Treatment of discontinuous conditions for interface flux
Hi there ! Currently, I am dealing with an interface condition where the following relationship holds at the interface
  1. Displacement continuity condition:
    u_L = u_R \quad \text{on } \Gamma
  2. Normal derivative jump condition:
\frac{\partial u_L}{\partial n_L} - \frac{\partial u_R}{\partial n_R} = G = 1 \quad \text{on } \Gamma
where n_L = (1,0) is the outward normal from \Omega_L at the interface, and n_R = (-1,0) is the outward normal from \Omega_R at the interface.
I used the Lagrange multiplier method to derive the variational formulation, but the expected results were not obtained. I would like to ask how to handle this type of boundary condition. Your help would be greatly appreciated.
1. Problem Description
This code solves an interface problem: in a rectangular domain \Omega = [0,2] \times [0,1], divided into left and right subdomains by x=1, namely \Omega_L = [0,1] \times [0,1] and \Omega_R = [1,2] \times [0,1], we solve a Poisson equation in each subdomain while enforcing specific continuity conditions at the interface.
1.1 Governing Equations
In the left subdomain \Omega_L:
-\Delta u_L = f_L \quad \text{in } \Omega_L
In the right subdomain \Omega_R:
-\Delta u_R = f_R \quad \text{in } \Omega_R
where \Delta is the Laplacian operator, and f_L=1 and f_R=2 are source terms.
1.2 Boundary Conditions
  1. Dirichlet boundary conditions: at x=2 and y=0, y=1
    u = 0
  2. Neumann boundary condition: at x=0
    \frac{\partial u_L}{\partial n} = g_N = 0
    where n is the outward normal vector to the boundary.
1.3 Interface Conditions
At the interface \Gamma = \{(x,y) | x=1, 0 \leq y \leq 1\}:
2. Weak Form Derivation
2.1 Classical Weak Form
Applying the weak form to each subdomain:
For \Omega_L, multiply by test function v_L and integrate over the domain:
\int_{\Omega_L} \nabla u_L \cdot \nabla v_L \, dx = \int_{\Omega_L} f_L v_L \, dx + \int_{\partial \Omega_L \cap \{x=0\}} g_N v_L \, ds
For \Omega_R, multiply by test function v_R and integrate over the domain:
\int_{\Omega_R} \nabla u_R \cdot \nabla v_R \, dx = \int_{\Omega_R} f_R v_R \, dx
2.2 Introduction of Lagrange Multipliers
To handle the interface conditions, we introduce two Lagrange multipliers:
  • \lambda_1: for the displacement continuity condition
  • \lambda_2: for the normal derivative jump condition
2.3 Application of Lagrange Multiplier Method
The displacement continuity constraint u_L = u_R is enforced via Lagrange multiplier \lambda_1:
\int_{\Gamma} \lambda_1 (v_R - v_L) \, ds + \int_{\Gamma} (u_R - u_L) \mu_1 \, ds
The normal derivative jump constraint \frac{\partial u_L}{\partial n_L} - \frac{\partial u_R}{\partial n_R} = G is enforced via Lagrange multiplier \lambda_2:
\int_{\Gamma} \lambda_2 \left(\frac{\partial v_L}{\partial n_L} - \frac{\partial v_R}{\partial n_R}\right) \, ds + \int_{\Gamma} \left(\frac{\partial u_L}{\partial n_L} - \frac{\partial u_R}{\partial n_R} - G\right) \mu_2 \, ds
3. Complete Variational Form
Combining all the terms above, we get the complete variational problem:
Find (u_L, u_R, \lambda_1, \lambda_2) \in V_L \times V_R \times V_{I1} \times V_{I2} such that for all (v_L, v_R, \mu_1, \mu_2) \in V_L \times V_R \times V_{I1} \times V_{I2}:
a((u_L, u_R, \lambda_1, \lambda_2), (v_L, v_R, \mu_1, \mu_2)) = L((v_L, v_R, \mu_1, \mu_2))
where a is the bilinear form:
+ \int_{\Omega_R} \nabla u_R \cdot \nabla v_R \, dx
+ \int_{\Gamma} \lambda_1 (v_R - v_L) \, ds
+ \int_{\Gamma} \lambda_2 \left(\frac{\partial v_L}{\partial n_L} - \frac{\partial v_R}{\partial n_R}\right) \, ds
+ \int_{\Gamma} \left(\frac{\partial u_L}{\partial n_L} - \frac{\partial u_R}{\partial n_R}\right) \mu_2 \, ds
and L is the linear form:
L((v_L, v_R, \mu_1, \mu_2)) = \int_{\Omega_L} f_L v_L \, dx + \int_{\Omega_R} f_R v_R \, dx
+ \int_{\partial \Omega_L \cap \{x=0\}} g_N v_L \, ds + \int_{\Gamma} G \mu_2 \, ds
