Undefined near, solve, tr for dolfinx-v0.6.0
from contextlib import ExitStack
#from dolfinx import *
from dolfinx import la
from dolfinx.cpp.function import near
from dolfinx.fem import (Expression, Function, FunctionSpace,
                         VectorFunctionSpace, dirichletbc, form,
                         locate_dofs_topological, Constant)
                               set_bc)
from dolfinx.mesh import (CellType, GhostMode, create_box, create_rectangle,
                          locate_entities_boundary)
from ufl import dx, grad, inner, sym, Identity, TrialFunction, TestFunction
comm = MPI.COMM_SELF
L = 25.
H = 1.
Nx = 250
Ny = 10
mesh = create_rectangle(comm=comm, points=((0.0, 0.0), (L, H)), n=(Nx, Ny),
                            cell_type=CellType.triangle)
def eps(v):
    return sym(grad(v))
E = Constant(1e5)
nu = Constant(0.3)
model = "plane_stress"
mu = E/2/(1+nu)
lmbda = E*nu/(1+nu)/(1-2*nu)
if model == "plane_stress":
    lmbda = 2*mu*lmbda/(lmbda+2*mu)
#def sigma(v):
#    return lmbda*tr(eps(v))*Identity(2) + 2.0*mu*eps(v)
def sigma(v):
    return lmbda*eps(v)*Identity(2) + 2.0*mu*eps(v)
rho_g = 1e-3
f = Constant((0, -rho_g))
V = VectorFunctionSpace(mesh, 'Lagrange', degree=2)
du = TrialFunction(V)
u_ = TestFunction(V)
a = inner(sigma(du), eps(u_))*dx
l = inner(f, u_)*dx
def left(x, on_boundary):
    return near(x[0], 0.)
bc = dirichletbc(V, Constant((0.,0.)), left)
u = Function(V, name="Displacement")
#solve(a == l, u, bc)
problem = PETSc.LinearProblem(a, L, bcs=[bc], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = problem.solve()
#plot(1e3*u, mode="displacement")
print('done...')
I moved this code into dolfinx-0.6.0 from:
https://comet-fenics.readthedocs.io/en/latest/demo/elasticity/2D_elasticity.py.html
So far there seems to be a difficulty with import dolfinx.cpp.funtion.near. I see there is a way to implement a linear solver from fenicsx tutorials if that is the same type of solver as was meant by the author of 2D_elasticity.html tutorial. So far the function tr() is undefined. Could it be stated what that tr() was originally meant to compute it?
Please look at the dolfinx demos or the dolfinx tutorial for syntax on how to describe Dirichlet boundary conditions. The input to the dorichletbc constructor should not be a function to locate dofs/entities, but a list of dofs.
In DOLFINx you use locate_dofs_topological or locate_dofs_geometrical where near is replaced by np.isclose
tr is the trace operator, and it can be imported from ufl.
