Hello, my dear! This is a program that uses FENICSX 0.9.0 to read the grid information stored in the “.h5” file. It will run without mpirun, but if you switch to mpirun, the following error will occur. Can you help me to solve it? Thank you very much!
import h5py
from dolfinx import mesh, io
from dolfinx.mesh import meshtags, meshtags_from_entities #
from dolfinx.io import distribute_entity_data
# import meshio #
try:
from dolfinx.cpp.graph import adjacencylist
except ImportError:
from dolfinx import cpp
adjacencylist = cpp.graph.AdjacencyList_int32
filename = "colin27_coarse_boundaries.h5"
file = h5py.File(filename, 'r')
coordinates = np.array(file["mesh/coordinates"])
# coordinates = np.array([
# [0.0, 0.0, 0.0], #
# [1.0, 0.0, 0.0], #
# [0.0, 1.0, 0.0], #
# [0.0, 0.0, 1.0], #
# [1.0, 1.0, 1.0], #
# ], dtype=np.float64)
topology = np.array(file["mesh/topology"]) #
print(f"Mesh_shape: {topology.shape}")
# topology = np.array([
# [0, 1, 2, 3], #
# [1, 2, 3, 4], #
# [2, 3, 4, 5], #
# ], dtype=np.int32)
boundary_coordinates = np.array(file["boundaries/coordinates"])
boundary_facets = np.array(file["boundaries/topology"], dtype=np.int32) #
tags = np.array(file["boundaries/values"], dtype=np.int32) #
print(f"boundary_facets = {boundary_facets}") #
gdim = 3
shape = "tetrahedron"
degree = 1
cell = ufl.Cell(shape)
ultele = element("Lagrange", cell.cellname(), degree, shape=(gdim,))
ufl_tetra = ufl.Mesh(ultele)
mesh = dolfinx.mesh.create_mesh(MPI.COMM_WORLD, topology, coordinates, ufl_tetra)
tdim = mesh.topology.dim
fdim = tdim - 1
marked_facets = boundary_facets.reshape(-1, 3).astype(np.int64)
print(f"boundary_facets = {marked_facets}")
facet_values = tags.reshape(-1).astype(np.int32)
print(f"facet_values = {facet_values}")
# 2.
sorted_facets = np.sort(marked_facets, axis=1)
print(f"boundary_facets = {sorted_facets.shape}")
unique_facets, unique_indices = np.unique(sorted_facets, axis=0, return_index=True)
marked_facets_unique = marked_facets[unique_indices]
facet_values_unique = facet_values[unique_indices]
print(f"only fact number: {len(marked_facets_unique)}")
# 3.
local_entities, local_values = distribute_entity_data(
mesh, fdim, marked_facets_unique, facet_values_unique
print(f"local_entities: {local_entities.shape}; local_values: {local_values.shape}")
# 4.
mesh.topology.create_connectivity(fdim, tdim) #
mesh.topology.create_connectivity(tdim, fdim)
# 5.
adj = adjacencylist(local_entities)
facet_tag = meshtags_from_entities(mesh, fdim, adj, local_values)
facet_tag.name = "Facet tags"
with io.XDMFFile(MPI.COMM_WORLD, "brain.xdmf", "w") as xdmf:
xdmf.write_mesh(mesh)
xdmf.write_meshtags(facet_tag, mesh.geometry)
Error:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see and [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
[0]PETSC ERROR: Run with -malloc_debug to check if memory corruption is causing the crash.[1]PETSC ERROR: ------------------------------------------------------------------------
[1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger[1]PETSC ERROR: or see and [1]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
[1]PETSC ERROR: to get more information on the crash.[1]PETSC ERROR: Run with -malloc_debug to check if memory corruption is causing the crash.
