Update (mixed)function in custom newton solver
Hello everyone,
I am trying to extend the method written in A Newton Method at the Algebraic Level to mixed element in order to solve Navier-Stokes eqeuation. I first solve for the Stokes equation in order to get the initial value to the custom nonlinear solver. However, the residual keep increasing for each iteration, I think it is because I use the wrong commands to update and assign functions inside the iteration loop.
The following is the MWE of what I am trying to do, if anybody has experience on the mixed element, could you please suggest me how to fix this?
# set_log_level(LogLevel.ERROR)
#%% classes for subdomains
class Fluid(SubDomain):
        return x[1] >= 0.0
class Solid(SubDomain):
        return x[1] <= 0.0
# classes for boundaries
class Top(SubDomain):
        return near(x[1], 0.1)
class LeftF(SubDomain):
        return near(x[0], 0.0) and between(x[1], (0.0, 0.1))
class RightF(SubDomain):
        return near(x[0], 1.0) and between(x[1], (0.0, 0.1))
class Interface(SubDomain):
        return near(x[1], 0.0)
class LeftS(SubDomain):
        return near(x[0], 0.0) and between(x[1], (-0.1, 0.0))
class RightS(SubDomain):
        return near(x[0], 1.0) and between(x[1], (-0.1, 0.0))
class Bottom(SubDomain):
        return near(x[1], -0.1)
#%% Varying cases
Re   = Constant(5E-1, name="Re") #500
Pr   = Constant(0.01, name="Pr")  #0.01, 100
kCHT = Constant(20.0, name="kCHT") #1.0, 5.0, 20.0
#%% Parameters for fluid and solid
# Fluid parameters for the variational problem
muF  = Constant(1.002, name="muF")
rhoF = Constant(998, name="rhoF")
cdF  = Constant(0.5984, name="cdF") #0.5984
cpF  = Constant(4181, name="cpF")
alpF = Constant(cdF/rhoF/cpF, name="alpF")
# Solid parameters for the variational problem
muS  = Constant(1, name="muS")
rhoS = Constant(2705, name="rhoS")
cdS  = Constant(227, name="cdS") #227
cpS  = Constant(900, name="cpS")
alpS = Constant(cdS/rhoS/cpS, name="alpS")
#%% meshing and defining the subdomains
mesh = RectangleMesh(Point(0.0, -0.1), Point(1.0, 0.1), 100, 10)
# Define markers for Subdomians, Dirichlet and Neuman bcs
subdomain_marker = MeshFunction("size_t", mesh, mesh.geometry().dim(), 0)
Fluid().mark(subdomain_marker, 1)
Solid().mark(subdomain_marker, 2)
boundary_marker = MeshFunction("size_t", mesh, mesh.geometry().dim()-1, 0)
Top().mark(boundary_marker, 1)
LeftF().mark(boundary_marker, 2)
RightF().mark(boundary_marker, 3)
Interface().mark(boundary_marker, 4) # interface
LeftS().mark(boundary_marker, 5)
RightS().mark(boundary_marker, 6)
Bottom().mark(boundary_marker, 7)
#%% Function Spaces
V  = VectorElement("CG", triangle, 2)       # Velocity on the fluid domain
P  = FiniteElement("CG", triangle, 1)       # Pressure on the fluid domain
element = MixedElement([V, P])
W = FunctionSpace(mesh, element)
#%% Boundary conditions
U_noslip = Constant((0.0,0.0), name="U_noslip")
pressure_left = Constant(15.0, name="pressure_left")
pressure_right = Constant(0.0, name="pressure_right")
bc1 = DirichletBC(W.sub(0), U_noslip, boundary_marker, 1)
bc2 = DirichletBC(W.sub(0), U_noslip, boundary_marker, 4)
bcs = [bc1,bc2]
#%% define trial and test functions
(u, p) = TrialFunctions(W)
(v, q) = TestFunctions(W)
#%% define the domains for integration
dx = Measure("dx", domain=mesh, subdomain_data=subdomain_marker)
ds = Measure("ds", domain=mesh, subdomain_data=boundary_marker)
#%% Define the nonlinear problem