4. Theoretical Explanation of the Lagrange Multiplier Method
The code is as blew:
# Define subdomains for boundary conditions
class Dirichlet(SubDomain):
    """Define Dirichlet boundary conditions on the right edge (x=2) and top/bottom edges (y=0,1)"""
        return on_boundary and (near(x[0], 2) or near(x[1], 0) or near(x[1], 1))
class Neumann(SubDomain):
    """Define Neumann boundary conditions on the left edge (x=0)"""
class Interface(SubDomain):
    """Define the interface between left and right subdomains (x=1)"""
        return near(x[0], 1)
# Create the rectangular mesh [0,2]×[0,1]
n = 32  # mesh refinement parameter
mesh = RectangleMesh(Point(0, 0), Point(2, 1), 2 * n, n)
# Mark subdomains: 0 for left subdomain (x<1), 1 for right subdomain (x>1)
domain = MeshFunction("size_t", mesh, mesh.topology().dim(), 0)
for cell in cells(mesh):
    domain[cell] = 1 if cell.midpoint().x() > 1.0 else 0
# Mark the interface facets (x=1)
facets = MeshFunction("size_t", mesh, mesh.topology().dim() - 1, 0)
Interface().mark(facets, 1)
# Create mesh views for each subdomain and the interface
mesh_L = MeshView.create(domain, 0)  # Left subdomain mesh
mesh_R = MeshView.create(domain, 1)  # Right subdomain mesh
mesh_I = MeshView.create(facets, 1)  # Interface mesh
# Define function spaces using continuous Galerkin elements (CG) of order 1
V_L = FunctionSpace(mesh_L, "CG", 1)  # Function space for left subdomain
V_R = FunctionSpace(mesh_R, "CG", 1)  # Function space for right subdomain
V_I1 = FunctionSpace(mesh_I, "CG", 1)  # Function space for displacement continuity Lagrange multiplier
V_I2 = FunctionSpace(mesh_I, "CG", 1)  # Function space for flux jump Lagrange multiplier
# Create a mixed function space for all variables
W = MixedFunctionSpace(V_L, V_R, V_I1, V_I2)
# Mark boundary conditions on the left subdomain boundary
ff_L = MeshFunction("size_t", mesh_L, mesh_L.topology().dim() - 1, 0)
Dirichlet().mark(ff_L, 1)  # Mark Dirichlet boundaries with tag 1
Neumann().mark(ff_L, 2)    # Mark Neumann boundaries with tag 2
Interface().mark(ff_L, 3)  # Mark interface with tag 3
# Mark boundary conditions on the right subdomain boundary
ff_R = MeshFunction("size_t", mesh_R, mesh_R.topology().dim() - 1, 0)
Dirichlet().mark(ff_R, 1)  # Mark Dirichlet boundaries with tag 1
Interface().mark(ff_R, 3)  # Mark interface with tag 3
# Define Dirichlet boundary conditions (u=0 on marked boundaries)
g_D = Constant(0.0)  # Value for Dirichlet boundary condition
bc_L = DirichletBC(W.sub_space(0), g_D, ff_L, 1)  # Apply to left subdomain
bc_R = DirichletBC(W.sub_space(1), g_D, ff_R, 1)  # Apply to right subdomain
bcs = [bc_L, bc_R]  # Collect boundary conditions
# Define problem parameters
f_L = Constant(1.0)  # Source term in left subdomain (-Δu_L = f_L)
f_R = Constant(2.0)  # Source term in right subdomain (-Δu_R = f_R)
g_N = Constant(0.0)  # Neumann boundary condition (∂u/∂n = g_N on x=0)
G = Constant(10.0)   # Interface flux jump condition (∂u_L/∂n_L - ∂u_R/∂n_R = G)
# Define measures for integration over different domains
dx_L = Measure("dx", domain=mesh_L)  # Integration over left subdomain
ds_L = Measure("ds", domain=mesh_L, subdomain_data=ff_L)  # Integration over left boundary
dx_R = Measure("dx", domain=mesh_R)  # Integration over right subdomain
ds_R = Measure("ds", domain=mesh_R, subdomain_data=ff_R)  # Integration over right boundary
ds_I = Measure("dx", domain=mesh_I)  # Integration over interface
(u_L, u_R, lambda_1, lambda_2) = TrialFunctions(W)
(v_L, v_R, mu_1, mu_2) = TestFunctions(W)
# Define the normal vectors at the interface
n_L = Constant((1.0, 0.0))   # Outward normal from left subdomain (pointing right)
n_R = Constant((-1.0, 0.0))  # Outward normal from right subdomain (pointing left)
# Define the bilinear form 'a' for the variational problem
a = (
    # Standard Poisson terms for both subdomains
