Update mesh over time
Hello everyone,
I have implemented a model for the solution of a PDE system where the mesh is changing over time. However, when I visualize the solution, the mesh appears that it is not changing, although when I print the coordinates, they have changed. Is this a mistake in how I am exporting the solution each time? Or is there an error in the solution?
Here is my code:
# # Schnackeberg model 1D
import os
from dolfinx import default_real_type, log, plot, mesh
from dolfinx.fem import Function, functionspace, Expression, FunctionSpaceBase
from dolfinx.io import XDMFFile, VTKFile
from dolfinx.mesh import CellType, create_unit_square, GhostMode
from ufl import dx, grad, inner, SpatialCoordinate
# Save all logging to file
log.set_output_file("log.txt")
dt = 5.0e-04  # time step
# A unit interval
msh = mesh.create_unit_interval(comm=MPI.COMM_WORLD,
                            nx=50,
                            ghost_mode=GhostMode.shared_facet)
P1 = element("Lagrange", msh.basix_cell(), 1)
ME = functionspace(msh, mixed_element([P1, P1]))
# Trial and test functions of the space `ME` are now defined:
q, v = ufl.TestFunctions(ME)
u = Function(ME)  # current solution
u0 = Function(ME)  # solution from previous converged step
# Split mixed functions
u1, u2 = ufl.split(u)
u10, u20 = ufl.split(u0)
au = 0.9
bu = 1.1
av = 0.8
bv = 0.95
# u_n = InitialConditions(au,bu,av,bv)
# Interpolate initial condition
u.sub(0).interpolate(lambda x: (bu-au)*np.random.rand(x.shape[1]) +au)
u.sub(1).interpolate(lambda x: (bv-av)*np.random.rand(x.shape[1]) +av)
u.x.scatter_forward()
#dt = 1e-3 # time step size
k = dt
d = 10
gamma = 250
a = 0.1
b = 0.9
tol = 1e-4
d1 = 1.0
d2 = d
F = ((u1 - u10) / k)*q*dx + d1*inner(grad(u1), grad(q))*dx\
   -(gamma*(u1*u1*u2-u1+a))*q*dx \
  + ((u2 - u20) / k)*v*dx + d2*inner(grad(u2), grad(v))*dx\
  -(gamma*(-u1*u1*u2+b))*v*dx
# Create nonlinear problem and Newton solver
problem = NonlinearProblem(F, u)
solver.rtol = np.sqrt(np.finfo(default_real_type).eps) * 1e-2
# We can customize the linear solver used inside the NewtonSolver by
# modifying the PETSc options
ksp = solver.krylov_solver
opts = PETSc.Options()  # type: ignore
ksp.setFromOptions()
# Output file
file1 = XDMFFile(MPI.COMM_WORLD, "Schnakenberg1D/outputu1.xdmf", "w")
#file2 = XDMFFile(MPI.COMM_WORLD, "Schnakenberg1D/outputu2.xdmf", "w")
file1.write_mesh(msh)
#file2.write_mesh(msh)
# Step in time
t = 0.0
#  Reduce run time if on test (CI) server
if "CI" in os.environ.keys() or "GITHUB_ACTIONS" in os.environ.keys():
    T = 3 * dt
    T = 1000 * dt
# Get the sub-space for c and the corresponding dofs in the mixed space
# vector
V0, dofs = ME.sub(0).collapse()
# Prepare viewer for plotting the solution during the computation
u1 = u.sub(0)
u2 = u.sub(1)
u0.x.array[:] = u.x.array
x_cord = msh.geometry.x[:,0]
x_2 = x_cord[-1]
x_1 = x_cord[0]
xi = 2*(x_cord - x_1)/(x_2-x_1)-1
v = 0.01
mov = xi**2
print(mov)
while (t < T):
    r = solver.solve(u)
    print(f"Step {int(t/dt)}: num iterations: {r[0]}")
    file1.write_function(u1, t)
    #file2.write_function(u2, t)
    x_2 = x_cord[-1]
    x_1 = x_cord[0]
    v = 0.01
    mov = xi
    msh.geometry.x[:,0] = msh.geometry.x[:,0]+v*mov
file1.close()
#file2.close()
print(msh.geometry.x[:,0])
Thank you.
The XDMFFile does not store a new mesh geometry at each time-step if not explicitly told to do so (as this is very expensive).
Here is a minimal reproducible example:
mesh = dolfinx.mesh.create_unit_square(
    MPI.COMM_WORLD, 10, 10, dolfinx.cpp.mesh.CellType.triangle)
mesh.name = "initial_mesh"
xdmf = dolfinx.io.XDMFFile(mesh.comm, "output.xdmf", "w")
xdmf.write_mesh(mesh)
def f(x):
    return x[0]**2, x[1]**2
V = dolfinx.fem.functionspace(mesh, ("Lagrange", 1, (2, )))
u = dolfinx.fem.Function(V)
u.interpolate(f)
xdmf.write_function(
    u, 0.0, mesh_xpath=f"/Xdmf/Domain/Grid[@Name='{mesh.name}']")
# Perturb mesh
u.x.array[:] -= 1
mesh.geometry.x[:, :] += 0.1
mesh.name = "perturbed_mesh"
    u, 1.0, mesh_xpath=f"/Xdmf/Domain/Grid[@Name='{mesh.name}']")
xdmf.close()
