Hi, I’m learning fenicsx-0.9.0 to work on some 3D problems. I found that when I apply a homogeneous Neumann boundary condition to the 3D domain, the actual Neumann flux ends up pretty uneven, depending on the mesh cell type. Here’s a minimal example to show what I mean:
from pathlib import Path
from dolfinx import fem, io, mesh
msh = mesh.create_box(
comm = MPI.COMM_WORLD,
points = ((0.0, 0.0, 0.0), (10.0, 10.0, 10.0)),
n = (10, 10, 10),
V = fem.functionspace(msh, ('CG', 1))
u = ufl.TrialFunction(V)
f = fem.Constant(msh,0.1)
# Define ds(1)
boundary = lambda x : np.isclose(x[2],10.0)
facets = mesh.locate_entities_boundary(msh, 2, boundary)
marks = np.ones((len(facets),),dtype=np.int32)
meshtag = mesh.meshtags(msh,2,facets,marks)
ds = ufl.Measure("ds", domain = msh, subdomain_data = meshtag)
# Define and solve the problem
a = u * v * ufl.dx
L = f * v * ds(1)
problem = LinearProblem(
a,L,petsc_options={"ksp_type":"gmres","pc_type": "ilu"})
uh = problem.solve()
# Output xdmf results
out_folder = Path("output")
out_folder.mkdir(parents=True, exist_ok=True)
with io.XDMFFile(msh.comm, out_folder / "results.xdmf", "w") as file:
file.write_mesh(msh)
file.write_function(uh)
This minumum working code simply solves:
uh*v*dx = f*v*ds(1) with spatially constant f
and in thoery, the value of uh on the boundary ds(1) should be uniform. However, when I use the built-in structured tetrahedral mesh, the values for uh on the boundary ds(1) turn out uneven (see the first figure). If I switch to an unstructured tetra mesh, the results get worse (see the second figure). On the contrary, if I set the cell type as hexahedron, the results would be perfect (see the thrid figure).
So how can I properly apply the Neumann boundary condition when using a tetrahedral mesh? Did I miss something in my setup?
