I am trying to solve a PDE on a subdomain without creating a submesh because of the potential overhead. For this task I am using the multiphenicsx library. I assemble my matrix using multiphenicsx.fem.petsc.assemble_matrix with a degree of freedom restriction map and upon calling ksp.setOperators(matrix), I get a null pointer error. Here is a MWE where I try to solve a Laplace equation on the left side of the unit square:
from dolfinx import io, fem, mesh, cpp
import multiphenicsx
import multiphenicsx.fem.petsc
import petsc4py.PETSc
def exact_sol(x):
return 2 -(x[0]**2 + x[1]**2)
def rhs():
return 4
def main():
# BACKGROUND MESH
nels_side = 2
bg_mesh = mesh.create_unit_square(MPI.COMM_WORLD, nels_side, nels_side, mesh.CellType.quadrilateral)
cdim = bg_mesh.topology.dim
fdim = cdim - 1
# SOLUTION SPACES
Vbg = fem.functionspace(bg_mesh, ("Lagrange", 1),)
dg0bg = fem.functionspace(bg_mesh, ("Discontinuous Lagrange", 0),)
Vactive = Vbg.clone()
active_dofs = fem.locate_dofs_geometrical(Vactive, lambda x : x[0] <= 0.5)
active_els = np.array(fem.locate_dofs_geometrical(dg0bg, lambda x : x[0] <= 0.5), dtype=np.int32)
restriction = multiphenicsx.fem.DofMapRestriction(Vactive.dofmap, active_dofs)
active_els_tag = mesh.meshtags(bg_mesh, cdim,
active_els,
np.ones(active_els.shape, dtype=np.int32) )
# LOCATE ACTIVE BOUNDARY
bfacets = []
bg_mesh.topology.create_connectivity(fdim, cdim)
con_facet_cell = bg_mesh.topology.connectivity(1, 2)
for ifacet in range(con_facet_cell.num_nodes):
local_con = con_facet_cell.links(ifacet)
incident_active_els = 0
for el in local_con:
if el in active_els:
incident_active_els += 1
if (incident_active_els==1):
bfacets.append(ifacet)
bdofs = fem.locate_dofs_topological(Vactive, fdim, bfacets,)
# BC
u_bc = fem.Function(Vactive)
u_bc.interpolate(exact_sol)
bc = fem.dirichletbc(u_bc, bdofs)
# FORMS
dx = ufl.Measure("dx")(subdomain_data=active_els_tag)
(u, v) = (ufl.TrialFunction(Vactive),ufl.TestFunction(Vactive))
a = ufl.inner(ufl.grad(u), ufl.grad(v))*dx
l = rhs()*v*dx
a_cpp = fem.form(a)
l_cpp = fem.form(l)
A = multiphenicsx.fem.petsc.assemble_matrix(a_cpp,
bcs=[bc],
restriction=(restriction, restriction))
L = multiphenicsx.fem.petsc.assemble_vector(l_cpp,
restriction=restriction,)
# SOLVE
u = multiphenicsx.fem.petsc.create_vector(l_cpp, restriction=restriction)
ksp = petsc4py.PETSc.KSP()
ksp.setOperators(A)
ksp.setType("preonly")
ksp.getPC().setType("lu")
ksp.getPC().setFactorSolverType("mumps")
ksp.setFromOptions()
ksp.solve(L, u)
u.ghostUpdate(addv=petsc4py.PETSc.InsertMode.INSERT, mode=petsc4py.PETSc.ScatterMode.FORWARD)
ksp.destroy()
if __name__=="__main__":
main()
I get:
petsc4py.PETSc.Error: error code 85
[0] KSPSetOperators() at /usr/local/petsc/src/ksp/ksp/interface/itcreate.c:509
[0] Null argument, when expecting valid pointer
using the latest versions of dolfinx and multiphenicsx on the fenicsx development docker container. I would appreciate any help from @francesco-ballarin or anyone else in finding a potential bug.
PS: I could not find dolfinx.mesh.create_submesh in the documentation website.
