UFL Conditional Breaking NonlinearProblem
Hey y’all. Just as a preface, I am using v 0.10 of DOLFINx. I am building a axisymmetric contact mechanics model between and analytical rigid indenter and an elastic body using a penalty method, currently using the linear elasticity constitutive laws. I have defined the strain tensor as below:
def eps_u(u):
    return sym(as_tensor([
        [u[0].dx(0),          0, u[0].dx(1)],
        [0,          u[0]/ r_mesh,          0],
        [u[1].dx(0),          0, u[1].dx(1)]
The use of the strain tensor above allows for the FEA to run perfectly, but produces an asymptotic artifact in the volumetric strain graph as the radial distance approaches 0. Through online searching, I am of the belief that this issue is caused by the middle hoop strain term. To accommodate this I was planning on using the modified strain tensor below:
def eps_u(u):
    hoop = conditional(lt(r_mesh, 1e-8), u[0].dx(0), u[0] / r_mesh)
        [0,          hoop,          0],
But this returns this error:
  File "/home/user/project.py", line 198, in <module>
    problem = NonlinearProblem(form, u_displacement, bcs=bcs, J=J, petsc_options_prefix="my_problem_")
  File "/home/user/anaconda3/envs/fenicsx/lib/python3.14/site-packages/dolfinx/fem/petsc.py", line 1239, in __init__
    self._F = _create_form(
        F,
    ...<2 lines>...
        entity_maps=entity_maps,
  File "/home/user/anaconda3/envs/fenicsx/lib/python3.14/site-packages/dolfinx/fem/forms.py", line 449, in form
    return _create_form(form)
  File "/home/user/anaconda3/envs/fenicsx/lib/python3.14/site-packages/dolfinx/fem/forms.py", line 441, in _create_form
    return _form(form)
  File "/home/user/anaconda3/envs/fenicsx/lib/python3.14/site-packages/dolfinx/fem/forms.py", line 361, in _form
    ufcx_form, module, code = jit.ffcx_jit(
        msh.comm, form, form_compiler_options=form_compiler_options, jit_options=jit_options
  File "/home/user/anaconda3/envs/fenicsx/lib/python3.14/site-packages/dolfinx/jit.py", line 60, in mpi_jit
  File "/home/user/anaconda3/envs/fenicsx/lib/python3.14/site-packages/dolfinx/jit.py", line 215, in ffcx_jit
  File "/home/user/anaconda3/envs/fenicsx/lib/python3.14/site-packages/ffcx/codegeneration/jit.py", line 244, in compile_forms
    raise e
  File "/home/user/anaconda3/envs/fenicsx/lib/python3.14/site-packages/ffcx/codegeneration/jit.py", line 224, in compile_forms
    impl = _compile_objects(
        decl,
    ...<9 lines>...
        visualise=visualise,
  File "/home/user/anaconda3/envs/fenicsx/lib/python3.14/site-packages/ffcx/codegeneration/jit.py", line 349, in _compile_objects
    _, code_body = ffcx.compiler.compile_ufl_objects(
        ufl_objects, prefix=module_name, options=options, visualise=visualise
  File "/home/user/anaconda3/envs/fenicsx/lib/python3.14/site-packages/ffcx/compiler.py", line 113, in compile_ufl_objects
    ir = compute_ir(analysis, _object_names, _prefix, options, visualise)
  File "/home/user/anaconda3/envs/fenicsx/lib/python3.14/site-packages/ffcx/ir/representation.py", line 151, in compute_ir
    _compute_integral_ir(
        fd,
    ...<4 lines>...
        visualise,
  File "/home/user/anaconda3/envs/fenicsx/lib/python3.14/site-packages/ffcx/ir/representation.py", line 402, in _compute_integral_ir
    integral_ir = compute_integral_ir(
        itg_data.domain.ufl_cell(),
    ...<5 lines>...
