I am using Ubuntu subsystem on windows 10. I installed Anaconda through ubuntu and then installed fenics. However, when I try to import fenics, I get an error saying module not found.
I am attaching a screenshot for better understanding.
I believe the fenics python module is removed in the latest version of fenics (2018.1), try importing dolfin instead.
Could you try this? It worked for me.
Thank you so much. Works for me too.
I didn’t try this with anaconda, but I had a similar issue in Ubuntu. I installed the fenics package on ubuntu, but when I tried to import fenics, I got the error - ‘module not found’.
For me, the resolution was to specify to use python3. I had both python2 and python3 on my system, so by default, python2 was being used when I typed: python -c ‘import fenics’. When I specified python3, it worked for me.
