Coming back to FEniCS after a while, I forgot how to store mesh functions with meshio. Here’s what I tried, but the order of the points is messed up:
import meshzoo
from dolfin import FunctionSpace, Mesh, MeshEditor, Expression, project
points, cells = meshzoo.disk(6, 10)
editor = MeshEditor()
mesh = Mesh()
# topological and geometrical dimension 2
editor.open(mesh, "triangle", 2, 2, 1)
editor.init_vertices(len(points))
editor.init_cells(len(cells))
for k, point in enumerate(points):
editor.add_vertex(k, point[:2])
for k, cell in enumerate(cells.astype(np.uintp)):
editor.add_cell(k, cell)
editor.close()
f1 = Expression("x[0]", element=V.ufl_element())
e1 = project(f1, V).vector().get_local()
meshio.Mesh(
V.mesh().coordinates(),
{"triangle": V.mesh().cells()},
point_data={"e1": e1},
).write("out.vtk")
If there’s a better way of creating a mesh from points and cells, let me know, too!
dokken
2
I would suggest saving your data to xdmf, as explained here: https://jsdokken.com/converted_files/tutorial_pygmsh.html#second
I’ve also made a similar version coming from cell-sets (pygmsh)
and
That doesn’t show how to store point_data, does it?
dokken
5
Sorry Nico, I was a bit to fast reading through your post. How about using the vertex_to_dof_map?
mesh = UnitSquareMesh(5, 5)
v_to_d = vertex_to_dof_map(V)
# vertex_to_dof_map
meshio.Mesh(
point_data={"e1": e1[v_to_d]},
).write("out.vtk")
For higher order spaces where there is no 1-to-1 map, I would use:
dolfin.Function.compute_vertex_values()
which would interpolate to vertices of the mesh.
That’s what I was looking for. Thanks!
