Error in implementing 2D time dependent heat equation
Hi dear Fenicsx users,
I am trying to implement the 2D time dependent heat equation of this tutorial https://jsdokken.com/dolfinx-tutorial/chapter2/heat_code.html.
However the following error occurs when I create the matrix and vector for the linear problem.
I am using DOLFINx version: 0.7.2.
Here is the code:
#We start by defining the temporal discretization parameters, along with the parameters
from dolfinx import mesh, fem
from dolfinx.fem.petsc import assemble_matrix, assemble_vector, apply_lifting, create_vector, set_bc
import numpy
t = 0  # Start time
T = 2  # End time
num_steps = 20  # Number of time steps
dt = (T - t) / num_steps  # Time step size
alpha = 3
beta = 1.2
#As for the previous problem, we define the mesh and appropriate function spaces.
nx, ny = 5, 5
domain = mesh.create_unit_square(MPI.COMM_WORLD, nx, ny, mesh.CellType.triangle)
V = fem.FunctionSpace(domain, ("Lagrange", 1))
#As in the membrane problem, we create a Python-class to resemble the exact solution
class exact_solution():
    def __init__(self, alpha, beta, t):
        self.alpha = alpha
        self.beta = beta
        self.t = t
    def __call__(self, x):
        return 1 + x[0]**2 + self.alpha * x[1]**2 + self.beta * self.t
u_exact = exact_solution(alpha, beta, t)
#As in the previous chapters, we define a Dirichlet boundary condition over the whole boundary
u_D = fem.Function(V)
u_D.interpolate(u_exact)
tdim = domain.topology.dim
fdim = tdim - 1
bc = fem.dirichletbc(u_D, fem.locate_dofs_topological(V, fdim, boundary_facets))
u_n = fem.Function(V)
u_n.interpolate(u_exact)
f = fem.Constant(domain, beta - 2 - 2 * alpha)
F = u * v * ufl.dx + dt * ufl.dot(ufl.grad(u), ufl.grad(v)) * ufl.dx - (u_n + dt * f) * v * ufl.dx
a = fem.form(ufl.lhs(F))
L = fem.form(ufl.rhs(F))
A = assemble_matrix(a, bcs=[bc])
b = create_vector(L)
uh = fem.Function(V)
The error is :
(fenicsx) (base) mamadou@it-latitude5431:~$ /home/mamadou/anaconda3/envs/fenicsx/bin/python /home/mamadou/Downloads/Fawzoulazim2024_March_7th_2024.py
x86_64-conda-linux-gnu-cc: error: unrecognized command-line option '-march'
  File "/home/mamadou/anaconda3/envs/fenicsx/lib/python3.12/site-packages/setuptools/_distutils/unixccompiler.py", line 185, in _compile
    self.spawn(compiler_so + cc_args + [src, '-o', obj] + extra_postargs)
  File "/home/mamadou/anaconda3/envs/fenicsx/lib/python3.12/site-packages/setuptools/_distutils/ccompiler.py", line 1041, in spawn
    spawn(cmd, dry_run=self.dry_run, **kwargs)
  File "/home/mamadou/anaconda3/envs/fenicsx/lib/python3.12/site-packages/setuptools/_distutils/spawn.py", line 70, in spawn
    raise DistutilsExecError(
distutils.errors.DistutilsExecError: command '/home/mamadou/anaconda3/envs/fenicsx/bin/x86_64-conda-linux-gnu-cc' failed with exit code 1
  File "/home/mamadou/anaconda3/envs/fenicsx/lib/python3.12/site-packages/cffi/ffiplatform.py", line 48, in _build
    dist.run_command('build_ext')
  File "/home/mamadou/anaconda3/envs/fenicsx/lib/python3.12/site-packages/setuptools/dist.py", line 989, in run_command
    super().run_command(command)
  File "/home/mamadou/anaconda3/envs/fenicsx/lib/python3.12/site-packages/setuptools/_distutils/dist.py", line 988, in run_command
    cmd_obj.run()
  File "/home/mamadou/anaconda3/envs/fenicsx/lib/python3.12/site-packages/setuptools/command/build_ext.py", line 88, in run
    _build_ext.run(self)
  File "/home/mamadou/anaconda3/envs/fenicsx/lib/python3.12/site-packages/setuptools/_distutils/command/build_ext.py", line 345, in run
    self.build_extensions()
  File "/home/mamadou/anaconda3/envs/fenicsx/lib/python3.12/site-packages/setuptools/_distutils/command/build_ext.py", line 467, in build_extensions
    self._build_extensions_serial()