    inner(grad(u_L), grad(v_L)) * dx_L     # ∫_Ω_L ∇u_L·∇v_L dx
    + inner(grad(u_R), grad(v_R)) * dx_R   # ∫_Ω_R ∇u_R·∇v_R dx
    # Interface terms for displacement continuity (u_L = u_R)
    + inner(lambda_1, v_R - v_L) * ds_I    # ∫_Γ λ₁(v_R - v_L) ds
    + inner(u_R - u_L, mu_1) * ds_I        # ∫_Γ (u_R - u_L)μ₁ ds
    # Interface terms for flux jump condition (∂u_L/∂n_L - ∂u_R/∂n_R = G)
    + inner(lambda_2, dot(grad(v_L), n_L) - dot(grad(v_R), n_R)) * ds_I  # ∫_Γ λ₂(∇v_L·n_L - ∇v_R·n_R) ds
    + inner(dot(grad(u_L), n_L) - dot(grad(u_R), n_R), mu_2) * ds_I      # ∫_Γ (∇u_L·n_L - ∇u_R·n_R)μ₂ ds
# Define the linear form 'L' for the variational problem
L = (
    # Source terms
    inner(f_L, v_L) * dx_L     # ∫_Ω_L f_L·v_L dx
    + inner(f_R, v_R) * dx_R   # ∫_Ω_R f_R·v_R dx
    # Neumann boundary condition term
    + inner(g_N, v_L) * ds_L(2)  # ∫_∂Ω_L∩{x=0} g_N·v_L ds
    # Interface flux jump condition term
    + inner(G, mu_2) * ds_I      # ∫_Γ G·μ₂ ds
# Solve the variational problem
u = Function(W)
solve(a == L, u, bcs, solver_parameters={"linear_solver": "direct"})
# Extract solution components
u_L, u_R, lambda_1, lambda_2 = u.split()
# Create individual functions for evaluation
u_L_func = Function(V_L)
u_R_func = Function(V_R)
lambda_1_func = Function(V_I1)
lambda_2_func = Function(V_I2)
# Assign solution components to individual functions
u_L_func.assign(u_L)
u_R_func.assign(u_R)
lambda_1_func.assign(lambda_1)
lambda_2_func.assign(lambda_2)
# Project gradients for flux evaluation
grad_u_L = project(grad(u_L), VectorFunctionSpace(mesh_L, "CG", 1))
grad_u_R = project(grad(u_R), VectorFunctionSpace(mesh_R, "CG", 1))
# Define interface sampling points
num_points = 20
y_points = np.linspace(0.01, 0.99, num_points)
# Initialize arrays to store sampled values
u_L_values = []  # Left solution values at interface
u_R_values = []  # Right solution values at interface
flux_L_values = []  # Left flux values at interface
flux_R_values = []  # Right flux values at interface
# Sample solution and flux values at the interface
for y in y_points:
    # Define points slightly to the left and right of the interface
    point_L = Point(0.9999, y)  # Point just left of interface
    point_R = Point(1.0001, y)  # Point just right of interface
    # Evaluate solution values
    u_L_val = u_L_func(point_L)
    u_R_val = u_R_func(point_R)
    # Evaluate gradient values
    grad_L_val = grad_u_L(point_L)
    grad_R_val = grad_u_R(point_R)
    # Calculate normal fluxes (derivatives in x-direction)
    flux_L = grad_L_val[0]      # Left flux (∂u_L/∂x at x=1⁻)
    flux_R = -grad_R_val[0]     # Right flux (negative of ∂u_R/∂x at x=1⁺ due to opposite normal)
    # Store values for analysis
    u_L_values.append(u_L_val)
    u_R_values.append(u_R_val)
    flux_L_values.append(flux_L)
    flux_R_values.append(flux_R)
# Calculate errors in interface conditions
continuity_error = np.array(u_L_values) - np.array(u_R_values)  # u_L - u_R should be 0
flux_jump_error = np.array(flux_L_values) - np.array(flux_R_values) - 10.0  # flux_L - flux_R should be G=10
# Print statistical information about errors
print("Interface continuity check:")
print(f"  Maximum error: {np.max(np.abs(continuity_error)):.6e}")
print(f"  Average error: {np.mean(np.abs(continuity_error)):.6e}")
print("Flux jump condition check:")
print(f"  Maximum error: {np.max(np.abs(flux_jump_error)):.6e}")
print(f"  Average error: {np.mean(np.abs(flux_jump_error)):.6e}")
Got wrong output at the interface
  Maximum error: 1.612573e-02
  Average error: 3.787325e-03
  Maximum error: 2.121465e+02
  Average error: 5.768207e+01
Any hint will be greatly appreciated. I’m not fixated on using the Lagrange multiplier method. I welcome any feasible methods that can help me solve this problem of handling the interface condition with the given relationship at the interface to obtain the expected results from the variational formulation.
