I am conducting explicit dynamic simulations and aim to remesh my domain and interpolate the previous solution when convergence issues arise. To this end, I write the last deformed mesh in the .msh format using Meshio. This mesh is then given as an argument to gmsh for remeshing, after which I re-export it in a format compatible with DolfinX.
However, I suspect that Meshio/gmsh disrupts the connectivity, resulting in meshes that are visually appealing yet functionally useless after remeshing.
Below, you will find a Minimal Working Example (MWE) that illustrates this phenomenon:
from dolfinx.fem import (FunctionSpace, Function, VectorFunctionSpace)
from dolfinx.io import gmshio, XDMFFile
from dolfinx.io.gmshio import model_to_mesh
#%% Mesh generation
def init_gmsh():
gmsh.option.setNumber("General.Terminal", 0) # to disable meshing info
gdim = 2
rank = 0
gmsh.model.add("Model")
geom = gmsh.model.geo
return gdim, rank, geom
def return_mesh(model, comm, rank, gdim, quad = True, degree = 1):
gmsh.option.setNumber("Mesh.RecombinationAlgorithm", 2)
if quad:
gmsh.option.setNumber("Mesh.Algorithm", 8)
gmsh.option.setNumber("Mesh.RecombineAll", 1)
gmsh.option.setNumber("Mesh.SubdivisionAlgorithm", 1)
gmsh.model.mesh.setOrder(degree)
domain, meshtags, facets = model_to_mesh(model, comm, rank, gdim=gdim)
gmsh.finalize()
return domain, meshtags, facets
def broken_unit_square(N_largeur, Nh, Largeur = 1, tol = None, raff = 0):
if tol == None:
tol = Largeur / 1e3
gdim, model_rank, geom = init_gmsh()
h_size = Largeur/N_largeur
geom.synchronize()
pb1 = geom.add_point(0, 0, 0)
pb2 = geom.add_point(Largeur/2, 0, 0)
pb3 = geom.add_point(Largeur, 0, 0)
pt1 = geom.add_point(0, Largeur, 0)
pt2 = geom.add_point(Largeur/2, Largeur, 0)
pt3 = geom.add_point(Largeur, Largeur, 0)
pm1 = geom.add_point(0, Largeur/2 - tol, 0)
pm1bis = geom.add_point(0, Largeur/2 + tol, 0)
pm2 = geom.add_point(Largeur/2, Largeur/2, 0)
pm3 = geom.add_point(Largeur, Largeur/2, 0)
left_bottom = geom.add_line(pm1, pb1)
bottom_left = geom.add_line(pb1, pb2)
bottom_right = geom.add_line(pb2, pb3)
right_bottom = geom.add_line(pb3, pm3)
right_mid = geom.add_line(pm3, pm2)
bottom_lip = geom.add_line(pm2, pm1)
left_top = geom.add_line(pm1bis, pt1)
top_left = geom.add_line(pt1, pt2)
top_right = geom.add_line(pt2, pt3)
right_top = geom.add_line(pt3, pm3)
top_lip = geom.add_line(pm2, pm1bis)
boundary_1 = geom.add_curve_loop([left_bottom, bottom_left, bottom_right, right_bottom, right_mid, bottom_lip])
surf_1 = geom.add_plane_surface([boundary_1])
boundary_2 = geom.add_curve_loop([left_top, top_left, top_right, right_top, right_mid, top_lip])
surf_2 = geom.add_plane_surface([boundary_2])
geom.synchronize()
gmsh.model.addPhysicalGroup(gdim, [surf_1], 1)
gmsh.model.addPhysicalGroup(gdim, [surf_2], 2)
gmsh.model.addPhysicalGroup(gdim - 1, [bottom_left, bottom_right], 1, name="bottom")
gmsh.model.addPhysicalGroup(gdim - 1, [left_bottom, left_top], 2, name="left")
gmsh.model.addPhysicalGroup(gdim - 1, [top_left, top_right], 3, name="top")
gmsh.model.addPhysicalGroup(gdim - 2, [pb1], 4, name="corner")
gmsh.option.setNumber("Mesh.CharacteristicLengthMin", h_size)
gmsh.option.setNumber("Mesh.CharacteristicLengthMax", h_size)
geom.synchronize()
return return_mesh(gmsh.model, MPI.COMM_WORLD, model_rank, gdim)
#%% Mesh raff
def dolfinx_mesh_to_msh_with_meshio(input_mesh, name = "mesh.msh"):
ufl_celltype = input_mesh.ufl_cell().cellname()
if ufl_celltype =="triangle":
celltype = "triangle"
reshape_size = 3
elif ufl_celltype =="quadrilateral":
celltype = "quad"
reshape_size = 4
cells = input_mesh.topology.connectivity(input_mesh.topology.dim, 0).array.reshape((-1, reshape_size))
cell_type = meshio.CellBlock(celltype, cells)
points = input_mesh.geometry.x
# Write .msh
mio_mesh = meshio.Mesh(points, [cell_type])
meshio.write(name, mio_mesh, file_format="gmsh22")
return name
def improved_gmsh_mesh_to_dolfinx_mesh(input_mesh_name):
gmsh.open(input_mesh_name)
gmsh.fltk.run()
tags_surface = [entite[1] for entite in gmsh.model.getEntities(gdim)]
tag_groupe_physique = gmsh.model.addPhysicalGroup(gdim, tags_surface)
domain, meshtags, facets = model_to_mesh(gmsh.model, MPI.COMM_WORLD, model_rank, gdim)
gmsh.finalize()
def improve_mesh(domain, name = "old_mesh"):
return improved_gmsh_mesh_to_dolfinx_mesh(dolfinx_mesh_to_msh_with_meshio(domain, name))
######## Mesh ########
domain, _, facet_tag = broken_unit_square(10, 10)
def dummy_deformation(x):
return (x[0]-x[1]**2, x[1])
V = VectorFunctionSpace(domain, ("Lagrange", 1))
u_radial = Function(V)
u_radial.interpolate(dummy_deformation)
with XDMFFile(domain.comm, "mesh.xdmf", "w") as xdmf:
xdmf.write_mesh(domain)
def deform_mesh(mesh, displacement_array):
deformation_array = displacement_array.x.array.reshape((-1, mesh.geometry.dim))
mesh.geometry.x[:, :mesh.geometry.dim] += deformation_array
deform_mesh(domain, u_radial)
with XDMFFile(domain.comm, "mesh_deformed.xdmf", "w") as xdmf:
new_domain, _, facet_tag = improve_mesh(domain)
with XDMFFile(domain.comm, "new_mesh_deformed.xdmf", "w") as xdmf:
xdmf.write_mesh(new_domain)
I deform my non-trivial mesh with an arbitrary displacement field and then attempt to remesh it.
Would anyone have a suggestion for solving this problem? Thanks in advance.
Sincerely,
Paul
