Strange behavior with boundary conditions and PETSc solvers in dolfin 2019.2
I am having some strange errors lately which I cannot fully understand. I can get an MWE which is simply a rectangular 2D mesh with a circular hole in the middle, over which I solve a standard poisson problem.
The mesh is generated with pygmsh version 7.1.5, while meshio version is 4.3.8 and gmsh is 4.7.1, from pip freeze.
In my applications I want to generate the mesh on one process, write it to an XDMF file and read it back so that it’s decomposed between all processors, when running in parallel. The example is the following, most of it is just definition of the mesh and boundary domains:
import pygmsh
# generate the mesh
if MPI.rank(MPI.comm_world) == 0:
    with pygmsh.geo.Geometry() as geom:
        ci = geom.add_circle([0., 0.], 0.5, mesh_size=0.05, make_surface=False)
        rec = geom.add_rectangle(xmin=-2,xmax=2.,ymin=-2.,ymax=2.,z=0.0,mesh_size=0.1,holes=[ci.curve_loop])
        msh = geom.generate_mesh(dim=2)
    msh.remove_lower_dimensional_cells()
    msh.prune_z_0()
    meshio.write('test.xdmf', msh)
    pass
MPI.barrier(MPI.comm_world)     # WAIT FOR PROCESS 0 TO FINISH MESHING
# after writing to file, read again the mesh with xdmf parallel dolfin interface
mesh=Mesh(MPI.comm_world)
with XDMFFile('test.xdmf') as infile:
        infile.read(mesh)
# define domains
class Circle(SubDomain):
        RR = (x[0]*x[0]+x[1]*x[1])**0.5
        return (RR < 1.) and on_boundary
class Out(SubDomain):
        return on_boundary
domains = MeshFunction("size_t", mesh,mesh.topology().dim() -1 )
domains.set_all(0)
Out().mark(domains, 2)
Circle().mark(domains, 1)
# now solve a simple variational problem with PETSc
bcs = [DirichletBC(V, Constant(1.0), domains, 1), DirichletBC(V, Constant(0.0), domains, 2)]
a = inner(grad(u), grad(v))*dx
L = Constant(0.0)*v*dx
sol = PETScKrylovSolver('gmres')
A, bb = assemble_system(a, L, bcs)
# solve
sol.solve(A, u.vector(), bb)
with XDMFFile('sol.xdmf') as outfile:
    outfile.write(u)
Now the problem is that, if I run it on one process: python3 test.py, I get the following error message:
  File "test.py", line 54, in <module>
RuntimeError:
*** Error:   Unable to successfully call PETSc function 'KSPSolve'.
*** Reason:  PETSc error code is: 73 (Object is in wrong state).
*** Where:   This error was encountered inside /build/dolfin-GfTndI/dolfin-2019.2.0~git20201207.b495043/dolfin/la/PETScKrylovSolver.cpp.
*** Process: 0
*** Git changeset:  unknown
If instead I run it in parallel, mpirun -np 2 python3 test.py, the code runs fine and writes the expected solution to file. I guess something is wrong with the mesh reading process, since if I change the code sligthly I get another error, in parallel this time. Just by applying the boundary condition explicitely:
bc1 = DirichletBC(V, Constant(1.0), domains, 1)
A = assemble(a)
bc1.apply(A)
(I repeated only the important part, mesh generation and reading part is the same as above). Now, running in parallel gives the following error:
  File "test.py", line 51, in <module>
    bc1.apply(A)
RuntimeError:
*** Error:   Unable to apply boundary condition.
*** Reason:  Dimension of function space (2908) too large for application of boundary conditions to linear system (2907 rows).
*** Where:   This error was encountered inside BoundaryCondition.cpp.
*** Process: 0
while in serial it works. Any suggestion on what might be going on here?
This is probably because pygmsh adds in non-physical points to your mesh (for instance when generating a circle). These unused points should not be part of your mesh. The easiest way to spot these is to use physical tags with pygmsh, then the non physical points should be at the end of the msh.points array.
See for instance:
Thanks @dokken,
indeed, if I take from the code in your repository
cells = msh.get_cells_type('triangle')
num_vertices = len(np.unique(cells.reshape(-1)))
points = msh.points[:num_vertices]
it turns out that points contained one extra point at the end, which should be the center of the circular boundary in my mesh, and needs to be removed
