Should `basix' load `dolfinx`by default?
Hello.
Description of the issue
The Python API of Basix fails when trying to access basix.ufl if DOLFINx is not loaded.
Expected result
I would not have expected Basix to depend on DOLFINx to work with UFL. If that is the case, may be Basix should load DOLFINx by default.
MWE
import basix
# import dolfinx   # uncomment to fix error
basix.ufl
Error output
  File "<stdin>", line 6, in <module>
AttributeError: module 'basix' has no attribute 'ufl'
System
  • FEniCSx software
    dolfinx: 0.8.0.dev0_r27568.a34b0c9-1
    basix: 0.8.0.dev0_r952.eebbc52-1
    ufl: 2023.3.0.dev0_r3568.f132188-1
    ffcx: 0.8.0.dev0_r7083.b4cb217-1
  • Dependencies
    python: 3.11.5-2
    python-numpy: 1.26.0-1
    petsc: 3.19.5.1171.g37df9106526-1
    hdf5-openmpi: 1.14.2-1
    boost: 1.83.0-2
    adios2: 2.8.3-5
    scotch: 7.0.4-1
    pybind11: 2.11.1-1
    python-build: 1.0.1-1
    python-cffi: 1.15.1-4
    python-cppimport: 22.08.02.r6.g0849d17-1
    python-installer: 0.7.0-3
    python-mpi4py: 3.1.4-3
    python-pytest: 7.4.2-1
    python-scikit-build: 0.17.6-1
    python-setuptools: 1:68.0.0-1
    python-wheel: 0.40.0-3
    xtensor: 0.24.0-2
    xtensor-blas: 0.20.0-1
  • Operating system
    Arch Linux: 6.5.4-arch2-1
basix.ufl is an optional submodule of Basix.
You should import it explicitly through import basix.ufl