        visualise,
  File "/home/user/anaconda3/envs/fenicsx/lib/python3.14/site-packages/ffcx/ir/integral.py", line 227, in compute_integral_ir
    F = compute_argument_factorization(S, rank)
  File "/home/user/anaconda3/envs/fenicsx/lib/python3.14/site-packages/ffcx/ir/analysis/factorization.py", line 337, in compute_argument_factorization
    F.add_edge(i, F.e2i[o])
KeyError: Zero((), (), ())
Exception ignored while calling deallocator <function NonlinearProblem.__del__ at 0x71e355d33060>:
  File "/home/user/anaconda3/envs/fenicsx/lib/python3.14/site-packages/dolfinx/fem/petsc.py", line 1361, in __del__
    lambda obj: obj is not None, (self._snes, self._A, self._b, self._x, self._P_mat)
AttributeError: 'NonlinearProblem' object has no attribute '_snes'
I have attached how I have currently written my NonlinearProblem, and all of the elements which go into it along with the solver below:
element_displacement = element("Lagrange", domain.basix_cell(), 2, shape = (2,))
functionspace_displacement = functionspace(domain, element_displacement)
u_displacement = Function(functionspace_displacement, name="displacement")
du_displacement = TrialFunction(functionspace_displacement)
v_displacement = TestFunction(functionspace_displacement)
x = SpatialCoordinate(domain)
r_mesh = x[0]
z_mesh = x[1]
def eps_u(u):
        [0,          hoop,          0],
def sig_u(u):
    term_1 = lame_lambda*(tr(eps_u(u)))*Identity(3)
    term_2 = 2*lame_mu*(eps_u(u))
    return term_1+term_2
def ppos(g):
    return 0.5*(g + sqrt(g*g + eps_c*eps_c))
delta_val = Constant(domain, 0.0)
n = as_vector((0.0, 1.0, 0.0)) #Normal vector in the z direction.
obstacle = -delta_val + r_mesh**2 / (2.0 * R_sphere)
gap = obstacle - u_displacement[1]
gap_ppos = ppos(-gap)
penalty_factor = scaling_factor * youngs_mod / lc_fine
ds = Measure('ds', domain=domain, subdomain_data=facet_tags)
contact_energy = 0.5 * penalty_factor * gap_ppos**2 * r_mesh * ds(3)
elastic_form = inner(sig_u(u_displacement), eps_u(v_displacement)) * r_mesh * dx
penalty_form = derivative(contact_energy, u_displacement, v_displacement)
f = Constant(domain, np.array([0.0, 0.0]))
L = inner(f, v_displacement) * r_mesh * dx
form = elastic_form + penalty_form - L
J = derivative(form, u_displacement, du_displacement)
snes_solver = problem.solver
I apologize that I couldn’t provide a full MWE, but does anyone have an idea what could be causing this issue where using the conditional prevents initialization of the problem, and without using conditional, the file runs and solves the problem? Thank you for you time and any help!
I managed to reproduce the error using the configuration in: Axisymmetric formulation for elastic structures of revolution — Computational Mechanics Numerical Tours with FEniCSx, when using your hoop = conditional(lt(r_mesh, 1e-8), u[0].dx(0), u[0] / r_mesh) in the strain tensor.
I think this is a compilation bug, which was reported some time ago: Factorization failure for certain conditionals · Issue #246 · FEniCS/ffcx · GitHub, but does not seem to have been fixed.
A workaround could be the following (tune the regularization at the denominator if it is too low):
def eps(v):
    hoop = v[0] / (x[0] + 1e-10)
    return ufl.sym(
        ufl.as_tensor(
                [v[0].dx(0), 0, v[0].dx(1)],
                [0, hoop, 0],
                [v[1].dx(0), 0, v[1].dx(1)],
That work around solution allows for the model to initialize and converge. The asymptotic artifact still remains even with the conditional, but your help has allowed me to narrow down the issue further. Thank you for taking your time to help!
