, "EdgesList", obstacle)
    threshold_field = gmsh.model.mesh.field.add("Threshold")
    gmsh.model.mesh.field.setNumber(threshold_field, "IField", distance_field)
    gmsh.model.mesh.field.setNumber(threshold_field, "LcMin", res_min)
    gmsh.model.mesh.field.setNumber(threshold_field, "LcMax", 0.25 * H)
    gmsh.model.mesh.field.setNumber(threshold_field, "DistMin", r)
    gmsh.model.mesh.field.setNumber(threshold_field, "DistMax", 2 * H)
    min_field = gmsh.model.mesh.field.add("Min")
    gmsh.model.mesh.field.setNumbers(min_field, "FieldsList", [threshold_field])
    gmsh.model.mesh.field.setAsBackgroundMesh(min_field)
# ## Generating the mesh
# We are now ready to generate the mesh. However, we have to decide if our mesh should consist of triangles or quadrilaterals. In this demo, to match the DFG 2D-3 benchmark, we use second order quadrilateral elements.
    gmsh.option.setNumber("Mesh.Algorithm", 8)
    gmsh.option.setNumber("Mesh.RecombinationAlgorithm", 2)
    gmsh.option.setNumber("Mesh.RecombineAll", 1)
    gmsh.option.setNumber("Mesh.SubdivisionAlgorithm", 1)
    gmsh.model.mesh.setOrder(2)
# ## Loading mesh and boundary markers
# As we have generated the mesh, we now need to load the mesh and corresponding facet markers into DOLFINx.
# To load the mesh, we follow the same structure as in [Deflection of a membrane](./../chapter1/membrane_code.ipynb), with the difference being that we will load in facet markers as well. To learn more about the specifics of the function below, see [A GMSH tutorial for DOLFINx](https://jsdokken.com/src/tutorial_gmsh.html).
mesh, _, ft = gmshio.model_to_mesh(gmsh.model, mesh_comm, model_rank, gdim=gdim)
ft.name = "Facet markers"
# ## Physical and discretization parameters
# Following the DGF-2 benchmark, we define our problem specific parameters
mu = Constant(mesh, PETSc.ScalarType(0.001))  # Dynamic viscosity
rho = Constant(mesh, PETSc.ScalarType(1))     # Density
##### Added boundary conditions and Newton solver to solve steady state equations
# Domain
gdim = 2
model_rank=0
#mesh, _, ft =gmshio.read_from_msh("cylinder.msh", mesh_comm, model_rank, gdim)
mesh=mesh
ft=ft
fdim = mesh.topology.dim - 1
# Functional Spaces
P2 = element("Lagrange", mesh.topology.cell_name(), 2,shape=(mesh.geometry.dim, ))
P1=s_cg1 = element("Lagrange", mesh.topology.cell_name(), 1)
mixEl = mixed_element([P2, P1])
#combined space
W = functionspace(mesh, mixEl)
# Test and trial functions: monolithic
(v, q) = TestFunctions(W)
dup = TrialFunction(W)
up  = Function(W)
(u, p) = split(up)
# Computing the viscosity
Re=20
InvReNo=1.0/Re
InvRe=Constant(mesh, PETSc.ScalarType(InvReNo))
print('Re = ',format(Re) )
until here the code is almost same as tutorial. I just added different boundary conditions and solution method using Newton solver as follows:
# Setting Boundary Conditions
##nonslip on obstacles. no penetration at walls normal gradient of velocity at wall and outlet is zero
##pressure is zero at outlet
# inlet velocity is uniform and =(1,0)
#(**markers**)
#inlet
u_inlet=np.array([1.0,0.0], dtype=PETSc.ScalarType)
dofs_inlet=locate_dofs_topological(W.sub(0), fdim, ft.find(inlet_marker))
bcu_inflow = dirichletbc(u_inlet,dofs_inlet ,W.sub(0).collapse()[0])
# Walls
u_nonslip = np.array((0,) * mesh.geometry.dim, dtype=PETSc.ScalarType)
dofs_walls=locate_dofs_topological(W.sub(0), fdim, ft.find(wall_marker))
bcu_walls = dirichletbc(u_nonslip, dofs_walls, W.sub(0).collapse()[0])
# Obstacle
dofs_obstacle=locate_dofs_topological(W.sub(0), fdim, ft.find(obstacle_marker))
bcu_obstacle = dirichletbc(u_nonslip, dofs_obstacle, W.sub(0).collapse()[0])
# Outlet pressure bc
dofs_out=locate_dofs_topological(W.sub(1), fdim, ft.find(outlet_marker))
bcp_outlet = dirichletbc(PETSc.ScalarType(0), dofs_out, W.sub(1).collapse()[0])
#combined bc
bcs1=[bcu_inflow, bcu_obstacle, bcu_walls, bcp_outlet ]
# Variational forms
F = dot(dot(u, nabla_grad(u)), v) * dx
+InvRe*inner(grad(u),grad(v)) * dx   #diffussion term
- div(v)*p * dx  #pressure grad term
+q*div(u) * dx ##continuity equation
_F = form(F)
# Solver settings
problem = NonlinearProblem(F, up, bcs=bcs1)
solver.rtol = 1e-3
solver.atol= 1e-3
solver.report = True
# We can modify the linear solver in each Newton iteration by accessing the underlying `PETSc` object.
ksp = solver.krylov_solver
opts = PETSc.Options()
ksp.setFromOptions()
# We are now ready to solve the non-linear problem. We assert that the solver has converged and print the number of iterations.
n, converged = solver.solve(up)
assert (converged)
Any help regarding this is appreciated
Why are you collapsing the latter space? it shouldn’t be collapsed:
bcu_inflow = dirichletbc(u_inlet,dofs_inlet ,W.sub(0))
Similar comments holds for bc_walls, bcu_obstacle and bcp_outlet
Secondly, you should try changing one thing at the time, i.e first change bcs and keep Newton solver fixed, then check that it works, then change the solver.
