Using the subspace iteration method to find modes
Hello everyone, I am a beginner in coding, and I don’t know why all my modes are 1. I really appreciate your help (fenicsx0.10x)
Here is the code:
from dolfinx import mesh, fem
import dolfinx.fem.petsc
from scipy.linalg import eigh
# 1. Mesh and function space
comm = MPI.COMM_WORLD
rank = comm.Get_rank()
domain = mesh.create_unit_square(comm, 16, 16)          # coarse mesh for speed
V = fem.functionspace(domain, ("Lagrange", 1))          # scalar linear elements
u = ufl.TrialFunction(V)
# 2. Variational forms: stiffness (Laplacian) and mass (L2)
a_K = ufl.inner(ufl.grad(u), ufl.grad(v)) * ufl.dx
a_M = ufl.inner(u, v) * ufl.dx
# 3. Dirichlet boundary condition on left edge (x = 0)
def left_boundary(x):
    return np.isclose(x[0], 0.0)
left_facets = mesh.locate_entities_boundary(domain, fdim, left_boundary)
dofs_left = fem.locate_dofs_topological(V, fdim, left_facets)
bc = fem.dirichletbc(PETSc.ScalarType(0.0), dofs_left, V)
# 4. Assemble matrices K and M with consistent boundary conditions
K = dolfinx.fem.petsc.assemble_matrix(fem.form(a_K), bcs=[bc])
K.assemble()
M = dolfinx.fem.petsc.assemble_matrix(fem.form(a_M), bcs=[])
M.assemble()
M.zeroRowsColumns(dofs_left, diag=1.0)   # apply Dirichlet to mass matrix
M.assemble()
# Quick check of matrix magnitudes (only rank 0)
if rank == 0:
    k_diag = K.getDiagonal().array
    m_diag = M.getDiagonal().array
    print(f"K diag: min={k_diag.min():.2e}, max={k_diag.max():.2e}, mean={k_diag.mean():.2e}")
    print(f"M diag: min={m_diag.min():.2e}, max={m_diag.max():.2e}, mean={m_diag.mean():.2e}")
# 5. Linear solver for K y = b (direct LU with MUMPS)
ksp = PETSc.KSP().create(comm)
ksp.setOperators(K)
ksp.setType(PETSc.KSP.Type.PREONLY)
pc = ksp.getPC()
pc.setType(PETSc.PC.Type.LU)
ksp.setFromOptions()
# 6. Subspace iteration parameters
p = 6                     # number of eigenpairs sought
q = p                     # subspace dimension (can be increased, e.g. q=2p)
max_iter = 30
tol = 1e-8
# Initial random subspace X (list of PETSc Vecs)
X_vecs = []
for i in range(q):
    vec = K.createVecRight()
    while True:
        rctx = PETSc.Random().create(comm=comm)
        rctx.setType(PETSc.Random.Type.RAND)
        rctx.setSeed(i + rank * 100 + 12345)
        vec.setRandom(rctx)
        if vec.dot(M * vec) > 1e-12:
            break
    X_vecs.append(vec)
# Helper functions: M‑normalization and M‑orthonormalization
def m_normalize(vec, M):
    norm2 = vec.dot(M * vec)
    if norm2 < 1e-12:
        vec.axpy(1e-8, vec)          # tiny perturbation
    norm = np.sqrt(norm2)
    vec.scale(1.0 / norm)
    return norm
def m_orthonormalize(vecs, M):
    """Modified Gram–Schmidt with respect to the M inner product."""
    n = len(vecs)
    for i in range(n):
        for j in range(i):
            prod = vecs[j].dot(M * vecs[i])
            vecs[i].axpy(-prod, vecs[j])
        m_normalize(vecs[i], M)
# Initial orthonormalization
m_orthonormalize(X_vecs, M)
# 7. Subspace iteration loop
old_ritz = np.full(p, np.inf)
for it in range(max_iter):
    # --- (1) Simultaneous inverse iteration: K Y = M X ---
    Y_vecs = []
    for i in range(q):
        y = K.createVecRight()
        Mx = M * X_vecs[i]
        ksp.solve(Mx, y)
        Y_vecs.append(y)
    # --- (2) Rayleigh–Ritz projection ---
    # Compute K_r = Yᵀ K Y  and M_r = Yᵀ M Y  (dense q×q matrices)
    K_r_local = np.zeros((q, q))
    M_r_local = np.zeros((q, q))
    KY_vecs = [K * y for y in Y_vecs]          # precompute K*Y
    for i in range(q):
        for j in range(q):
            K_r_local[i, j] = Y_vecs[i].dot(KY_vecs[j])
            M_r_local[i, j] = Y_vecs[i].dot(M * Y_vecs[j])
    # Global reduction (MPI all‑reduce)
    K_r_global = np.zeros_like(K_r_local)
    M_r_global = np.zeros_like(M_r_local)
    comm.Allreduce(K_r_local, K_r_global, op=MPI.SUM)
    comm.Allreduce(M_r_local, M_r_global, op=MPI.SUM)
    # Solve the reduced eigenproblem on rank 0
    if rank == 0:
        K_r_sym = 0.5 * (K_r_global + K_r_global.T)
        M_r_sym = 0.5 * (M_r_global + M_r_global.T)
        ritz_vals, Q = eigh(K_r_sym, M_r_sym)   # ascending eigenvalues
        Q = None
        ritz_vals = None
    ritz_vals = comm.bcast(ritz_vals, root=0)
    Q = comm.bcast(Q, root=0)
    # --- (3) Update subspace: X_new = Y * Q ---
    X_new_vecs = []
    for i in range(q):
        new_vec = K.createVecRight()
        new_vec.set(0.0)
        for j in range(q):
            coeff = Q[j, i]
            if abs(coeff) > 1e-14:
                new_vec.axpy(coeff, Y_vecs[j])
        X_new_vecs.append(new_vec)
    m_orthonormalize(X_new_vecs, M)            # numerical stabilization
    # --- (4) Convergence test ---
    current_ritz = ritz_vals[:p]
    if it > 0:
        err = np.linalg.norm(current_ritz - old_ritz) / (np.linalg.norm(current_ritz) + 1e-12)
        if rank == 0:
            print(f"Iter {it+1:2d}: error = {err:.2e}")
        if err < tol:
            if rank ==`Preformatted text` 0:
                print("Subspace iteration converged!")
            break
    old_ritz = current_ritz.copy()
    # Replace old subspace with new one
    for vec in X_vecs:
        vec.destroy()
    X_vecs = X_new_vecs
# 8. Output eigenvalues and frequencies
if rank == 0:
    print("\nFinal eigenvalues (λ):")
    for i, val in enumerate(current_ritz):
        print(f"Mode {i+1}: λ = {val:.8e}")
    print("\nFrequencies (ω = sqrt(λ)):")
    for i, w in enumerate(np.sqrt(current_ritz)):
        print(f"Mode {i+1}: ω = {w:.6f}")
# Cleanup
ksp.destroy()
K.destroy()
M.destroy()
for vec in X_vecs:
    vec.destroy()
type or paste code here
Hi Peter,
Welcome! dolfinx zeroes the rows and columns of the mass and stiffness matrices corresponding to the Dirichlet dofs and fills the diagonal entries with the optional diagonal keyword argument of assemble_matrix. Hence you get N modes with frequency \sqrt{\frac{K_{diag}}{M_{diag}}}. You can set the diagonal values to appropriately large/small values so that these modes are outside your range of interest:
You can remove those rows and columns as shown in: Structural Modal Analysis - #2 by dokken
that removes the Dirichlet Dofs from the system.
Thank you very much, this is very helpful
