Precision in hyperelastic model
Hi! I’m trying to model the tissue growth of an embryo using the hyperelastic example. I’m interested in the internal displacements.
I show here an example script which is somehow similar to the real thing: an initial circle is stretched by means of a force into its final shape. The force is variable with time (first points downthen up). This is done in 40 separate time steps:
Now imagine you want to track a “cell”. I do it by applying the computed sequence of displacements to a whatever point on the plane: these are the colored lines. The end point of these are the final position of the “cell”. Now I invert the displacement vectors, and in principle they should be walking back to where they started: these are the black lines.
While overall it seems to work well, there is a small discrepancy between the 2 lines (colored and black). I wonder if you have any idea why is that, maybe it’s something to be expected? Or can be further improved? Or am I doing something wrong?
I also tested with doing a remeshing at each step - instead of keeping the same mesh - and it doesn’t seem to change much (which is very good!):
Thanks a lot for your help!
The code:
import vedo
set_log_level(30)
class AllBoundaries(SubDomain):
        return on_boundary and x[0]<-10
def solve_problem(mesh, mfunc, force):
    V = VectorFunctionSpace(mesh, "CG", 1)
    displacement = Function(V)
    bc = [DirichletBC(V, Constant((0,0)), mfunc, 1)]
    F = Constant(force)
    E = Constant(5000)
    nu = Constant(0.3)
    mu = E / (2.0*(1+nu))
    lmbda = E * nu / ((1.0+nu) * (1-2*nu))
    sigma = 2.0 * mu * sym(grad(u)) + lmbda * tr( sym(grad(u)) ) * Identity(2)
    solve(inner(sigma, grad(v)) * dx == inner(F, v) * dx, displacement, bc)
    displacement.set_allow_extrapolation(True)
    return displacement
def update(mesh, displacement):
    new_mesh = Mesh(mesh)
    ALE.move(new_mesh, displacement)
    return new_mesh
def remesh(mesh, res=50):
    if isinstance(mesh, vedo.Mesh):
        vmesh = mesh
        vmesh = vedo.Mesh([mesh.coordinates(), mesh.cells()])
    bpts = vmesh.computeNormals(cells=True).boundaries().join(reset=1) #extract boundary
    vz = vmesh.celldata["Normals"][0][2] # check z component of normals at first point
    bpts.tomesh(invert=vz<0).smooth().write('tmpmesh.xml') #vedo REMESHING + smoothing
    return Mesh("tmpmesh.xml")
N = 40             # number of iterations of stretching
res = 15           # resolution of meshes
do_remesh = False  # grab the boundary and remesh the interior at each iteration
vedo.settings.useParallelProjection = True  # avoid perspective parallax
circle = Circle(Point(0, 0), 50)
mesh = generate_mesh(circle, res)
meshes = [mesh]
displacements = []
for i in range(N):
    mfunc = MeshFunction('size_t', mesh, 1, mesh.domains())
    mfunc.set_all(0)
    allb = AllBoundaries()
    allb.mark(mfunc, 1)
    F = np.array([2, (i-N/2)/N])
    displacement = solve_problem(mesh, mfunc, F)
    new_mesh = update(mesh, displacement)
    if do_remesh:
        mesh = remesh(new_mesh)
        mesh = new_mesh
    meshes.append(mesh)
    displacements.append(displacement)
    # plot things:
    txt = vedo.Text2D(f"step{i}")
    arrow = vedo.Arrow2D([0,0], F*20).z(1)
    vedo.dolfin.plot(mesh, arrow, txt, c='grey5', at=i, N=N, zoom=1.1) # PRESS q to continue
dmesh_i = meshes[0]  # initial mesh
dmesh_f = meshes[-1] # final mesh
vmesh_i = vedo.Mesh([dmesh_i.coordinates(), dmesh_i.cells()], c='grey5').z(-1)
vmesh_f = vedo.Mesh([dmesh_f.coordinates(), dmesh_f.cells()], c='grey3').wireframe()
plt = vedo.Plotter()
# move a few points along the deformation of the circle
seeds = vedo.Circle(r=50, res=res).points()
endpoints = []
for i, p in enumerate(seeds):
    line = [p]
    for disp in displacements:
        dp   = disp([p[0], p[1]])
        newp = p  + [dp[0],dp[1], 0.0]
        line.append(newp)
        p = newp
    plt += vedo.Line(line, c=i, lw=4).z(1)
    endpoints.append(newp)
# invert everything and move the end points back in place
seeds = list(reversed(endpoints))
displacements = list(reversed(displacements))
    line = [p]
        newp = p  - [dp[0],dp[1], 0.0]
        line.append(newp)
        p = newp
    plt += vedo.Line(line, c='k', lw=2).z(2)
plt += [vmesh_i, vmesh_f]
plt.show(axes=1)
I think the basic problem here is an off-by-one error regarding which point the n^\text{th} displacement is evaluated at. Consider a displacement function
\mathbf{u}^n : \mathbb{R}^2\to\mathbb{R}^2\text{ ,}
and, for some given point \mathbf{x}^n\in\mathbb{R}^2, define
\mathbf{x}^{n+1} := \mathbf{x}^n + \mathbf{u}^n(\mathbf{x}^n)\text{ .}
Then
\mathbf{x}^n \neq \mathbf{x}^{n+1} - \mathbf{u}^n(\mathbf{x}^{n+1})\text{ ,}
because
\mathbf{u}^n(\mathbf{x}^{n+1}) \neq \mathbf{u}^n(\mathbf{x}^n)\text{ .}
It looks like these invalid equations are being used in the attempt to trace the trajectories backward, which would explain the slight deviation.
Thanks for the answer, that indeed explains it.
So is there some meaningful way of “inverting” a set of solutions and back-trace the points or, in other words, can I solve for a in:
\mathbf{b} = \mathbf{a} + \mathbf{u}^n(\mathbf{a})\text{ .}
for a known generic b ?
Assuming the deforming body never self-intersects, a unique inverse deformation exists. But, actually solving for \mathbf{a} in practice may be hard, especially since \mathbf{u}^n is not smooth. You could formally set up a Newton iteration using residual
\mathbf{R}(\mathbf{a}) = \mathbf{a} + \mathbf{u}^n(\mathbf{a}) - \mathbf{b}
and Jacobian
\mathbf{J}(\mathbf{a}) = \mathbf{I} + \nabla\mathbf{u}^n(\mathbf{a})\text{ ,}
but the fact that \nabla\mathbf{u}^n is discontinuous would make convergence unreliable. It might still work, though, if the initial guess is close to \mathbf{a} (e.g., \mathbf{b} in this case), jumps in \nabla\mathbf{u}^n are small, and some sort of line search or damping is used.
