Initial Conditions and Function update on time in mixed Element
Version: Dolfinx 0.6.0 Python
Windows Subsystem for Linux (WSL) in Visual Studio Code
Hello guys, I’ve been trying to solve an Eletro-chemo-mechanical coupling problem, and I’ve been faced with some problems.
I’m trying to update these codes to the current version FENICSX, however, I’m having a lot of difficulties.
Due to the fact that the code is extremely extensive, I chose not to write it in full here, just to present the fundamental points
Some questions are:
  1. How to determine an initial concentration the of mobile ions c0= 2740 , in time t =0 for each subdomain ( hydrogel and elastomer) , for a mixed elements.
  2. How to update scalar and vector solution functions correctly in newmark functions (displacement, speed and acceleration)
In the previous version,
This was done in the following way
# Define function space, scalar
U2 = VectorElement("Lagrange", mesh.ufl_cell(), 1)
D0 = FiniteElement("DG", mesh.ufl_cell(), 0)
D1 = FiniteElement("DG", mesh.ufl_cell(), 1)
# DOFs
TH = MixedElement([U2, P1, P1, P1])
ME = FunctionSpace(mesh, TH) # Total space for all DOFs
W = FunctionSpace(mesh,P1)   # Scalar space for visualization later
W2 = FunctionSpace(mesh,U2)   # Vector space for visualization later
W3 = FunctionSpace(mesh,D0)   # DG space for visualization later
W4 = FunctionSpace(mesh,D1)   # DG space for visualization later
# Define test functions in weak form
dw = TrialFunction(ME)
(u_test, omgPos_test, phi_test, omgNeg_test)  = TestFunctions(ME)    # Test function
# Define actual functions with the required DOFs
w = Function(ME)
(u, omgPos, phi, omgNeg) = split(w)    # current DOFs
# A copy of functions to store values in last step for time-stepping.
w_old = Function(ME)
(u_old, omgPos_old, phi_old, omgNeg_old) = split(w_old)   # old DOFs
v_old = Function(W2)
a_old = Function(W2)
# Initial electro-chemical potentials
init_omgPos = Expression('abs(x[1])>=int2-tol?std::log((cPos0)):std::log((cNum))', int2=int2, tol = tol, cPos0 = cPos0, cNum=DOLFIN_EPS, degree=0)
omgPos_init = interpolate(init_omgPos,ME.sub(1).collapse())
assign(w_old.sub(1),omgPos_init)
assign(w.sub(1),omgPos_init)
# Update formula for acceleration
# a = 1/(2*beta)*((u - u0 - v0*dt)/(0.5*dt*dt) - (1-2*beta)*a0)
def update_a(u, u_old, v_old, a_old, ufl=True):
    if ufl:
        dt_ = dk
        beta_ = beta
        dt_ = float(dk)
        beta_ = float(beta)
    return (u-u_old-dt_*v_old)/beta_/dt_**2 - (1-2*beta_)/2/beta_*a_old
# Update formula for velocity
# v = dt * ((1-gamma)*a0 + gamma*a) + v0
def update_v(a, u_old, v_old, a_old, ufl=True):
    if ufl:
        dt_ = dk
        gamma_ = gamma
        dt_ = float(dk)
        gamma_ = float(gamma)
    return v_old + dt_*((1-gamma_)*a_old + gamma_*a)
def update_fields(u_proj, u_proj_old, v_old, a_old):
    """Update fields at the end of each time step."""
    # Get vectors (references)
    u_vec, u0_vec  = u_proj.vector(), u_proj_old.vector()
    v0_vec, a0_vec = v_old.vector(), a_old.vector()
    # use update functions using vector arguments
    a_vec = update_a(u_vec, u0_vec, v0_vec, a0_vec, ufl=False)
    v_vec = update_v(a_vec, u0_vec, v0_vec, a0_vec, ufl=False)
    # Update (u_old <- u)
    v_old.vector()[:], a_old.vector()[:] = v_vec, a_vec
    #u_old.vector()[:] = u_proj.vector()
def avg(x_old, x_new, alpha):
    return alpha*x_old + (1-alpha)*x_new
# Update fields for next step
    u_proj = project(u, W2)
    u_proj_old = project(u_old, W2)
    w_old.vector()[:] = w.vector()
I made some attempts to solve the problems, however I am not making any progress in terms of updating the vector fields and applying the initial condition, due to the fact that I must determine the initial concentration in different subdominions, for a geometry built in gmsh.
I made two attempts to determine the concentrations, one from the coordinates and the other through physical entities built in gmsh itself.Below is the summarized code.
