I want to implement code that uses the subspace iteration method to obtain modes and then perform topology optimization using MMA. But it is too slow and too complicated, and I hope someone can give me some advice.
Here is the code
import shutil
import os
cache_dir = os.path.expanduser(“~/.cache/fenics”)
if os.path.exists(cache_dir):
shutil.rmtree(cache_dir)
print(“Cleared FEniCS cache”)
from dolfinx import mesh, fem
import dolfinx.fem.petsc
from scipy.linalg import eigh
import time
comm = MPI.COMM_WORLD
rank = comm.Get_rank()
lx, ly = 2.0, 1.0
nx, ny = 80, 40
domain = mesh.create_rectangle(comm, [[0.0, 0.0], [lx, ly]], [nx, ny],
cell_type=mesh.CellType.quadrilateral)
V = fem.functionspace(domain, (“Lagrange”, 1))
u = ufl.TrialFunction(V)
a_K0 = ufl.inner(ufl.grad(u), ufl.grad(v)) * ufl.dx # unit stiffness matrix
a_M0 = ufl.inner(u, v) * ufl.dx # unit mass matrix
Boundary condition (fixed left end)
def left_boundary(x):
return np.isclose(x[0], 0.0)
left_facets = mesh.locate_entities_boundary(domain, fdim, left_boundary)
dofs_left = fem.locate_dofs_topological(V, fdim, left_facets)
bc = fem.dirichletbc(PETSc.ScalarType(0.0), dofs_left, V)
Penalty parameter for boundary DOFs
BIG_PENALTY = 1e12
2. Design variable space (DG-0, constant per cell)
V_design = fem.functionspace(domain, (“DG”, 0))
rho = fem.Function(V_design, name=“Density”)
vol_frac = 0.3
rho.interpolate(lambda x: np.full(x[0].shape, vol_frac))
SIMP interpolation parameters
p_simp = 3.0 # stiffness interpolation exponent
q_simp = 3.0 # mass interpolation exponent (use >p_simp to suppress localized modes)
E0 = 1.0
Emin = 1e-9
def E_simp(rho_e):
return Emin + rho_e**p_simp * (E0 - Emin)
def M_simp(rho_e):
return rho_e**q_simp # density interpolation factor
3. Assemble stiffness matrix K and mass matrix M (with penalty BC)
def assemble_matrices(rho):
# Interpolated Young’s modulus (cell-wise, evaluated at quadrature points)
E_eff = Emin + rhop_simp * (E0 - Emin)
# Reconstruct variational forms
a_K_rho = E_eff * ufl.inner(ufl.grad(u), ufl.grad(v)) * ufl.dx
a_M_rho = rhoq_simp * ufl.inner(u, v) * ufl.dx
K_mat = dolfinx.fem.petsc.assemble_matrix(fem.form(a_K_rho), bcs=[])
K_mat.assemble()
M_mat = dolfinx.fem.petsc.assemble_matrix(fem.form(a_M_rho), bcs=[])
M_mat.assemble()
# Apply penalty BC (push boundary DOF eigenvalues to high frequency)
K_mat.zeroRowsColumns(dofs_left, diag=BIG_PENALTY)
M_mat.zeroRowsColumns(dofs_left, diag=1.0)
K_mat.assemble()
M_mat.assemble()
return K_mat, M_mat
4. Subspace iteration solver (fully encapsulated from user code)
def subspace_iteration(K_mat, M_mat, p, q, max_iter=50, tol=1e-8):
mpi_comm = MPI.COMM_WORLD
rank = mpi_comm.Get_rank()
# ----- 4.1 Create KSP solver (for K y = M x) -----
# Create KSP solver using PETSc communicator
petsc_comm = K_mat.comm
ksp = PETSc.KSP().create(petsc_comm)
ksp.setOperators(K_mat)
ksp.setType(PETSc.KSP.Type.PREONLY)
pc = ksp.getPC()
pc.setType(PETSc.PC.Type.LU)
ksp.setFromOptions()
# ----- 4.2 Initialize subspace basis (random vectors, M-orthonormalized) -----
X_vecs = []
for i in range(q):
vec = K_mat.createVecRight()
while True:
rctx = PETSc.Random().create(comm=comm)
