hi,I tried to repeat this plastic numerical example, 2.077-Fenicsx-Plasticity/Plasticity_Tests/2d_test_Plasticity_New_Frac_Snes.ipynb at main · jorgenin/2.077-Fenicsx-Plasticity · GitHub but there was a problem. I simplified the problem into a simple elastic problem, and the following error message occurred. May I ask why this is the case? The solver reference is the same as that used in the numerical example above.
x = int(1 / 0.1)
ny = int(1 / 0.1)
domain = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD, nx, ny, cell_type=dolfinx.mesh.CellType.triangle)MPI.COMM_WORLD, 0, 2)
tdim =2
fdim =1
V = fem.functionspace(domain,("CG",1,(2,)))
u_new = fem.Function(V,name = "Displacement_for_updating")
du_limit = fem.Function(V, name="Displacement_limit")
du_max = fem.Function(V, name="Displacement_max")
u_load = fem.Function(V, name="Displacement_load")
v = ufl.TrialFunction(V)
u_ = ufl.TestFunction(V)
du_limit.x.array[:] = -np.inf
du_max.x.array[:] = np.inf
n = ufl.FacetNormal(domain)
loading = fem.Constant(domain,ScalarType(0.0))
def fix(x):
return np.isclose(x[1],0.0)
def load(x):
return np.isclose(x[1],1.0)
def F_ext(v):
return -loading * ufl.inner(n, v) * ds
BC = []
Uimp = fem.Constant(domain,1.0)
dofs_fix = dolfinx.fem.locate_dofs_geometrical(V,fix)
entities = dolfinx.mesh.locate_entities_boundary(domain,fdim,load)
dofs_load = dolfinx.fem.locate_dofs_topological(V.sub(1),fdim,entities)
load_tag = mesh.meshtags(domain,fdim,entities,np.full(len(entities),2))
BC_fix = dolfinx.fem.dirichletbc(dolfinx.default_scalar_type((0.0,0.0)),dofs_fix,V)
BC_load = dolfinx.fem.dirichletbc(Uimp,dofs_load,V.sub(1))
BC = [BC_fix]
u_load.x.array[:] = Uimp.value[()]
E = fem.Constant(domain, 7e3)
nu = fem.Constant(domain, 0.1)
mu = E / (2.0 * (1.0 + nu))
lamda = E * nu / ((1.0 + nu) * (1.0 - 2.0 * nu))
def eps(u):
return ufl.sym(ufl.grad(u))
def sigma(u):
return lamda * ufl.tr(eps(u)) * ufl.Identity(2) + 2 * mu * eps(u)
dx = ufl.Measure("dx",domain=domain)
ds = ufl.Measure("ds",domain = domain,subdomain_data=load_tag)
E_u = ufl.inner(sigma(u_new),eps(v)) * dx
E_u_jacbian = ufl.derivative(E_u,u_new,u_)
problem = SNESSolver(E_u, u_new,J_form = E_u_jacbian, bcs = BC, petsc_options=petsc_options_SNES)
savedir = "results1/"
if os.path.isdir(savedir):
shutil.rmtree(savedir)
os.makedirs(savedir + "Displacement", exist_ok=True)
Displacement_files = dolfinx.io.VTKFile(domain.comm, savedir + "Displacement/Displacement.vtk", "w")
Nincr = 50
loading = np.linspace(0, 0.01,Nincr + 1)
Niter_max = 100
tol = 1e-4
tol_plastic = 1e-4
iterations = [0]
Force = [0]
for iter, t in enumerate(loading[1:]):
print("Load step", iter + 1)
Uimp.value[()] = t
problem.solve()
iterations.append(iter)
Force.append(fem.assemble_scalar(fem.form(sigma(u_new)[1,1] *ds(2))))
Displacement_files.write_function(u_new, iter)
plt.figure()
plt.plot(loading, Force)
plt.xlabel("Imposed displacement")
plt.ylabel("Reaction force")
the snes solver
import dolfinx.fem.petsc
import os, shutil
from dolfinx.cpp.log import LogLevel, log
petsc_options_SNES = {
"snes_type": "vinewtonrsls",
"snes_linesearch_type": "basic",
"ksp_type": "preonly",
"pc_type": "lu",
"snes_atol": 1.0e-08,
"snes_rtol": 1.0e-09,
"snes_stol": 0.0,
"snes_max_it": 50,
"snes_monitor": "",
# "snes_monitor_cancel": "",
class SNESSolver:
Problem class for elasticity, compatible with PETSC.SNES solvers.
