Unwanted growing boundary
im running the following code, which is similar to this (Precision in hyperelastic model) except that I create a XDMF file as result to view in ParaView 5.9.1.
But my result is differnt, it looks like my boundary is growing in all directions.
In the example it starts with a 100 mm circle, my circle is in the end in X- at ~55 and at X+ ~132. In the example its -50 and ~122.
Anyone having an idea where this could come from? Any help would be great. Hope this is formatted in the right way.
Im running FEniCS 2019.2.0.dev0 on Ubuntu 20.04 in Windows 10.
import vedo
set_log_level(20)
class AllBoundaries(SubDomain):
        return on_boundary and x[0]<-10
def solve_problem(mesh, mfunc, force):
    V = VectorFunctionSpace(mesh, "CG", 1)
    displacement = Function(V)
    bc = [DirichletBC(V, Constant((0,0)), mfunc, 1)]
    F = Constant(force)
    E = Constant(5000)
    nu = Constant(0.3)
    mu = E / (2.0*(1+nu))
    lmbda = E * nu / ((1.0+nu) * (1-2*nu))
    sigma = 2.0 * mu * sym(grad(u)) + lmbda * tr( sym(grad(u)) ) * Identity(2)
    solve(inner(sigma, grad(v)) * dx == inner(F, v) * dx, displacement, bc)
    displacement.set_allow_extrapolation(True)
    return displacement
def update(mesh, displacement):
    new_mesh = Mesh(mesh)
    ALE.move(new_mesh, displacement)
    return new_mesh
def remesh(mesh, res=50):
    if isinstance(mesh, vedo.Mesh):
        vmesh = mesh
        vmesh = vedo.Mesh([mesh.coordinates(), mesh.cells()])
    bpts = vmesh.compute_normals(cells=True).boundaries().join(reset=1) #extract boundary
    vz = vmesh.celldata["Normals"][0][2] # check z component of normals at first point
    bpts.tomesh(invert=vz<0).smooth().write('tmpmesh.xml') #vedo REMESHING + smoothing
    return Mesh("tmpmesh.xml")
N = 40
res = 15
do_remesh = True
vedo.settings.use_parallel_projection = True
circle = Circle(Point(0, 0), 50)
mesh = generate_mesh(circle, res)
file_results = XDMFFile("remesh_test_1.xdmf")
for i in range(N):
    mfunc = MeshFunction('size_t', mesh, 1, mesh.domains())
    mfunc.set_all(0)
    allb = AllBoundaries()
    allb.mark(mfunc, 1)
    F = np.array([2, (i-N/2)/N])
    displacement = solve_problem(mesh, mfunc, F)
    new_mesh = update(mesh, displacement)
    file_results.write(displacement,i)
    if do_remesh:
        mesh = remesh(new_mesh)
        mesh = new_mesh
Thank you!
Hi - interesting observation… it looks like it’s the smoothing thing, which slightly moves the boundary points, and it becomes visible as a cumulative effect. This is a revised version of the same:
import vedo
set_log_level(30)
    F = Constant(force)
    E = Constant(5000)
    nu = Constant(0.3)
    return displacement
    return new_mesh
def remesh(mesh):
        vmesh = mesh
    bpts.generate_mesh(invert=vz<0).write('tmpmesh.xml') #vedo REMESHING + smoothing
N = 40         # number of iterations of stretching
do_remesh = 0  # grab the boundary and remesh the interior at each iteration
circle = vedo.Circle(r=50)
mesh = remesh(circle)
half_circle = circle.boundaries().cut_with_plane(origin=[-10,0,0], normal='-x').z(2)
half_circle.linewidth(5).c("yellow4")
plt = vedo.Plotter(N=N, size=(2250, 1300))
meshes = [mesh]
displacements = []
for i in range(N):
    mfunc.set_all(0)
    allb.mark(mfunc, 1)
    if do_remesh:
        mesh = new_mesh
    meshes.append(mesh)
    displacements.append(displacement)
    arrow = vedo.Arrow2D([0,0], F*20).z(1).c("red4")
    vmesh = vedo.Mesh([mesh.coordinates(), mesh.cells()]).c("k5").lw(1)
    plt.at(i).show(f"step{i}", half_circle, vmesh, arrow)
plt.interactive().close()
no reeshing:
Screenshot from 2023-03-02 14-44-16
remeshing:
Screenshot from 2023-03-02 14-43-46
Thank yout so much!
If I call the smooth() afterwards it does not happen, seems like the combination is causing it.