From the coordinates:
from dolfinx import fem, io, nls, log, mesh, plot
import pyvista
from ufl import VectorElement,FiniteElement,MixedElement,TestFunction,TrialFunction,split,grad,tr,Identity,inner,dot
from dolfinx.io import gmshio
domain, cell_tags, facet_tags = gmshio.read_from_msh("capacitor_malha.msh", MPI.COMM_SELF,0, gdim=2)
"""Function Space"""
U2 = ufl.VectorElement("Lagrange", domain.ufl_cell(), 1)  # Displacent
P1 = ufl.FiniteElement("Lagrange", domain.ufl_cell(), 1)  # concentrações + - , electric potential
D0 = ufl.FiniteElement("DG", domain.ufl_cell(), 0)
D1 = ufl.FiniteElement("DG", domain.ufl_cell(), 1)
# DOFs
TH = ufl.MixedElement([U2, P1, P1, P1])
ME = fem.FunctionSpace(domain, TH)  # Total space for all DOFs
"""Extraindo os sub espaços do elemento misto e os mapas contendo os graus de liberdade """
num_subs = ME.num_sub_spaces
spaces = []
maps = []
for i in range(num_subs):
    space_i, map_i = ME.sub(i).collapse()
    spaces.append(space_i)
    maps.append(map_i)
(u_test, omgPos_test, phi_test, omgNeg_test)  = ufl.TestFunctions(ME)    # Test function
dw = ufl.TrialFunction(ME)
w = fem.Function(ME)
(u, omgPos, phi, omgNeg) = ufl.split(w)  # current DOFs
w_old = fem.Function(ME)
(u_old, omgPos_old, phi_old, omgNeg_old) = ufl.split(w_old)  # old DOFs
"""Concentrações iniciais"""
DOlfin_Eps= 0.3e-16
scaleY = 900.e0 #Problema aqui
tol = 1e-12
cPos0 = 0.274
int1 = 200.e0 #
int2 = scaleY/2.-int1
class init_Omg:
    def __init__(self):
        self.scaley= scaleY
        self.int2= int2
        self.tol= tol
        self.c= 0
        self.CNum= DOlfin_Eps
    def init_Omg_eval(self,x):
        if x[1]>= 700e-6 + tol:
            #return ufl.ln(self.c) #
            return np.log(self.c, dtype=np.int32)
        if x[1]<= 200e-6 - tol:
            return np.log(self.CNum, dtype=np.int32)
    def init_Omg_(self,x):
        return ufl.conditional(ufl.ge(x[1],200e+6 + tol), ufl.ln(self.c), ufl.ln(self.CNum))
my_bc_value = init_Omg()
my_bc_value.c=cPos0
bc_expr = fem.Expression(my_bc_value.init_Omg_eval, spaces[1].element.interpolation_points())
w_old.sub(1).interpolate(bc_expr)
by physical entities:
""" Implementation of concentrations in each region"""
def tag(n_tag):
    return cell_tags.find(n_tag)
Q = fem.FunctionSpace(domain, D0)
eletrodo_sup = tag(26)
eletrodo_inf = tag(27)
gel_p = tag(28)
# A ordem de entrada das propriedades na lista deve ser equivalente ao espaço no qual o material ocupa dentro do dominio
material_ = [gel_p, eletrodo_inf, eletrodo_sup]
Init_CPos= fem.Function(spaces[1])
Init_CPos.interpolate(my_bc_value.init_Omg_)
w_old.x.array[gel_p]= Init_CPos.x.array
both attempts don’t work.
I guess you are referring to this?
In the code below, you are mixing a whole lot of ufl and numpy
Let us consider a simple MWE, on a unit square:
from IPython import embed
domain = mesh.create_rectangle(MPI.COMM_WORLD, [[2, 2], [3, 3]], [10, 10])
# DOFs
a = 2.5
cpos0 = 1.1
cNum = 2
def init_omega(x):
    condition = x[1] > a
    condition_inverse = np.invert(condition)
    return condition*np.log(cpos0) + condition_inverse * np.log(cNum)
w.sub(1).interpolate(init_omega)
Here I’ve created a simply numpy function with the same functionality as
where you replace a with int2-tol etc.
As long as your example is kept as partial snippets, it is quite hard to give you any further guidance (and it is aso the reason why it has taken so long to write up a reply). I would strongly suggest you try to simplify your code, and have a look at: PETSc NonlinearProblem running slow - #4 by dokken
as it seems rather relevant for the second question.
