Hi all, this is a two-fold question. I am trying to solve for the wall shear stress in a basic channel flow. To do so, I believe that I need to use a MixedFunctionSpace as a vector function space for the velocity and scalar function space for the pressure. However, I get the following error when trying to solve for the velocity (line 165):
“Preconditioner number of local columns 4600 does not equal output vector size 4066”
I believe this issue has something to do with my mixed function space Y as a past script which didn’t used a mixed function space did not have this issue. That said, I believe I need the mixed function space as stated above. My code is below:
# Import stuff
set_log_level(1)
# Import mesh from gmsh using meshio
msh = meshio.read("../../domain/rectangle.msh")
# Extract cells and physical data
def create_mesh(mesh, cell_type, prune_z=True):
out_mesh = meshio.Mesh(points=mesh.points, cells={cell_type: cells}, cell_data={"name_to_read":[cell_data]})
if prune_z:
out_mesh.prune_z_0()
return out_mesh
# Triangle mesh
mesh = Mesh()
infile.read(mesh)
# Line mesh
meshio.write("mf.xdmf", line_mesh)
mf = MeshFunction("size_t", mesh, mvc)
domains = MeshFunction("size_t", mesh, mesh.topology().dim())
# # -------------------- Begin Problem ------------------------- # #
# Define knowns
T = 3.0 # time duration
num_steps = 1000 # number of time steps
mu = 0.01 # dynamic viscosity
rho = 1 # density
# Generate Finite Element Space
vp = VectorElement('P', mesh.ufl_cell(), 2)
qp = FiniteElement('P', mesh.ufl_cell(), 1)
# Mixed elements
mex = MixedElement([vp, qp])
# Generate Function Spaces
V = FunctionSpace(mesh, vp)
Q = FunctionSpace(mesh, qp)
## Mixed Function Space
Y = FunctionSpace(mesh, mex)
# Trial Functions
(u, p) = TrialFunctions(Y)
#y = TrialFunction(Y)
#u, p = split(y)
# Test Functions
(v, q) = TestFunctions(Y)
# Define Functions
u_n = Function(V)
u_ = Function(V)
p_n = Function(Q)
p_ = Function(Q)
# Expressions used in variational forms
U = 0.5*(u_n + u)
f = Constant((0, 0))
k = Constant(dt)
mu = Constant(mu)
rho = Constant(rho)
# Define strain rate tensor/symmetric gradient
# Define stress tensor
def sigma(u, p):
return 2*mu*epsilon(u) - p*Identity(len(u))
# Surface Traction
Trac = sigma(u, p)*n
# Normal and tangential components
Tn = inner(Trac, n)
Tt = Trac - Tn*n
# Assemble functions for stress
shear_stress = Function(V)
Lt = (1 / FacetArea(mesh)) * inner(v, Tt) * ds
# Progess bar
progress = Progress('Time-stepping', num_steps)
# Inflow profile
inflow_profile = Expression(('4.0*1.5*x[1]*(0.25 - x[1]) / pow(0.25, 2)', '0'), degree=2)
# Assign Boundary Conditions using markers from gmsh
bcu_inflow = DirichletBC(Y.sub(0), inflow_profile, mf, 5)
bcp_outflow = DirichletBC(Y.sub(1), Constant(0), mf, 6)
bcu_walls = DirichletBC(Y.sub(0), Constant((0,0)), mf, 7)
# Collect Boundary Conditions
bcu = [bcu_inflow, bcu_walls]
bcp = [bcp_outflow]
# Variational Problems #
# Step 1: Tentative Velocity
F1 = rho*dot((u - u_n) / k, v)*dx + \
rho*dot(dot(u_n, nabla_grad(u_n)), v)*dx \
+ inner(sigma(U, p_n), epsilon(v))*dx \
+ dot(p_n*n, v)*ds - \
dot(mu*nabla_grad(U)*n, v)*ds \
- dot(f, v)*dx
a1 = lhs(F1)
L1 = rhs(F1)
# Step 2: New Pressure, P_n
a2 = dot(nabla_grad(p), nabla_grad(q))*dx
L2 = dot(nabla_grad(p_n), nabla_grad(q))*dx - (1/k)*div(u_)*q*dx
# Step 3: Corrected Velocity, u^{n+1}
a3 = dot(u, v)*dx
L3 = dot(u_, v)*dx - k*dot(nabla_grad(p_ - p_n), v)*dx
# Time-stepping
t = 0
for j in range(num_steps):
# Update time
inflow_profile.t = t
# Assemble Matrices
A1 = assemble(a1)
A2 = assemble(a2)
A3 = assemble(a3)
# Apply boundary conditions to LHS matrices
[bc.apply(A1) for bc in bcu]
[bc.apply(A2) for bc in bcp]
# Update current time
b1 = assemble(L1)
[bc.apply(b1) for bc in bcu]
solve(A1, u_.vector(), b1, "mumps", "default")
b2 = assemble(L2)
[bc.apply(b2) for bc in bcp]
solve(A2, p_.vector(), b2, "mumps", "default")
b3 = assemble(L3)
solve(A3, u_.vector(), b3, "mumps", "default")
# Assemble shear stress
assemble(Lt, tensor=shear_stress.vector())
# Save Solutions
if (j % 10 == 00):
# Save solution as vtk
ufile = File('vtk/channel_velo/velo_%04d.pvd' % j)
ufile << (u_, t)
shearfile = File('vtk/channel_shear/shear_%04d.pvd' % j)
shearfile << (shear_stress, t)
# Update Previous Solution
u_n.assign(u_)
p_n.assign(p_)
# Update progress bar
set_log_level(LogLevel.PROGRESS)
progress += 1