# unit normal vector
# weak form for the Stroke-flow
a = muF*inner(grad(u), grad(v))*dx(1) \
    - p*div(v)*dx(1) \
    - q*div(u)*dx(1)
l = - pressure_left*inner(n, v)*ds(2)\
    - pressure_right*inner(n, v)*ds(3)
# Assembly the lhs and rhs matrices
A = assemble(a, keep_diagonal=True)
L = assemble(l)
# Apply boundary conditions
[bc.apply(A) for bc in bcs]
[bc.apply(L) for bc in bcs]
# solve for the solution
A.ident_zeros()
w_k = Function(W, name="fluid variables")
solver_lin = LUSolver("mumps")
solver_lin.solve(A, w_k.vector(), L)
# Split using deep copy
(u_k, p_k) = w_k.split(True)
u_kVec = u_k.vector().get_local()
p_kVec = p_k.vector().get_local()
# Note that all Dirichlet conditions must be zero for
# the correction function in a Newton-type method
bc1N = DirichletBC(W.sub(0), Constant((0.0,0.0)), boundary_marker, 1)
bc2N = DirichletBC(W.sub(0), Constant((0.0,0.0)), boundary_marker, 4)
bcsN = [bc1N,bc2N]
# Define variational problem for the matrix and vector
# in a Newton iteration
dw = TrialFunctions(W) # w = w_k + omega*dw
# weak form for the Navier-Stroke equation
F = rhoF*inner(grad(u_k)*u_k, v)*dx(1) \
    + inner(grad(u_k), grad(v))*dx(1) \
    - p_k*div(v)*dx(1) \
    - q*div(u_k)*dx(1) \
# derivative of the weak form
a = derivative(F, w_k)
L = -F
# Newton iteration at the algebraic level
dw = Function(W)
(du, dp) = dw.split(True)
w  = Function(W)  # u = u_k + omega*du
(u, p) = w.split(True)
omega = 1.0       # relaxation parameter
eps = 1.0
tol = 1.0E-10
iter = 0
maxiter = 25
while eps > tol and iter < maxiter:
    iter += 1
    print('iteration', iter)
    b = assemble(L)
    [bc.apply(A) for bc in bcsN]
    [bc.apply(b) for bc in bcsN]
    A.ident_zeros()
    solve(A, dw.vector(), b)
    eps = np.linalg.norm(dw.vector().get_local(), ord=np.Inf)
    print('Norm:', eps)
    u.vector()[:] = u_k.vector() + omega*du.vector()
    p.vector()[:] = p_k.vector() + omega*dp.vector()
    assigner = FunctionAssigner(W, W)
    assigner.assign(w_k, w)
convergence = 'convergence after %d Newton iterations at the algebraic level' % iter
if iter >= maxiter:
    convergence = 'no ' + convergence
Many thanks in advance,
Phuris
First, to keep u_k and p_k symbolically linked to w_k, you want to make the following change:
(u_k, p_k) = split(w_k)#w_k.split(True)
#u_kVec = u_k.vector().get_local()
#p_kVec = p_k.vector().get_local()
(The potential for confusion between w_k.split(True) and split(w_k) has been a topic of discussion for some time.) Next, you can simply use the assign method of the Function class regardless of what type of space the Function is in:
    #u.vector()[:] = u_k.vector() + omega*du.vector()
    #p.vector()[:] = p_k.vector() + omega*dp.vector()
    #assigner = FunctionAssigner(W, W)
    #assigner.assign(w_k, w)
    w_k.assign(w_k + omega*dw)
The assign method will take, as an argument, any linear combination of Functions in the correct space. With these changes, the iteration converges nicely for me. (Actually, for the given problem, it converges in one iteration. This looked suspicious, but, after adding a nonzero body force term -inner(Constant((0,1)),v)*dx(1) to F, I got multiple iterations with roughly quadratic convergence, as expected for Newton’s method.)
I am not sure about the 1 iteration convergence here, maybe it is the result of the initial solution is already close to the final solution. I will need to test it further.
Thank you very much for your help.