Is there a particular reason that you want to use two fields defined over two submeshes? You could solve this problem by defining only one field u defined over the entire domain. That would automatically satisfy your compatibility condition u_L = u_R. To also enforce the natural interface condition (the one as the jump over normal stresses), you would only need to add a surface integral on \Gamma. The weak form would be:
Find \, u^h \in V^h(\Omega)\ s.t.\ \forall\, v\in V^h:\\ \int_\Omega \nabla u \cdot \nabla v \, d\Omega= \int_\Omega f \,v \,d\Omega +\int_\Gamma G\, v\, dS + \int_{\partial\Omega_D} g_n\, v\, dS
Here follows the derivation (for f=0 for notational symplicity):
\int_{\Omega_R} \Delta u_R v + \int_{\Omega_L} \Delta u_L v = \int_{\Omega_R} \nabla u_R \cdot \nabla v - \int _{\partial\Omega_R} \nabla u_R\cdot n v \, dS + \int_{\Omega_R} \nabla u_L \cdot \nabla v - \int _{\partial\Omega_L} \nabla u_L\cdot n v \, dS = 0
Choosing u\in H^1 as u_R in \Omega_r and u_L in \Omega_L:
\int_{\Omega} \nabla u \cdot \nabla v = \int _{\partial\Omega} \nabla u \cdot n v \, dS + \int _{\Gamma} ( \nabla u_R\cdot n_R + \nabla u_L\cdot n_L ) v \, dS
Setting v=0 on Dirichlet BC, substituting the Neumann condition and the interface condition:
\int_{\Omega} \nabla u \cdot \nabla v = \int _{\partial\Omega_N} g_N v \, dS + \int _{\Gamma} G\,v \, dS
Note I had to use the interface condition ( \nabla u_R\cdot n_R + \nabla u_L\cdot n_L ) = G rather than ( \nabla u_R\cdot n_R - \nabla u_L\cdot n_L ) = G. Did you make a sign notation mistake, or is that truly what you need?
Thanks, Stein. That’s exactly what I want. I am new to fenics and by using two fields defined over two submeshes is cited from topic_example
Also I have found topic is similar to my problem ,and I have rerite the code
import dolfinx.fem.petsc
from ufl import SpatialCoordinate, TestFunction, TrialFunction, dot, ds, dx, grad, div, FacetNormal, inner, avg
from dolfinx import fem, mesh, io, plot
def V_exact(mode):
    """Define exact solution function"""
    return lambda x: -mode.cos(mode.pi * x[1])
V_numpy = V_exact(np)  # Used for interpolation
V_ufl = V_exact(ufl)   # Used for defining source term
def solve_poisson(N, degree=1):
    Solve Poisson equation with interface conditions
    # Create unit square mesh
    domain = mesh.create_rectangle(MPI.COMM_WORLD, [np.array([0, 0]), np.array([1, 1])],
                                   [N, N], mesh.CellType.triangle)
    # Why connectivity is needed:
    # - Boundary conditions are defined on edges
    # - Finite element degrees of freedom are associated with cells
    # - To know which DOFs are affected by boundary conditions, the code needs to know which cells connect to boundary edges
    domain.topology.create_connectivity(domain.topology.dim - 1, domain.topology.dim)
    # Create discontinuous Galerkin space for representing discontinuous material properties
    Q = fem.functionspace(domain, ("DG", 0))
    # Define subdomains
    def Omega_0(x):
        return x[1] <= 0.50
    def Omega_1(x):
        return x[1] >= 0.50
    # Set spatial coordinates
    x = SpatialCoordinate(domain)
    # Create conductivity function and assign values
    sigma = fem.Function(Q)
    cells_0 = mesh.locate_entities(domain, domain.topology.dim, Omega_0)
    cells_1 = mesh.locate_entities(domain, domain.topology.dim, Omega_1)
    def anode_conductivity(T):
        return 1. / (5.929e-5 - T * 1.235e-8)
    # Set different conductivity values for different regions
    sigma.x.array[cells_0] = np.full_like(cells_0, 210, dtype=default_scalar_type)
    sigma.x.array[cells_1] = np.full_like(cells_1, anode_conductivity(800), dtype=default_scalar_type)
    # Calculate source term based on exact solution
    f = div(-sigma * grad(V_ufl(x)))
    # Create first-order Lagrange function space for solution
    W = fem.functionspace(domain, ("Lagrange", 1))
    V = TrialFunction(W)
    phi = TestFunction(W)
    # Variational form left side: bilinear form
    a = dot(sigma * grad(V), grad(phi)) * dx
    # Mark boundaries and interface
