vtkDelaunay2D, Edge not recovered, polygon fill suspect
im running the following code, which is based on this (Precision in hyperelastic model ) except that I increase the deformation to force my problem to occur. Its may not a total MWE but I tried to shorten my problem on this example.
The problem occurs after some iterations that the remeshing seems not to be able extracting the boundary right for remeshing. And this warning comes up:
vtkDelaunay2D.cxx:1419  WARN| vtkDelaunay2D (0x3286090): Edge not recovered, polygon fill suspect
Anyone having an idea for a workaround or is this just a limit reached for this remeshing process?
import vedo
set_log_level(20)
class Fixed(SubDomain):
        return on_boundary and x[1]<0
class Disp(SubDomain):
        return on_boundary and x[1]>5
displ_max = 50
tend = 40
displ = Expression(('displ_max*time/tend','0.0'), displ_max = displ_max, time = 0, tend = tend, degree = 2)
def solve_problem(mesh, mfunc, force, displ, tend):
    V = VectorFunctionSpace(mesh, "CG", 1)
    displacement = Function(V)
    bc = [DirichletBC(V, Constant((0.,0.)), Fixed()),
          DirichletBC(V, displ, Disp())]
    F = Constant(force)
    E = Constant(5000)
    nu = Constant(0.3)
    mu = E / (2.0*(1+nu))
    lmbda = E * nu / ((1.0+nu) * (1-2*nu))
    sigma = 2.0 * mu * sym(grad(u)) + lmbda * tr( sym(grad(u)) ) * Identity(2)
    solve(inner(sigma, grad(v)) * dx == inner(F, v) * dx, displacement, bc)
    displacement.set_allow_extrapolation(True)
    return displacement
def update(mesh, displacement):
    new_mesh = Mesh(mesh)
    ALE.move(new_mesh, displacement)
    return new_mesh
def remesh(mesh, res=50):
    if isinstance(mesh, vedo.Mesh):
        vmesh = mesh
        vmesh = vedo.Mesh([mesh.coordinates(), mesh.cells()])
    bpts = vmesh.compute_normals(cells=True).boundaries().join(reset=1) #extract boundary
    vz = vmesh.celldata["Normals"][0][2] # check z component of normals at first point
    bpts.tomesh(invert=vz<0).write('tmpmesh.xml') #vedo REMESHING
    return Mesh("tmpmesh.xml")
N = 40
res = 15
do_remesh = True
vedo.settings.use_parallel_projection = True
circle = Circle(Point(0, 0), 50)
mesh = generate_mesh(circle, res)
meshes = [mesh]
displacements = []
file_results = XDMFFile("remesh_test.xdmf")
for i in range(N):
    displ.time = i
    mfunc = MeshFunction('size_t', mesh, 1, mesh.domains())
    mfunc.set_all(0)
    allb = Fixed()
    allb.mark(mfunc, 1)
    F = np.array([0, 0])
    displacement = solve_problem(mesh, mfunc, F, displ, tend)
    new_mesh = update(mesh, displacement)
    file_results.write(displacement,i)
    if do_remesh:
        mesh = remesh(new_mesh)
        mesh.smooth(1)
        mesh = new_mesh
Thanks for any idea!
I think the issue is that the line connecting the sharp boundaries is interpolated and might become invalid - infact already after a few iteration the mesh triangle look invalid:
you can reduce (but not remove completely) the problem by increasing the boundary and mesh resolution or provide a custom contour to generate the mesh
import vedo
from vedo.dolfin import plot
set_log_level(20)
        return on_boundary and x[1] < 0
        return on_boundary and x[1] > 5
    bc = [DirichletBC(V, Constant((0.0, 0.0)), Fixed()), DirichletBC(V, displ, Disp())]
    F = Constant(force)
    E = Constant(5000)
    nu = Constant(0.3)
    mu = E / (2.0 * (1 + nu))
    lmbda = E * nu / ((1.0 + nu) * (1 - 2 * nu))
    sigma = 2.0 * mu * sym(grad(u)) + lmbda * tr(sym(grad(u))) * Identity(2)
    return displacement
    return new_mesh
        vmesh = mesh
    bpts = vmesh.compute_normals(cells=True).boundaries().join_segments()[0]
    m = bpts.generate_mesh(invert=vz < 0, mesh_resolution=res, line_resolution=res*3)
    m.write("tmpmesh.xml")
displ_max = 50
tend = 40
N = 40
res = 100
do_remesh = True
circle = vedo.Circle(r=50)
mesh = remesh(circle, res)
displ = Expression(
    ("displ_max*time/tend", "0.0"),
    displ_max=displ_max, time=0, tend=tend, degree=2
for i in range(N):
    displ.time = i
    mfunc = MeshFunction("size_t", mesh, 1, mesh.domains())
    mfunc.set_all(0)
    allb = Fixed()
    allb.mark(mfunc, 1)
    file_results.write(displacement, i)
    plot(displacement).clear()
    if do_remesh:
        mesh = remesh(new_mesh, res)
        mesh.smooth(1)
        mesh = new_mesh
Thank you for the fast response, looks like the right direction!