rctx.setType(PETSc.Random.Type.RAND)
rctx.setSeed(i + rank * 100 + 12345)
vec.setRandom(rctx)
norm2 = vec.dot(M_mat * vec)
if norm2 > 1e-12:
break
X_vecs.append(vec)
# M-orthonormalization functions
def m_normalize(vec, M):
norm2 = vec.dot(M * vec)
if norm2 < 1e-12:
vec.axpy(1e-8, vec)
norm = np.sqrt(norm2)
vec.scale(1.0 / norm)
return norm
def m_orthonormalize(vecs, M):
qlen = len(vecs)
for i in range(qlen):
for j in range(i):
prod = vecs[j].dot(M * vecs[i])
vecs[i].axpy(-prod, vecs[j])
m_normalize(vecs[i], M)
m_orthonormalize(X_vecs, M_mat)
old_ritz = np.full(p, np.inf)
for it in range(max_iter):
# Simultaneous inverse iteration: solve K Y = M X
Y_vecs = []
for i in range(q):
y = K_mat.createVecRight()
Mx = M_mat * X_vecs[i]
ksp.solve(Mx, y)
Y_vecs.append(y)
# Rayleigh-Ritz projection
K_r_local = np.zeros((q, q))
M_r_local = np.zeros((q, q))
KY_vecs = [K_mat * y for y in Y_vecs]
for i in range(q):
for j in range(q):
K_r_local[i, j] = Y_vecs[i].dot(KY_vecs[j])
M_r_local[i, j] = Y_vecs[i].dot(M_mat * Y_vecs[j])
# MPI global sum
K_r_global = np.zeros_like(K_r_local)
M_r_global = np.zeros_like(M_r_local)
mpi_comm.Allreduce(K_r_local, K_r_global, op=MPI.SUM)
mpi_comm.Allreduce(M_r_local, M_r_global, op=MPI.SUM)
if rank == 0:
K_r_sym = 0.5 * (K_r_global + K_r_global.T)
M_r_sym = 0.5 * (M_r_global + M_r_global.T)
eps = 1e-10
success = False
for _ in range(10):
try:
M_reg = M_r_sym + eps * np.eye(q)
ritz_vals, Q = eigh(K_r_sym, M_reg)
# Check positivity
if np.min(ritz_vals) > -1e-12:
success = True
break
except np.linalg.LinAlgError:
eps *= 10
if not success:
print("Warning: generalized eigenproblem ill-conditioned, fallback to standard eig.")
ritz_vals, Q = eigh(K_r_sym)
# M-orthonormalize eigenvectors
for i in range(q):
norm_m = np.sqrt(Q[:, i] @ M_r_sym @ Q[:, i])
if norm_m > 1e-12:
Q[:, i] /= norm_m
ritz_vals = None
Q = None
# Broadcast (must be outside if-else)
ritz_vals = mpi_comm.bcast(ritz_vals, root=0)
Q = mpi_comm.bcast(Q, root=0)
# Update subspace basis
X_new_vecs = []
for i in range(q):
new_vec = K_mat.createVecRight()
new_vec.set(0.0)
for j in range(q):
coeff = Q[j, i]
if abs(coeff) > 1e-14:
new_vec.axpy(coeff, Y_vecs[j])
X_new_vecs.append(new_vec)
m_orthonormalize(X_new_vecs, M_mat)
# Convergence check
current_ritz = ritz_vals[:p]
if it > 0:
err = np.linalg.norm(current_ritz - old_ritz) / (np.linalg.norm(current_ritz) + 1e-12)
if err < tol:
if rank == 0:
print(f" Subspace iteration converged at step {it+1}")
break
old_ritz = current_ritz.copy()
# Clean old vectors
for vec in X_vecs:
vec.destroy()
X_vecs = X_new_vecs
# ----- 4.4 Extract first p eigenvectors -----
eigenvalues = current_ritz[:p]
eigenvectors = X_vecs[:p]
# Clean KSP and remaining vectors
ksp.destroy()
for vec in X_vecs[p:]:
vec.destroy()
return eigenvalues, eigenvectors
def compute_sensitivity(rho, phi, eigenvalue):
phi_func = fem.Function(V)
phi_func.x.array[:] = phi.array
# Create DG-0 space (constant per cell)
V0 = fem.functionspace(domain, ("DG", 0))
v0 = ufl.TestFunction(V0)
# Element stiffness energy ∫_e ∇φ·∇φ dx, multiplied by v0 to obtain cell-wise integrals
energy_K0_form = ufl.inner(ufl.grad(phi_func), ufl.grad(phi_func)) * v0 * ufl.dx