    boundaries = [(1, lambda x: np.isclose(x[0], 0)),   # Left boundary
                  (2, lambda x: np.isclose(x[0], 1)),   # Right boundary
                  (3, lambda x: np.isclose(x[1], 0)),   # Bottom boundary
                  (4, lambda x: np.isclose(x[1], 1)),   # Top boundary
                  (5, lambda x: np.isclose(x[1], 0.5))] # Interface
    # Create boundary markers
        facets = mesh.locate_entities(domain, fdim, locator)
        facet_indices.append(facets)
    facet_tag = mesh.meshtags(domain, fdim, facet_indices[sorted_facets], facet_markers[sorted_facets])
    # Define interior interface integration measure
    dS = ufl.Measure("dS", domain=domain, subdomain_data=facet_tag)
    # Calculate flux jump at the interface
    n = FacetNormal(domain)
    # Calculate flux jump at the interface based on exact solution
    g = ufl.pi * (sigma('+') - sigma('-'))  # Because cos(pi*y) has zero derivative at y=0.5
    # Variational form right side: linear form
    L = f * phi * dx + g * avg(phi) * dS(5)  # Using average of test function
    # Set Dirichlet boundary conditions
    facets_bottom = facet_tag.find(3)
    dofs_bottom = fem.locate_dofs_topological(W, fdim, facets_bottom)
    facets_top = facet_tag.find(4)
    dofs_top = fem.locate_dofs_topological(W, fdim, facets_top)
    BCs = [
        fem.dirichletbc(PETSc.ScalarType(-1), dofs_bottom, W),  # Bottom boundary condition
        fem.dirichletbc(PETSc.ScalarType(1), dofs_top, W)       # Top boundary condition
    # Solve linear problem
    problem = dolfinx.fem.petsc.LinearProblem(a, L, bcs=BCs,
                                     petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
    return problem.solve(), V_ufl(x)
def error_L2_func(Vh, V_ex, degree_raise=3):
    """Calculate L2 error norm"""
    # Create higher-order function space
    degree = 1
    family = Vh.function_space.ufl_element().family_name
    mesh = Vh.function_space.mesh
    Q = fem.functionspace(mesh, (family, degree + degree_raise))
    # Interpolate numerical solution
    V_W = fem.Function(Q)
    V_W.interpolate(Vh)
    # Interpolate exact solution
    V_ex_W = fem.Function(Q)
    if isinstance(V_ex, ufl.core.expr.Expr):
        u_expr = fem.Expression(V_ex, Q.element.interpolation_points)
        V_ex_W.interpolate(u_expr)
        V_ex_W.interpolate(V_ex)
    # Calculate error
    e_W = fem.Function(Q)
    e_W.x.array[:] = V_W.x.array - V_ex_W.x.array
    # Integrate error
    error = fem.form(ufl.inner(e_W, e_W) * ufl.dx)
    error_local = fem.assemble_scalar(error)
    error_global = mesh.comm.allreduce(error_local, op=MPI.SUM)
    return np.sqrt(error_global)
# Convergence test
N = [40, 80, 160, 320, 640]
error_L2 = []
error_H1 = []
h = []
mpi_rank = 5
for i in range(len(N)):
    Vh, Vex = solve_poisson(N[i])
    comm = Vh.function_space.mesh.comm
    # Calculate L2 error
    error_L2 += [error_L2_func(Vh, V_numpy)]
    # Calculate H1 seminorm error
    eh = Vh - Vex
    error_H10 = fem.form(dot(grad(eh), grad(eh)) * dx)
    E_H10 = np.sqrt(comm.allreduce(fem.assemble_scalar(error_H10), op=MPI.SUM))
    error_H1 += [E_H10]
    h += [1. / N[i]]
    if comm.rank == 0:
        mpi_rank = comm.rank
        print(f"h: {h[i]:.2e} Error L2: {error_L2[i]:.2e}")
        print(f"h: {h[i]:.2e} Error H1: {error_H1[i]:.2e}")
# Plot convergence curves
if mpi_rank == 0:
    plt.figure(figsize=(10, 6))
    plt.loglog(N, error_L2, 'o-', label='$L^2$ error')
    plt.loglog(N, error_H1, 's-', label='$H^1$ error')
    # Reference lines
    plt.loglog(N, h, '--', label='$O(h)$')
    h_square = [x ** 2 for x in h]
    plt.loglog(N, h_square, '-.', label='$O(h^2)$')
    plt.xlabel('Mesh resolution N')
    plt.ylabel('Error')
    plt.title('Error Convergence Analysis')
    plt.legend()
    plt.grid(True)
But please forgive my ignorance as a beginner. I still want to know the implementation process of using weak forms such as the Lagrange multiplier method or the Nitsche method. I’ve found two similar examples, but I don’t know how to modify them into the format of interface flux jump to meet the requirements of my problem.