Thank you for your answer friend, however, the model you implemented didn’t work for me, however, I got a solution to my problem, which apparently satisfied the behavior I expected, below is the model I used as a reference, In case anyone found it useful.
from dolfinx import fem,nls, log
domain, cell_tags, facet_tags = gmshio.read_from_msh("malhas/capacitor_geometria__triangulo_13.msh", MPI.COMM_WORLD,0, gdim=2)
# DOFs
W = fem.FunctionSpace(domain,P1)   # Scalar space for visualization later
spaces = []
maps = []
    maps.append(map_i)
"""Aplicando as propriedades dos materiais"""
1 28 "Voltagem"
1 27 "Aterramento"
1 22 "Engaste_esquerda"
1 23 "Engaste_direita"
2 24 "Hidrogel_superior"
2 25 "Hidrogel_inferior"
2 26 "elastomero"
2 27 "dominio"
"""Extrair as tags da malha"""
def tag(n_tag):
"Determinação das propriedades de um material "
def mat_features(function_descontinuo, material, constanste):
    space_Mat = fem.Function(function_descontinuo)
    for i in range(len(material)):
        space_Mat.x.array[material[i]] = np.full_like(material[i], constanste[i], dtype=ScalarType)
    return space_Mat
""" Implementação das propriedades em cada regiao"""
hidrogel_sup = tag(24)
hidrogel_inf = tag(25)
elastomero = tag(26)
material_ = [elastomero, hidrogel_inf, hidrogel_sup]
Gshear = mat_features(Q, material_, [0.034e-6, 0.003e-6, 0.003e-6])
Kbulk = mat_features(Q, material_, [2000*0.034e-6,2000*0.003e-6, 2000*0.003e-6])
#intInd = mat_features(Q, material_, [1, 0, 0])
matInd = mat_features(Q, material_, [0.0, 1, 1])
Gshear0 = 100.0e-6  # uso na formução fraca e no cconstrutor
Im_gent = mat_features(Q, material_, [90, 300.0, 300.0])
"""Constantes"""
D = 1.0e-2  # 1.0e0                 # Diffusivity [L2T-1]
RT = 8.3145e-3 * (273.0 + 20.0)  # Gas constant*Temp [ML2T-2#-1]
Farad = 96485.0e-6  # Faraday constant [Q#-1]
""" Initial concentrations"""
cPos0 = 0.274  # Initial concentration [#L-3]
cNeg0 = cPos0  # Initial concentration [#L-3]
cMax = 10000 * 1e-9  # 0.00001*1e-9 # 10000e0*1.e-9
"""Eletrical permittivity """
vareps0 = fem.Constant(domain, 8.85e-12 * 1e-6)  #
vareps_num = mat_features(Q, material_, [1.0 ,1.0e3, 1.0e3])  # Permissividade do gel igual a 10000
vareps_r = mat_features(Q, material_, [6.5, 80., 80.])  # eletrical permittivity for material
vareps = vareps0 * vareps_r * vareps_num
# Mass density
rho = fem.Constant(domain, 1e-9)  # 1e3 kg/m^3 = 1e-9 mg/um^3,
# Rayleigh damping coefficients
eta_m = 0.00000  # Constant(0.000005)
eta_k = 0.00000  # Constant(0.000005)
""" Generalized-alpha method parameters """
alpha = 0.0
gamma = 0.5 + alpha
beta = ((gamma + 0.5) ** 2) / 4
""" Simulation time related params (reminder: in microseconds)"""
ttd = 0.01
# Step in time
t = 0.0  # initialization of time
T_tot = 0e6 * 1.0e6  # 200.0 #0.11        # total simulation time
study = "Electrochemical only"
#study = "Capacitive strain sensing"
if study == "Electrochemical only":
    T2_tot = 30.0e6
elif study == "Capacitive strain sensing":
    T2_tot = 60.0e6
dt = T2_tot / 20  # incrementos de tempo
phi_norm = RT / Farad  # "Thermal" Volt
"""unknown functions, testing functions and step functions"""
"""acceleration and speed"""
W2 = fem.FunctionSpace(domain, U2)
v_old = fem.Function(W2)
a_old = fem.Function(W2)
"""Implementação das Concentrações iniciais, cations e anions, initial concentrations"""
DOlfin_Eps= 0.3e-15
Init_CPos= fem.Function(Q)
Init_CPos.x.array[material_[0]]= ufl.ln(DOlfin_Eps)
Init_CPos.x.array[material_[1]]= ufl.ln(cPos0)
Init_CPos.x.array[material_[2]]= ufl.ln(cPos0)
Init_CNeg= fem.Function(Q)
Init_CNeg.x.array[material_[0]]= ufl.ln(DOlfin_Eps)
Init_CNeg.x.array[material_[1]]= ufl.ln(cNeg0)
Init_CNeg.x.array[material_[2]]= ufl.ln(cNeg0)
w_old.sub(1).interpolate(Init_CPos)
w_old.sub(3).interpolate(Init_CNeg)
w.sub(3).interpolate(Init_CNeg)
w.sub(1).interpolate(Init_CPos)
Below is the link to the complete code and the mesh/geometry used
https://drive.google.com/drive/folders/13dVlZ0C-d9u3D9HuLiGvzJAxkfM6WxHj?usp=sharing
Link is not working . Can you please again upload the code
