Dear All,
I’m trying to solve Poisson-Nernst-Planck equation but I’ve problem updating the previous solutions at each time step.
Here my code:
from dolfinx import default_scalar_type as dst
from dolfinx import mesh, fem, io, log
import basix
import scipy.constants as sc
import pathlib
cache_dir = pathlib.Path('cache_PNP')
# Define quantities
pot_0 = 25 * 1e-3 # V
c_bulk = [0.1 * 1e3, 0.1 * 1e3] # mol/m^3
z = [1, -1] # charge/molecule
# from https://www.aqion.de/site/diffusion-coefficients
# NaCl
D = [1.330 * 1e-9, 2.030 * 1e-9] # m^2/s
Faraday = sc.e * sc.Avogadro # C/mol
kT = sc.Boltzmann * 298.15 # J
eps = sc.epsilon_0 * 78.36 # C/V*m
T = 10 # s
num_step = 100
dt = T/num_step # s
Is = 0
for c_i, z_i in zip(c_bulk, z):
Is += 1/2 * c_i * z_i**2 # mol*charge / molecule*m^3
k = ufl.sqrt(sc.e**2 # C^2/charge
* sc.Avogadro # molecue/mol
* 2 * Is # mol*charge / molecule*m^3
/ (eps * kT) # V*m/C * 1/J
) # 1/m
d_l = 1/k # m
# Create a simple 1D domain
L = 20 * d_l # m
domain = mesh.create_interval(MPI.COMM_WORLD, 50, [0.0, L])
# Mixed elements
P2 = basix.ufl.element('Lagrange', 'interval', 2)
elements = [P2, P2, P2] # pot, c_1, c_2
elements_n = [P2, P2] # c_1_n, c_2_n
element = basix.ufl.mixed_element(elements)
element_n = basix.ufl.mixed_element(elements_n)
# Function space
V = fem.functionspace(domain, element)
W = fem.functionspace(domain, element_n)
# Find boundary factes and dofs on V.sub(0)
tdim = domain.topology.dim
fdim = tdim - 1
def left_boundary(x):
return np.isclose(x[0], 0.0)
left_boundary_facets = mesh.locate_entities_boundary(domain, fdim,
left_boundary)
left_boundary_dofs_0 = fem.locate_dofs_topological(V.sub(0), fdim,
left_boundary_facets)
# Create trial and test functions
u_all = fem.Function(V) # current solution
v_all = ufl.TestFunction(V)
u_all_list = ufl.split(u_all)
pot = u_all_list[0]
c_1 = u_all_list[1]
c_2 = u_all_list[2]
u_all_n = fem.Function(W) # for previous step
u_all_n_list = u_all_n.split()
c_1_n = u_all_n_list[0]
c_2_n = u_all_n_list[1]
# Constant declaration
eps = fem.Constant(domain, dst(eps))
kT = fem.Constant(domain, dst(kT))
e = fem.Constant(domain, dst(sc.e))
dt = fem.Constant(domain, dst(dt))
for i, c_i in enumerate(c_bulk):
c_bulk[i] = fem.Constant(domain, dst(c_i))
for i, z_i in enumerate(z):
z[i] = fem.Constant(domain, dst(z_i))
for i, D_i in enumerate(D):
D[i] = fem.Constant(domain, dst(D_i))
# Define flux
flux_1 = -(D[0] * ufl.grad(c_1)
+ D[0]/kT * c_1 * z[0] * e * ufl.grad(pot))
flux_2 = -(D[1] * ufl.grad(c_2)
+ D[1]/kT * c_2 * z[1] * e * ufl.grad(pot))
# Define source term
rho = Faraday * (z[0] * c_1 + z[1] * c_2)
f = -rho / eps
# Define initial condition
# concentration equal to the bulk conc. everywhere at t=0
c_1_0_expr = fem.Expression(c_bulk[0],
W.sub(0).element.interpolation_points())
c_2_0_expr = fem.Expression(c_bulk[1],
W.sub(1).element.interpolation_points())
# pot_n.interpolate(pot_0_expr)
c_1_n.interpolate(c_1_0_expr)
c_2_n.interpolate(c_2_0_expr)
# ===Weak form===
# Poisson
Ap = -ufl.inner(ufl.grad(pot), ufl.grad(v_all[0])) * ufl.dx
lp = f * v_all[0] * ufl.dx
# Continuity
Ac_1 = ufl.inner(flux_1, ufl.grad(v_all[1])) * ufl.dx
lc_1 = ((c_1 - c_1_n) / dt) * v_all[1] * ufl.dx
Ac_2 = ufl.inner(flux_2, ufl.grad(v_all[2])) * ufl.dx
lc_2 = ((c_2 - c_2_n) / dt) * v_all[2] * ufl.dx
# BC
bc_0 = fem.dirichletbc(dst(pot_0), left_boundary_dofs_0,
V.sub(0))
# Total probelm
F = (Ap - lp
+ Ac_1 - lc_1
+ Ac_2 - lc_2)
# Solver
problem = NonlinearProblem(F, u_all, [bc_0],
jit_options={'cache_dir': cache_dir})
solver.rtol = 1e-6
solver.max_it = 100
solver.report = True
# Time loop
t = 0
# P1 element for XDMF file
V1 = fem.functionspace(domain, ('Lagrange', 1))
pot_P1 = fem.Function(V1)
c_1_P1 = fem.Function(V1)
c_2_P1 = fem.Function(V1)
pot_out = io.XDMFFile(domain.comm,
'pot.xdmf',
'w')
c_1_out = io.XDMFFile(domain.comm,
'c_1.xdmf',
'w')
c_2_out = io.XDMFFile(domain.comm,
'c_2.xdmf',
'w')
pot_out.write_mesh(V1.mesh)
c_1_out.write_mesh(V1.mesh)
c_2_out.write_mesh(V1.mesh)
for step in range(num_step):
t = t + dt
print(f'Time: {t} (s)')
n, converged = solver.solve(u_all)
if converged:
u_list = u_all.split()
c_1_n.interpolate(u_list[1])
c_2_n.interpolate(u_list[2])
# Save
pot_P1_ex = fem.Expression(u_list[0],
V1.element.interpolation_points())
pot_P1.interpolate(pot_P1_ex)
pot_out.write_function(
pot_P1,
t=t)
c_1_P1_ex = fem.Expression(u_list[1],
c_1_P1.interpolate(c_1_P1_ex)
c_1_out.write_function(
c_1_P1,
t=t)
c_2_P1_ex = fem.Expression(u_list[2],
c_2_P1.interpolate(c_2_P1_ex)
c_2_out.write_function(
c_2_P1,
t=t)
print('Not converge')
break
pot_out.close()
c_1_out.close()
c_2_out.close()
When I check the results, I notice that I have obtained constant functions, and these do not vary over time. I believe the problem is that the concentrations at the previous time, c_1_n and c_2_n, are not being updated within the loop. Could someone kindly help me?
Thank you in advance,
Matteo