Nitsche method example:
# In this demo, we implement a domain decomposition scheme for
# the Poisson equation based on Nitche's method. The scheme can
# be found in "Mortaring by a method of J. A. Nitsche" by Rolf
# Stenberg. See also "A finite element method for domain
# decomposition with non-matching grids" by Becker et al.
from ufl import inner, grad, avg, div
from utils import norm_L2, convert_facet_tags, interface_int_entities
from dolfinx.fem.petsc import assemble_matrix_block, assemble_vector_block
from meshing import create_square_with_circle
def u_e(x, module=np):
    "A function to represent the exact solution"
    return module.exp(-((x[0] - 0.5) ** 2 + (x[1] - 0.5) ** 2) / (2 * 0.05**2)) + x[0]
# Set some parameters
comm = MPI.COMM_WORLD
h = 0.05  # Maximum cell diameter
k_0 = 1  # Polynomial degree in omega_0
k_1 = 3  # Polynomial degree in omega_1
# Create mesh and sub-meshes
msh, ct, ft, vol_ids, surf_ids = create_square_with_circle(comm, h)
tdim = msh.topology.dim
submesh_0, sm_0_to_msh = mesh.create_submesh(msh, tdim, ct.find(vol_ids["omega_0"]))[:2]
submesh_1, sm_1_to_msh = mesh.create_submesh(msh, tdim, ct.find(vol_ids["omega_1"]))[:2]
# Define function spaces on each submesh
V_0 = fem.functionspace(submesh_0, ("Lagrange", k_0))
V_1 = fem.functionspace(submesh_1, ("Lagrange", k_1))
W = ufl.MixedFunctionSpace(V_0, V_1)
# Test and trial functions
u = ufl.TrialFunctions(W)
v = ufl.TestFunctions(W)
# We use msh as the integration domain, so we require maps from cells
# in msh to cells in submesh_0 and submesh_1. These can be created
# as follows:
cell_imap = msh.topology.index_map(tdim)
num_cells = cell_imap.size_local + cell_imap.num_ghosts
msh_to_sm_0 = np.full(num_cells, -1)
msh_to_sm_0[sm_0_to_msh] = np.arange(len(sm_0_to_msh))
msh_to_sm_1 = np.full(num_cells, -1)
msh_to_sm_1[sm_1_to_msh] = np.arange(len(sm_1_to_msh))
# Compute integration entities for the interface integral
fdim = tdim - 1
interface_facets = ft.find(surf_ids["interface"])
domain_0_cells = ct.find(vol_ids["omega_0"])
domain_1_cells = ct.find(vol_ids["omega_1"])
# Create interface integration entities and modify msh_to_sm maps
interface_entities, msh_to_sm_0, msh_to_sm_1 = interface_int_entities(
    msh, interface_facets, msh_to_sm_0, msh_to_sm_1
# Create entity maps using the modified msh_to_sm maps
entity_maps = {submesh_0: msh_to_sm_0, submesh_1: msh_to_sm_1}
# Create integration measures
dx = ufl.Measure("dx", domain=msh, subdomain_data=ct)
dS = ufl.Measure("dS", domain=msh, subdomain_data=[(surf_ids["interface"], interface_entities)])
kappa = [1.0 + 0.1 * ufl.sin(ufl.pi * x[0]) * ufl.sin(ufl.pi * x[1]) for _ in range(2)]
# Penalty parameter (including harmonic mean on kappa on interface)
# TODO Add k dependency
gamma = 10 * 2 * kappa[0] * kappa[1] / (kappa[0] + kappa[1])
h = ufl.CellDiameter(msh)
n = ufl.FacetNormal(msh)
def jump_i(v, n):
    return v[0]("+") * n("+") + v[1]("-") * n("-")
def grad_avg_i(v, kappa):
    return kappa[1] / (kappa[0] + kappa[1]) * kappa[0] * grad(v[0]("+")) + kappa[0] / (
        kappa[0] + kappa[1]
    ) * kappa[1] * grad(v[1]("-"))
a = (
    inner(kappa[0] * grad(u[0]), grad(v[0])) * dx(vol_ids["omega_0"])
    + inner(kappa[1] * grad(u[1]), grad(v[1])) * dx(vol_ids["omega_1"])
    - inner(grad_avg_i(u, kappa), jump_i(v, n)) * dS(surf_ids["interface"])
    - inner(jump_i(u, n), grad_avg_i(v, kappa)) * dS(surf_ids["interface"])
    + gamma / avg(h) * inner(jump_i(u, n), jump_i(v, n)) * dS(surf_ids["interface"])
# Compile LHS forms
a = fem.form(ufl.extract_blocks(a), entity_maps=entity_maps)
# Define right-hand side forms
f = [-div(kap * grad(u_e(ufl.SpatialCoordinate(msh), module=ufl))) for kap in kappa]
# L = inner(f[0], v[0]) * dx(vol_ids["omega_0"]) + inner(f[1], v[1]) * dx(vol_ids["omega_1"])
G = 1.0  #
L = (inner(f[0], v[0]) * dx(vol_ids["omega_0"]) +
     inner(f[1], v[1]) * dx(vol_ids["omega_1"]) +
     0.5 * G * (v[0]("+") + v[1]("-")) * dS(surf_ids["interface"]))
# Compile RHS forms and set block structure
L = fem.form(ufl.extract_blocks(L), entity_maps=entity_maps)