  File "/home/mamadou/anaconda3/envs/fenicsx/lib/python3.12/site-packages/setuptools/_distutils/command/build_ext.py", line 493, in _build_extensions_serial
    self.build_extension(ext)
  File "/home/mamadou/anaconda3/envs/fenicsx/lib/python3.12/site-packages/setuptools/command/build_ext.py", line 249, in build_extension
    _build_ext.build_extension(self, ext)
  File "/home/mamadou/anaconda3/envs/fenicsx/lib/python3.12/site-packages/setuptools/_distutils/command/build_ext.py", line 548, in build_extension
    objects = self.compiler.compile(
  File "/home/mamadou/anaconda3/envs/fenicsx/lib/python3.12/site-packages/setuptools/_distutils/ccompiler.py", line 600, in compile
    self._compile(obj, src, ext, cc_args, extra_postargs, pp_opts)
  File "/home/mamadou/anaconda3/envs/fenicsx/lib/python3.12/site-packages/setuptools/_distutils/unixccompiler.py", line 187, in _compile
    raise CompileError(msg)
distutils.errors.CompileError: command '/home/mamadou/anaconda3/envs/fenicsx/bin/x86_64-conda-linux-gnu-cc' failed with exit code 1
  File "/home/mamadou/Downloads/Fawzoulazim2024_March_7th_2024.py", line 53, in <module>
  File "/home/mamadou/anaconda3/envs/fenicsx/lib/python3.12/site-packages/dolfinx/fem/forms.py", line 188, in form
    return _create_form(form)
  File "/home/mamadou/anaconda3/envs/fenicsx/lib/python3.12/site-packages/dolfinx/fem/forms.py", line 183, in _create_form
    return _form(form)
  File "/home/mamadou/anaconda3/envs/fenicsx/lib/python3.12/site-packages/dolfinx/fem/forms.py", line 141, in _form
  File "/home/mamadou/anaconda3/envs/fenicsx/lib/python3.12/site-packages/dolfinx/jit.py", line 56, in mpi_jit
  File "/home/mamadou/anaconda3/envs/fenicsx/lib/python3.12/site-packages/dolfinx/jit.py", line 204, in ffcx_jit
  File "/home/mamadou/anaconda3/envs/fenicsx/lib/python3.12/site-packages/ffcx/codegeneration/jit.py", line 199, in compile_forms
    raise e
  File "/home/mamadou/anaconda3/envs/fenicsx/lib/python3.12/site-packages/ffcx/codegeneration/jit.py", line 190, in compile_forms
    impl = _compile_objects(decl, forms, form_names, module_name, p, cache_dir,
  File "/home/mamadou/anaconda3/envs/fenicsx/lib/python3.12/site-packages/ffcx/codegeneration/jit.py", line 284, in _compile_objects
    ffibuilder.compile(tmpdir=cache_dir, verbose=True, debug=cffi_debug)
  File "/home/mamadou/anaconda3/envs/fenicsx/lib/python3.12/site-packages/cffi/api.py", line 725, in compile
    return recompile(self, module_name, source, tmpdir=tmpdir,
  File "/home/mamadou/anaconda3/envs/fenicsx/lib/python3.12/site-packages/cffi/recompiler.py", line 1564, in recompile
    outputfilename = ffiplatform.compile('.', ext,
  File "/home/mamadou/anaconda3/envs/fenicsx/lib/python3.12/site-packages/cffi/ffiplatform.py", line 20, in compile
    outputfilename = _build(tmpdir, ext, compiler_verbose, debug)
  File "/home/mamadou/anaconda3/envs/fenicsx/lib/python3.12/site-packages/cffi/ffiplatform.py", line 54, in _build
    raise VerificationError('%s: %s' % (e.__class__.__name__, e))
cffi.VerificationError: CompileError: command '/home/mamadou/anaconda3/envs/fenicsx/bin/x86_64-conda-linux-gnu-cc' failed with exit code 1
Thank you for your time and your patience.
Hi.
I cannot reproduce your error in DOLFINx v0.7.2, nor DOLFINx v0.7.3. Both tested in conda and Docker environments. Please check mixed Python environments (I saw that you have (fenicsx) (base) in your terminal).
It’s odd that it doesn’t give a URL to the compiler’s log. Maybe it can’t find your C compiler? If you do $ which mpicc do you see what you’d expect?
@ottarhellan at Simula also experienced this today. Maybe @minrk has an idea?
Thank you Jesus for your suggestions. I have chosen (fenicsx) (base) (fenicsx) (base) in my terminal because it is the recommended environment.
