Von Mises Plasticity in FEniCS
Hello All,
I am trying to do an analysis similar to the analysis done here: Elasto-plastic analysis of a 2D von Mises material — Numerical tours of continuum mechanics using FEniCS master documentation
I have made adjustments to the geometry and boundary conditions without applying any external force. However, there is a nonzero prescribed vertical displacement at the top side, and the analysis is running with very high residuals. Despite my efforts, I have been unable to resolve this issue. Any guidance or advice would be greatly appreciated.
parameters["form_compiler"]["representation"] = 'quadrature'
import warnings
from ffc.quadrature.deprecation import QuadratureRepresentationDeprecationWarning
warnings.simplefilter("once", QuadratureRepresentationDeprecationWarning)
E = Constant(70e3)
nu = Constant(0.3)
lmbda = E*nu/(1+nu)/(1-2*nu)
mu = E/2./(1+nu)
sig0 = Constant(250.)  # yield strength
Et = E/100.  # tangent modulus
H = E*Et/(E-Et)  # hardening modulus
mesh = UnitSquareMesh(50, 50)
# plot(mesh)
def left_right_boundary(x, on_boundary):
    return (near(x[0], 0) or near(x[0], 1)) and on_boundary
def top_boundary(x, on_boundary):
    return near(x[1], 1) and on_boundary
def bottom_boundary(x, on_boundary):
    return near(x[1], 0) and on_boundary
# Function spaces
deg_u = 2
deg_stress = 2
V = VectorFunctionSpace(mesh, "CG", deg_u)
We = VectorElement("Quadrature", mesh.ufl_cell(), degree=deg_stress, dim=4, quad_scheme='default')
W = FunctionSpace(mesh, We)
W0e = FiniteElement("Quadrature", mesh.ufl_cell(), degree=deg_stress, quad_scheme='default')
W0 = FunctionSpace(mesh, W0e)
sig = Function(W)
sig_old = Function(W)
n_elas = Function(W)
beta = Function(W0)
p = Function(W0, name="Cumulative plastic strain")
u = Function(V, name="Total displacement")
du = Function(V, name="Iteration correction")
Du = Function(V, name="Current increment")
v = TrialFunction(V)
u_ = TestFunction(V)
# Boundary conditions
bc_top = DirichletBC(V.sub(1), 0.03, top_boundary)  # Initial displacement is 0.03
bc_bottom = DirichletBC(V.sub(1), 0, bottom_boundary)
bc_left_right = DirichletBC(V.sub(1), 0, left_right_boundary)
bc = [bc_top, bc_bottom, bc_left_right]
def eps(v):
    e = sym(grad(v))
    return as_tensor([[e[0, 0], e[0, 1], 0],
                      [e[0, 1], e[1, 1], 0],
                      [0, 0, 0]])
def sigma(eps_el):
    return lmbda*tr(eps_el)*Identity(3) + 2*mu*eps_el
def as_3D_tensor(X):
    return as_tensor([[X[0], X[3], 0],
                      [X[3], X[1], 0],
                      [0, 0, X[2]]])
ppos = lambda x: (x+abs(x))/2.
def proj_sig(deps, old_sig, old_p):
    sig_n = as_3D_tensor(old_sig)
    sig_elas = sig_n + sigma(deps)
    s = dev(sig_elas)
    sig_eq = sqrt(3/2.*inner(s, s))
    f_elas = sig_eq - sig0 - H*old_p
    dp = ppos(f_elas)/(3*mu+H)
    n_elas = s/sig_eq*ppos(f_elas)/f_elas
    beta = 3*mu*dp/sig_eq
    new_sig = sig_elas-beta*s
    return as_vector([new_sig[0, 0], new_sig[1, 1], new_sig[2, 2], new_sig[0, 1]]), \
           as_vector([n_elas[0, 0], n_elas[1, 1], n_elas[2, 2], n_elas[0, 1]]), \
           beta, dp
def sigma_tang(e):
    N_elas = as_3D_tensor(n_elas)
    return sigma(e) - 3*mu*(3*mu/(3*mu+H)-beta)*inner(N_elas, e)*N_elas-2*mu*beta*dev(e)
metadata = {"quadrature_degree": deg_stress, "quadrature_scheme": "default"}
dxm = dx(metadata=metadata)
a_Newton = inner(eps(v), sigma_tang(eps(u_)))*dxm
res = -inner(eps(u_), as_3D_tensor(sig))*dxm
    dv = TrialFunction(V)
    v_ = TestFunction(V)
    a_proj = inner(dv, v_)*dxm
    b_proj = inner(v, v_)*dxm
    solver.factorize()
    if u is None:
        solver.solve_local_rhs(u)
        return u
        return
file_results = XDMFFile("plasticity_results.xdmf")
P0 = FunctionSpace(mesh, "DG", 0)
p_avg = Function(P0, name="Plastic strain")
# Incremental vertical displacement applied to the top boundary
Nitermax, tol = 200, 1e-8  # parameters of the Newton-Raphson procedure
Nincr = 50
disp_increments = np.linspace(0, 0.03, Nincr+1)[1:]
results = np.zeros((Nincr+1, 2))
for (i, d) in enumerate(disp_increments):
    bc_top = DirichletBC(V.sub(1), d, top_boundary)
    # Rest of the Newton-Raphson procedure
    A, Res = assemble_system(a_Newton, res, bc)
    nRes0 = Res.norm("l2")
    nRes = nRes0
    Du.interpolate(Constant((0, 0)))
    print("Increment:", str(i+1))
    niter = 0
    while nRes/nRes0 > tol and niter < Nitermax:
        solve(A, du.vector(), Res, "mumps")
        Du.assign(Du+du)
        deps = eps(Du)
        sig_, n_elas_, beta_, dp_ = proj_sig(deps, sig_old, p)
        local_project(sig_, W, sig)
        local_project(n_elas_, W, n_elas)
        local_project(beta_, W0, beta)
        nRes = Res.norm("l2")
        print("    Residual:", nRes)
        niter += 1
    u.assign(u+Du)
    p.assign(p+local_project(dp_, W0))
    sig_old.assign(sig)
    # Record results
    file_results.write(u, d)
    p_avg.assign(project(p, P0))
    file_results.write(p_avg, d)