# Apply boundary conditions. We require the DOFs of V_0 on the domain
# boundary. These can be identified via that facets of submesh_0 that
# lie on the domain boundary.
ft_sm_0 = convert_facet_tags(msh, submesh_0, sm_0_to_msh, ft)
bound_facets_sm_0 = ft_sm_0.find(surf_ids["boundary"])
submesh_0.topology.create_connectivity(fdim, tdim)
bound_dofs = fem.locate_dofs_topological(V_0, fdim, bound_facets_sm_0)
u_bc_0 = fem.Function(V_0)
u_bc_0.interpolate(u_e)
bc_0 = fem.dirichletbc(u_bc_0, bound_dofs)
bcs = [bc_0]
# Assemble linear system of equations
A = assemble_matrix_block(a, bcs=bcs)
b = assemble_vector_block(L, a, bcs=bcs)
# Set-up solver
ksp.setOperators(A)
ksp.setType("preonly")
ksp.getPC().setType("lu")
ksp.getPC().setFactorSolverType("superlu_dist")
# Compute solution
x = A.createVecRight()
ksp.solve(b, x)
# Recover solution
u_0, u_1 = fem.Function(V_0), fem.Function(V_1)
offset = V_0.dofmap.index_map.size_local * V_0.dofmap.index_map_bs
u_0.x.array[:offset] = x.array_r[:offset]
u_1.x.array[: (len(x.array_r) - offset)] = x.array_r[offset:]
u_0.x.scatter_forward()
u_1.x.scatter_forward()
# Write solution to file
with io.VTXWriter(msh.comm, "u_0.bp", u_0, "BP4") as f:
    f.write(0.0)
with io.VTXWriter(msh.comm, "u_1.bp", u_1, "BP4") as f:
    f.write(0.0)
# Compute error in solution
e_L2_0 = norm_L2(msh.comm, u_0 - u_e(ufl.SpatialCoordinate(submesh_0), module=ufl))
e_L2_1 = norm_L2(msh.comm, u_1 - u_e(ufl.SpatialCoordinate(submesh_1), module=ufl))
e_L2 = np.sqrt(e_L2_0**2 + e_L2_1**2)
if msh.comm.rank == 0:
    print(e_L2)
Lagrange multiplier example from github_link (I want to implement it solely using FEniCS)
# Primal, multiscale
from xii import *
from emi.utils import H1_norm, L2_norm, subdomain_interpolate
import emi.fem.common as common
from xii.assembler.trace_matrix import trace_mat_no_restrict
def setup_problem(n, mms, params):
    '''Multi-dimensional primal formulation'''
    base_mesh = UnitSquareMesh(mpi_comm_self(), *(n,) * 2)
    # Marking
    inside = ['(0.25-tol<x[0])', '(x[0] < 0.75+tol)', '(0.25-tol<x[1])', '(x[1] < 0.75+tol)']
    inside = CompiledSubDomain(' && '.join(inside), tol=1E-10)
    mesh_f = MeshFunction('size_t', base_mesh, base_mesh.topology().dim(), 0)
    inside.mark(mesh_f, 1)
    inner_mesh = SubMesh(base_mesh, mesh_f, 1)  # Inside
    outer_mesh = SubMesh(base_mesh, mesh_f, 0)  # Ouside
    interface_mesh = BoundaryMesh(inner_mesh, 'exterior')
    # Spaces
    V1 = FunctionSpace(outer_mesh, 'CG', 1)
    V = FunctionSpace(inner_mesh, 'CG', 1)
    Q = FunctionSpace(interface_mesh, 'CG', 1)
    W = [V1, V, Q]
    u1, u, p = map(TrialFunction, W)
    v1, v, q = map(TestFunction, W)
    Tu1, Tv1 = (Trace(f, interface_mesh) for f in (u1, v1))
    Tu, Tv = (Trace(f, interface_mesh) for f in (u, v))
    # Mark subdomains of the interface mesh (to get source terms therein)
    subdomains = mms.subdomains[1]  #
    marking_f = MeshFunction('size_t', interface_mesh, interface_mesh.topology().dim(), 0)
    [subd.mark(marking_f, i) for i, subd in enumerate(map(CompiledSubDomain, subdomains), 1)]
    # The line integral
    dx_ = Measure('dx', domain=interface_mesh, subdomain_data=marking_f)
    kappa, epsilon = map(Constant, (params.kappa, params.eps))
    a = block_form(W, 2)
    a[0][0] = kappa * inner(grad(u1), grad(v1)) * dx
    a[0][2] = inner(Tv1, p) * dx_
    a[1][1] = inner(grad(u), grad(v)) * dx
    a[1][2] = -inner(Tv, p) * dx_
    a[2][0] = inner(Tu1, q) * dx_