cell_energy_K0_vec = fem.assemble_vector(fem.form(energy_K0_form))
cell_energy_K0 = cell_energy_K0_vec.array.copy()
# Element mass energy ∫_e φ·φ dx
energy_M0_form = ufl.inner(phi_func, phi_func) * v0 * ufl.dx
cell_energy_M0_vec = fem.assemble_vector(fem.form(energy_M0_form))
cell_energy_M0 = cell_energy_M0_vec.array.copy()
rho_e = rho.x.array
dK_drho = p_simp * (rho_e**(p_simp-1)) * (E0 - Emin) * cell_energy_K0
dM_drho = q_simp * (rho_e**(q_simp-1)) * cell_energy_M0
sens = dK_drho - eigenvalue * dM_drho
return sens
def sensitivity_filter(sens, rho, rmin):
mesh = domain
num_cells = len(sens)
# Obtain cell centers
geometry = mesh.geometry
cells = mesh.topology.connectivity(mesh.topology.dim, 0)
cell_centers = np.zeros((num_cells, 2))
for i in range(num_cells):
verts = cells.links(i)
center = np.mean(geometry.x[verts], axis=0) # shape (3,)
cell_centers[i] = center[:2]
filtered = np.zeros_like(sens)
w_sum = 0.0
val = 0.0
xi = cell_centers[i]
for j in range(num_cells):
xj = cell_centers[j]
dist = np.linalg.norm(xi - xj)
if dist < rmin:
w = rmin - dist
w_sum += w
val += w * sens[j]
filtered[i] = val / w_sum if w_sum > 0 else sens[i]
return filtered
Hand-written MMA solver (single constraint, dual method)
class MMA_SingleConstraint:
def init(self, x0, move=0.2):
self.n = len(x0)
self.x = x0.copy()
self.move = move
# Initial asymptotes
self.L = np.maximum(x0 - move, 0.0)
self.U = np.minimum(x0 + move, 1.0)
self.alpha = np.zeros(self.n)
self.beta = np.ones(self.n)
self.x_prev = x0.copy()
self.x_prev2 = x0.copy()
def update_asymptotes(self, x_curr, iter_num):
for j in range(self.n):
if iter_num <= 2:
Lj = x_curr[j] - self.move
Uj = x_curr[j] + self.move
s = (x_curr[j] - self.x_prev[j]) * (self.x_prev[j] - self.x_prev2[j])
if s < 0:
Lj = x_curr[j] - 0.7 * (self.U[j] - self.L[j])
Uj = x_curr[j] + 0.7 * (self.U[j] - self.L[j])
Lj = x_curr[j] - 1.2 * (self.U[j] - self.L[j])
Uj = x_curr[j] + 1.2 * (self.U[j] - self.L[j])
Lj = max(Lj, 0.0)
Uj = min(Uj, 1.0)
if Uj - Lj < 1e-6:
Lj = x_curr[j] - 0.5
Uj = x_curr[j] + 0.5
Lj = max(Lj, 0.0)
Uj = min(Uj, 1.0)
self.L[j] = Lj
self.U[j] = Uj
self.x_prev2 = self.x_prev.copy()
self.x_prev = x_curr.copy()
def compute_pq(self, grad_f0, grad_f1):
p0 = np.zeros(self.n)
q0 = np.zeros(self.n)
p1 = np.zeros(self.n)
q1 = np.zeros(self.n)
xj = self.x[j]
Lj = self.L[j]
Uj = self.U[j]
df0 = grad_f0[j]
p0[j] = max(0.0, (Uj - xj)**2 * df0) + 1e-12
q0[j] = max(0.0, -(xj - Lj)**2 * df0) + 1e-12
df1 = grad_f1[j]
p1[j] = max(0.0, (Uj - xj)**2 * df1) + 1e-12
q1[j] = max(0.0, -(xj - Lj)**2 * df1) + 1e-12
return p0, q0, p1, q1
def solve_subproblem(self, p0, q0, p1, q1):
# Dual variable μ Newton iteration
mu = 0.0
for _ in range(20):
x_new, f1_approx = self._compute_x_and_f1(mu, p0, q0, p1, q1)
if f1_approx <= 0:
break
eps = 1e-6
_, f1_plus = self._compute_x_and_f1(mu + eps, p0, q0, p1, q1)
df1 = (f1_plus - f1_approx) / eps
if df1 < 1e-12:
break
mu = mu - f1_approx / df1
mu = max(mu, 0.0)
x_new, _ = self._compute_x_and_f1(mu, p0, q0, p1, q1)
return x_new
def _compute_x_and_f1(self, mu, p0, q0, p1, q1):
