Hi, everyone!
This is what I wrote with fenicsx to solve the three-dimensional unsteady convection-diffusion equation, but the convergence order I obtained has always been incorrect.
But after I annotated the diffusion term, the model became a thermal equation, and the convergence order obtained was reasonable. Could you please help me figure out where the problem lies?
from dolfinx import mesh, fem
from dolfinx.fem.petsc import assemble_matrix, assemble_vector, apply_lifting, create_vector, set_bc
import time
from ufl import ds, dx, grad, inner, sin, cos, pi, exp, dot
# 精确解
def ExactRho(x,t):
factor = np.exp(-t) + 1.0
return factor * (x[0]**2 - x[0]) * (x[1]**2 - x[1]) * (x[2]**2 - x[2])
def ExactU(x,t):
temp1=factor * np.sin(np.pi * x[0]) * np.sin(np.pi * x[1]) * np.sin(np.pi * x[2])
temp2=np.zeros_like(x[0])
temp3=factor * (x[2]**2 - x[2]) * np.sin(np.pi * x[1]) * np.sin(np.pi * x[2])
return [temp1,temp2,temp3]
def rhs_expr(x, t, D1):
exp_term = np.exp(-t)
factor = exp_term + 1.0
return -exp_term*(x[0]**2 - x[0]) * (x[1]**2 - x[1]) * (x[2]**2 - x[2]) \
-D1*factor*(2*((x[1]**2 - x[1]) * (x[2]**2 - x[2])+(x[0]**2 - x[0])* (x[2]**2 - x[2])+(x[0]**2 - x[0]) * (x[1]**2 - x[1])))\
+factor**2*((x[1]**2 - x[1]) * (x[2]**2 - x[2])*((2*x[0]-1.0)*np.sin(np.pi*x[0])+np.pi*(x[0]**2 - x[0])*np.cos(np.pi*x[0]))*np.sin(np.pi*x[1])*np.sin(np.pi*x[2]))\
+factor**2*((x[0]**2 - x[0]) * (x[1]**2 - x[1])*2*(x[2]**2 - x[2])*(2*x[2]-1)*np.sin(np.pi*x[0])*np.sin(np.pi*x[1]))
# 固定终止时间
T = 1.0
# 结果记录
hs = []
errors_L2 = []
errors_max = []
start_time = time.time()
for i in range(3):
n = 2 ** (i + 2) # 空间划分数 n = 2^{i+2}
h = 1.0 / n
num_steps = 2 ** (2 * i + 4) # 时间划分数 tau = 2^{2i+4}
dt = T / num_steps
D1 = dt**2
t = 0.0
# 创建 3D 网格(单位立方体)
domain = mesh.create_unit_cube(MPI.COMM_WORLD, n, n, n, mesh.CellType.tetrahedron)
V = fem.functionspace(domain, ("Lagrange", 1)) # 线性 Lagrange 元
Vv=fem.functionspace(domain, ("Lagrange", 1, (3, )))
rho_n = fem.Function(V)
rho_n.interpolate(lambda x: ExactRho(x, t))
rho_D = fem.Function(V)
rho_D.interpolate(lambda x: ExactRho(x, t))
u_old = fem.Function(Vv)
u_old.interpolate(lambda x: ExactU(x, t))
f_fun = fem.Function(V)
# 施加 Dirichlet 边界条件(3D 边界)
tdim = domain.topology.dim
fdim = tdim - 1
bc = fem.dirichletbc(rho_D, fem.locate_dofs_topological(V, fdim, boundary_facets))
# 变分形式(3D 形式相同,但 dx 现在是 3D 积分)
rho, w = ufl.TrialFunction(V), ufl.TestFunction(V)
# a_form = (rho * w + dt * D1 * dot(grad(rho), grad(w))) * dx- dt* rho * dot(u_old, grad(w))* dx
F1 = (rho * w + dt * D1 * dot(grad(rho), grad(w))) * dx- dt * rho * dot(u_old, grad(w))* dx
F2 = rho_n * w* dx + dt *f_fun* w * dx
a = fem.form(F1)
L = fem.form(F2)
# 组装矩阵和向量
A = assemble_matrix(a, bcs=[bc])
b = create_vector(L)
rho_h = fem.Function(V)
# 定义求解器(直接法:LU 分解)
solver.setOperators(A)
# 时间步进
for n_step in range(num_steps):
f_fun.interpolate(lambda x: rhs_expr(x, t, D1))
# 更新矩阵
A.zeroEntries()
assemble_matrix(A, a, bcs=[bc])
# 重新组装右端向量
with b.localForm() as loc_b:
loc_b.set(0)
assemble_vector(b, L)
# 施加边界条件
apply_lifting(b, [a], [[bc]])
set_bc(b, [bc])
# 求解线性系统
solver.solve(b, rho_h.x.petsc_vec)
rho_h.x.scatter_forward()
# 更新 u_n
rho_n.x.array[:] = rho_h.x.array
# 计算误差(在更高阶空间)
V_ex = fem.functionspace(domain, ("Lagrange", 2))
rho_ex = fem.Function(V_ex)
rho_ex.interpolate(lambda x: ExactRho(x,T))
# L2 误差
error_L2 = np.sqrt(domain.comm.allreduce(fem.assemble_scalar(fem.form((rho_h - rho_ex)**2 * ufl.dx)), op=MPI.SUM))
if MPI.COMM_WORLD.rank == 0:
hs.append(h)
errors_L2.append(error_L2)
print(f"[i={i}] n={n}, num_steps={num_steps}, dt={dt:.3e}, h={h:.3e}")
print(f" → L2 error = {error_L2:.3e}")
end_time = time.time() # 计时结束
elapsed = end_time - start_time
# 输出收敛阶
print("\nEstimated convergence rates (L2):")
for j in range(1, len(hs)):
r = np.log(errors_L2[j-1]/errors_L2[j]) / np.log(hs[j-1]/hs[j])
print(f"h={hs[j-1]:.3e} → h={hs[j]:.3e}, rate ≈ {r:.2f}")
print(f"\nTotal runtime: {elapsed:.2f} seconds")