def __init__(
self,
F_form: ufl.Form,
u: fem.Function,
bcs=[],
J_form: ufl.Form = None,
bounds=None,
petsc_options={},
form_compiler_parameters={},
jit_parameters={},
monitor=None,
prefix=None,
self.u = u
self.bcs = bcs
self.bounds = bounds
# Give PETSc solver options a unique prefix
if prefix is None:
prefix = "snes_{}".format(str(id(self))[0:4])
self.prefix = prefix
if self.bounds is not None:
self.lb = bounds[0]
self.ub = bounds[1]
V = self.u.function_space
self.comm = V.mesh.comm
self.F_form = fem.form(F_form)
if J_form is None:
J_form = ufl.derivative(F_form, self.u, ufl.TrialFunction(V))
self.J_form = fem.form(J_form)
self.petsc_options = petsc_options
self.monitor = monitor
self.solver = self.solver_setup()
def set_petsc_options(self, debug=False):
# Set PETSc options
opts = PETSc.Options()
opts.prefixPush(self.prefix)
if debug is True:
ColorPrint.print_info(self.petsc_options)
for k, v in self.petsc_options.items():
opts[k] = v
opts.prefixPop()
def solver_setup(self):
# Create nonlinear solver
snes = PETSc.SNES().create(self.comm)
# Set options
snes.setOptionsPrefix(self.prefix)
self.set_petsc_options()
snes.setFromOptions()
self.b = fem.petsc.create_vector(self.F_form)
self.a = fem.petsc.create_matrix(self.J_form)
snes.setFunction(self.F, self.b)
snes.setJacobian(self.J, self.a)
# We set the bound (Note: they are passed as reference and not as values)
if self.monitor is not None:
snes.setMonitor(self.monitor)
snes.setVariableBounds(self.lb.vector, self.ub.vector)
return snes
def F(self, snes: PETSc.SNES, x: PETSc.Vec, b: PETSc.Vec):
"""Assemble the residual F into the vector b.
Parameters
snes: the snes object
x: Vector containing the latest solution.
b: Vector to assemble the residual into.
# We need to assign the vector to the function
x.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
x.copy(self.u.x.petsc_vec)
self.u.x.scatter_forward()
# Zero the residual vector
b.array[:] = 0
fem.petsc.assemble_vector(b, self.F_form)
# this is a nasty workaround to include the force term with the bug https://github.com/FEniCS/dolfinx/issues/2664
force_form = fem.form(-F_ext(v))
b_ds = fem.petsc.create_vector(force_form)
fem.petsc.assemble_vector(b_ds,force_form)
b.array[:] += b_ds.array
# Apply boundary conditions
fem.petsc.apply_lifting(b, [self.J_form], [self.bcs], [x], -1.0)
fem.petsc.set_bc(b, self.bcs, x, -1.0)
def J(self, snes, x: PETSc.Vec, A: PETSc.Mat, P: PETSc.Mat):
"""Assemble the Jacobian matrix.
Parameters
A: Matrix to assemble the Jacobian into.
A.zeroEntries()
fem.petsc.assemble_matrix(A, self.J_form, self.bcs)
def solve(self):
log(LogLevel.INFO, f"Solving {self.prefix}")
try:
self.solver.solve(None, self.u.x.petsc_vec)
return (self.solver.getIterationNumber(), self.solver.getConvergedReason())
except Warning:
log(
LogLevel.WARNING,
f"WARNING: {self.prefix} solver failed to converge, what's next?",
raise RuntimeError(f"{self.prefix} solvers did not converge")
type or paste code here
the problem would be like that
File "/usr/lib/petsc/lib/python3/dist-packages/dolfinx/fem/petsc.py", line 112, in create_vector
dofmap = L.function_spaces[0].dofmap
AttributeError: 'list' object has no attribute 'function_spaces'
