Hi everyone!
i calculated an Eigenfunction, which i want to use, to generate a load, to my model, i have all the parameters i need, but my console thorws an exception, for the eigenfunction, which is technically a vector with two entries.
mesh = UnitSquareMesh(10,10)
X = FiniteElement('CG', mesh.ufl_cell(), 2)
Y = FiniteElement('CG', mesh.ufl_cell(), 2)
Z = X * Y
S = FunctionSpace(mesh, Z)
u = TrialFunctions(S)
phi = TestFunctions(S)
a = inner(grad(u[1]), grad(phi[0]))*dx + inner(grad(u[0]), grad(phi[1]))*dx
def boundary(x, on_boundary):
return on_boundary
bc = DirichletBC(S, Constant((0,0)), boundary)
L_dummy = Constant(0)*phi[0]*dx
m = u[0]*phi[0]*dx + u[1]*phi[1]*dx
A, _ = assemble_system(a,L_dummy,bc)
B = assemble(m)
eigensolver = SLEPcEigenSolver(as_backend_type(A), as_backend_type(B))
eigensolver.parameters['spectrum'] = 'target real'
eigensolver.parameters['tolerance'] = 1e-6
eigensolver.solve()
r, c, rx, cx = eigensolver.get_eigenpair(0)
print("Eigenvalue: ", r)
ef = Function(S)
ef.vector()[:] = rx
plot(ef[0])
# %% Computation of time dependent problem
T = 0.1 # final time
num_steps = 500 # number of time steps
t = 0
u_m = Function(S)
u_n = Function(S)
f = Expression ("-2*r*u_lambda*-2*r*sin(r*t)" , r = r, t = 0, u_lambda = ef[0])
# Create VTK file for saving solution
vtkfile = File('solution/ResonatingPlate.pvd')
#define F and assemble unknown and known variables
a_evo = -dt*dt*(inner(grad(u[0]),grad(phi[0])) + inner(grad(u[1]),grad(phi[1])) + u[1]*phi[0])*dx + (u[0]*phi[1])*dx
L = (2*u_n[0]*phi[1] - u_m[0]*phi[1])*dx + dt*dt*(f*phi[1])*dx
l=Function(S)
for n in range(num_steps):
# Compute solution
solve(a_evo == L, l, bc)
# Save to file
vtkfile << (l, t)
#vtkfile2 << (w_temp,t)
u_m.assign(u_n)
# Update previous solution
u_n.assign(l)
# Update current time
f.t = t
I have the feeling that there is a simple thing i am missing to use the prior calculated function in my expression. Very hint is very much appreciated.
