Can FEniCS solve electromagentic question on 3D model
As the title, if it can do it, is there any example for referenc?
Thanks a lot!
Of course. Consider
which can all be extended to 3D by selecting an appropriate mesh.
You can also consider GitHub - Wells-Group/TEAM30: A repository for the TEAM-30 benchmark using DOLFINx for induction motors: https://www.compumag.org/jsite/images/stories/TEAM/problem30a.pdf
Thank you for your quick help!
Witch one of them is more similar with ‘phased array radar antenna’ model?
Thank you!
I wanna double check whether FEniCS can be applied to ‘phased array radar antenna’ model?
I don’t know that problem.
FEniCS is a general Finite Element solver, using a domain specific language.
So if you can formulate the variational form, you can usually implement it in FEniCS.
I would also suggest looking at papers by other people, say:
https://www.researchgate.net/profile/George-Slade-2/publication/348920225_Basics_of_Antenna_Modeling_with_FEniCS_Finite_Element_Suite/links/64521542809a5350214692ca/Basics-of-Antenna-Modeling-with-FEniCS-Finite-Element-Suite.pdf
https://onlinelibrary.wiley.com/doi/pdf/10.1002/mop.33039
https://www.researchgate.net/profile/Morteza-Ghaderi-Aram/publication/370210963_Differential_Least-Square_Microwave_Thermometry_A_Feasibility_Study_on_a_Realistic_Patient_Model/links/644573bf8ac1946c7a46d098/Differential-Least-Square-Microwave-Thermometry-A-Feasibility-Study-on-a-Realistic-Patient-Model.pdf
Thank you! I’ll try soon.
I followed the example script of https://www.researchgate.net/profile/George-Slade-2/publication/348920225_Basics_of_Antenna_Modeling_with_FEniCS_Finite_Element_Suite/links/64521542809a5350214692ca/Basics-of-Antenna-Modeling-with-FEniCS-Finite-Element-Suite.pdf. I saved GMSH script ‘PatchAntennaSymmetric.geo’ as '‘PatchAntennaSymmetric.msh’, but I couldn’t using meshio meshio.read('PatchAntennaSymmetric) open this gmsh file in the next step.
Following the error: Error: Couldn't read file PatchAntennaSymmetric.msh as either of ansys, gmsh