x_new = np.zeros(self.n)
f1_val = 0.0
Pj = p0[j] + mu * p1[j]
Qj = q0[j] + mu * q1[j]
Lj = self.L[j]
Uj = self.U[j]
sqrtP = np.sqrt(Pj)
sqrtQ = np.sqrt(Qj)
x_star = (sqrtP * Lj + sqrtQ * Uj) / (sqrtP + sqrtQ)
xj = np.clip(x_star, self.alpha[j], self.beta[j])
x_new[j] = xj
f1_val += p1[j] / (Uj - xj) + q1[j] / (xj - Lj)
return x_new, f1_val
7. Main optimization loop
max_iters = 80
tol_change = 1e-4
filter_radius = 0.04
move_limit = 0.2
Volume constraint
total_volume = fem.assemble_scalar(fem.form(1.0 * ufl.Measure(“dx”, domain=domain)))
Vmax = vol_frac * total_volume
Initialize design variables
rho_vec = np.full(domain.topology.index_map(domain.topology.dim).size_local, vol_frac)
rho.x.array[:] = rho_vec
MMA object
mma = MMA_SingleConstraint(rho_vec, move=move_limit)
Record history
history_lambda =
for iter_opt in range(max_iters):
# ----- 7.1 Assemble K, M for current density -----
K_mat, M_mat = assemble_matrices(rho)
# ----- 7.2 Subspace iteration for fundamental frequency and mode shape -----
# Note: only p=1 eigenvalue needed, subspace dimension q=6~8
evals, evecs = subspace_iteration(K_mat, M_mat, p=1, q=6, max_iter=20, tol=1e-8)
lambda1 = evals[0]
phi1 = evecs[0] # PETSc Vec
obj = -lambda1 # MMA minimizes -λ₁
# ----- 7.3 Volume constraint value -----
vol_curr = fem.assemble_scalar(fem.form(rho * ufl.dx))
g_val = vol_curr / Vmax - 1.0
# ----- 7.4 Sensitivity analysis -----
sens = compute_sensitivity(rho, phi1, lambda1)
# Volume constraint gradient (linear)
grad_g = np.full(len(rho_vec), 1.0 / Vmax)
# Sensitivity filtering (optional, stabilizes optimization)
sens = sensitivity_filter(sens, rho, filter_radius)
# Objective gradient (since f0 = -λ, grad_f0 = -sens)
grad_f0 = -sens
if rank == 0:
print(f"Iter {iter_opt+1:3d}: λ₁ = {lambda1:.6e}, obj = {obj:.6e}, Vol = {vol_curr/Vmax:.4f}")
# ----- 7.5 Update MMA asymptotes -----
mma.update_asymptotes(rho_vec, iter_opt+1)
# ----- 7.6 Compute MMA subproblem coefficients -----
p0, q0, p1, q1 = mma.compute_pq(grad_f0, grad_g)
# ----- 7.7 Solve subproblem to obtain new design variables -----
rho_new = mma.solve_subproblem(p0, q0, p1, q1)
# ----- 7.8 Convergence check -----
change = np.max(np.abs(rho_new - rho_vec))
if rank == 0:
print(f" Max change = {change:.3e}")
if change < tol_change and iter_opt > 10:
if rank == 0:
print(f"Optimization converged at iteration {iter_opt+1}")
break
# Update design variables
rho_vec = rho_new
history_lambda.append(lambda1)
# Clean matrices and vectors
K_mat.destroy()
M_mat.destroy()
phi1.destroy()
8. Save final results
if rank == 0:
print(“\n========== Optimization completed ==========”)
# Finally compute the fundamental frequency one more time
K_final, M_final = assemble_matrices(rho)
evals_final, _ = subspace_iteration(K_final, M_final, p=1, q=6, max_iter=50, tol=1e-8)
print(f"Final fundamental frequency (circular ω) = {np.sqrt(evals_final[0]):.6f} rad/s")
# Save density field
with dolfinx.io.XDMFFile(comm, “topopt_frequency_max.xdmf”, “w”) as f:
f.write_mesh(domain)
f.write_function(rho)
print(“Optimized density field saved to topopt_frequency_max.xdmf”)
K_final.destroy()
M_final.destroy()