    a[2][1] = -inner(Tu, q) * dx_
    a[2][2] = -epsilon * inner(p, q) * dx_
    # Data
    # Source for domains, outer boundary data, source for interface
    f1, f, gBdry, gGamma, hGamma = mms.rhs
    L = block_form(W, 1)
    L[0] = inner(f1, v1) * dx
    L[0] += sum(inner(hi, Tv1) * dx_(i) for i, hi in enumerate(hGamma, 1))
    # Iface contribution
    L[1] = inner(f, v) * dx
    L[2] = sum(inner(gi, q) * dx_(i) for i, gi in enumerate(gGamma, 1))
    A, b = map(ii_assemble, (a, L))
    subdomains = mms.subdomains[0]  #
    facet_f = MeshFunction('size_t', outer_mesh, outer_mesh.topology().dim() - 1, 0)
    [subd.mark(facet_f, i) for i, subd in enumerate(map(CompiledSubDomain, subdomains), 1)]
    V1_bcs = [DirichletBC(V1, gi, facet_f, i) for i, gi in enumerate(gBdry, 1)]
    bcs = [V1_bcs, [], []]
    A, b = apply_bc(A, b, bcs)
    return A, b, W
setup_mms = common.setup_mms
def setup_error_monitor(mms_data, params):
    '''Compute function mapping numerical solution to errors'''
    # Error of the solution ...
    exact = mms_data.solution
    subdomains = mms_data.subdomains[1]
    def get_error(wh, subdomains=subdomains, exact=exact, mms=mms_data, params=params):
        u1h, uh, ph = wh
        sigma_exact, u_exact, p_exact, I_exact = exact
        # Mutliplier error
        mesh = ph.function_space().mesh()
        Q = FunctionSpace(mesh, 'CG', 3)
        cell_f = MeshFunction('size_t', mesh, mesh.topology().dim(), 0)
        # Spaces on pieces
        for tag, subd in enumerate(subdomains, 1):
            CompiledSubDomain(subd, tol=1E-10).mark(cell_f, tag)
        dx = Measure('dx', domain=mesh, subdomain_data=cell_f)
        p, q = TrialFunction(Q), TestFunction(Q)
        a = inner(p, q) * dx
        L = sum(inner(I_exact_i, q) * dx(i) for i, I_exact_i in enumerate(I_exact, 1))
        I_exact = Function(Q)
        A, b = map(assemble, (a, L))
        solve(A, I_exact.vector(), b)
        V = uh.function_space()
        mesh = V.mesh()
        # Recover the transmembrane potential by postprocessing
        mesh = V.mesh()
        interface_mesh = BoundaryMesh(mesh, 'exterior')
        V = FunctionSpace(interface_mesh, 'CG', 1)
        Tu1 = PETScMatrix(trace_mat_no_restrict(u1h.function_space(), V)) * u1h.vector()
        Tu = PETScMatrix(trace_mat_no_restrict(uh.function_space(), V)) * uh.vector()
        vh = Function(V, Tu1 - Tu)
        # Now using flux we have
        Q = ph.function_space()
        mesh = Q.mesh()
        # Spaces on pieces
        gGamma = mms.rhs[3]
        L = inner(params.eps * ph, q) * dx + sum(inner(gi, q) * dx(i) for i, gi in enumerate(gGamma, 1))
        vh_P = Function(Q)  # Since we project
        solve(A, vh_P.vector(), b)
        vh_I = subdomain_interpolate(zip(gGamma, subdomains), Q)
        vh_I.vector().axpy(params.eps, ph.vector())
        # Simply by interpolation
        return (sqrt(H1_norm(u_exact[0], u1h) ** 2 + H1_norm(u_exact[1], uh) ** 2),
                L2_norm(p_exact, vh),
                L2_norm(p_exact, vh_P),
                L2_norm(p_exact, vh_I))
    error_types = ('|u|_1', '|v|_0', '|v|_{0P}', '|v|_{0I}')
    return get_error, error_types
# How is the problem parametrized
PARAMETERS = ('kappa', 'eps')
I’d be extremely grateful for any hints and assistance. Currently, I’m working on a semiconductor device simulation project based on FEniCS. Those who are interested are also welcome to communicate and cooperate with me.
Thank you again.
