V 0.5.0 codes aren't working in V 0.5.1
The code is similar to steady heat conduction with multiple boundary conditions from the tutorial. I’m importing a 3D mesh of a bracket. The rest of the code is pretty simple. It worked fine all these days in V 0.5.0 but doesn’t seem to work in V 0.5.1. I’m running FEniCSx on conda.
import time
start = time.time()
from dolfinx import fem
from ufl import dx,grad,dot,lhs,rhs,inner
from dolfinx.io.gmshio import read_from_msh
# Reading Mesh
mesh, cell_tags, facet_tags = read_from_msh("bracket3D.msh", MPI.COMM_WORLD, 0, gdim=3)
fdim = mesh.topology.dim - 1
# Thermal Conductivity
kappa = fem.Constant(mesh, PETSc.ScalarType(100))
# Convection Heat Transfer Coefficient
r = fem.Constant(mesh, PETSc.ScalarType(10))
s = 24          # Ambient Temperature
g = -200        # Heat Flux
f = 10          # Heat Generation
# Continuous Lagrange Function Space for Temperature
V = fem.FunctionSpace(mesh, ("CG", 1))
u = ufl.TrialFunction(V)
F = kappa * inner(grad(u), grad(v)) * dx - inner(f, v) * dx
ds = ufl.Measure("ds", domain=mesh, subdomain_data= facet_tags)
class CreateBoundaryCondition():
    def __init__(self, type, marker, values):
        self._type = type
        if type == "DirichletBC":
            facets = facet_tags.find(marker)
            dofs = fem.locate_dofs_topological(V, fdim, facets)
            self._bc = fem.dirichletbc(PETSc.ScalarType(values), dofs , V)
        elif type == "NeumannBC":
                self._bc = inner(values, v) * ds(marker)
        elif type == "RobinBC":
            self._bc = values[0] * inner(u-values[1], v)* ds(marker)
            raise TypeError("Unknown boundary condition: {0:s}".format(type))
    @property
    def bc(self):
        return self._bc
    @property
    def type(self):
        return self._type
# Define the Dirichlet condition
boundary_conditions = [CreateBoundaryCondition("DirichletBC", 52 , 100),
                       CreateBoundaryCondition("NeumannBC", 53, g),
                       CreateBoundaryCondition("DirichletBC", 54, 60),
                       CreateBoundaryCondition("RobinBC", 55, (r , s))]
bcs = []
for condition in boundary_conditions:
    if condition.type == "DirichletBC":
        bcs.append(condition.bc)
        F += condition.bc
# Solve linear variational problem
a = lhs(F)
L = rhs(F)
problem = fem.petsc.LinearProblem(a, L, bcs=bcs, petsc_options={"ksp_type": "cg", "ksp_rtol":1e-6, "ksp_atol":1e-10, "ksp_max_it": 1000})
uh = fem.Function(V)
uh = problem.solve()
end = time.time()
print("The time of execution of the program is :",(end-start), "s")
num_dofs = V.dofmap.index_map_bs * V.dofmap.index_map.size_global
print("DOFs :",num_dofs)
# Visualize solution
print("Plotting Temperature Contour using PyVista")
import pyvista
from dolfinx import plot
pyvista.set_jupyter_backend("ipygany")
pyvista_cells, cell_types, geometry = plot.create_vtk_mesh(V)
grid = pyvista.UnstructuredGrid(pyvista_cells, cell_types, geometry)
grid.point_data["Temperature"] = uh.x.array
grid.set_active_scalars("Temperature")
plotter = pyvista.Plotter()
#plotter.add_mesh(grid.copy(), style="points", point_size=10, render_points_as_spheres=True, line_width=0)
plotter.view_zy()
plotter.show()
This throws an error:
(fenicsx-0.5.1) varunkumar@Varuns-MacBook-Pro FEniCSx Codes % /opt/anaconda3/envs/fenicsx-0.5.1/bin/python "/Users/varunkumar/Documents/FEniCSx Codes/SteadyThermal.py"
Info    : Reading 'bracket3D.msh'...
Info    : 105 entities
Info    : 15603 nodes
Info    : 86592 elements
Info    : Done reading 'bracket3D.msh'
xcrun: error: invalid active developer path (/Library/Developer/CommandLineTools), missing xcrun at: /Library/Developer/CommandLineTools/usr/bin/xcrun
  File "/opt/anaconda3/envs/fenicsx-0.5.1/lib/python3.9/site-packages/setuptools/_distutils/unixccompiler.py", line 186, in _compile
    self.spawn(compiler_so + cc_args + [src, '-o', obj] + extra_postargs)
  File "/opt/anaconda3/envs/fenicsx-0.5.1/lib/python3.9/site-packages/setuptools/_distutils/ccompiler.py", line 1007, in spawn
    spawn(cmd, dry_run=self.dry_run, **kwargs)
  File "/opt/anaconda3/envs/fenicsx-0.5.1/lib/python3.9/site-packages/setuptools/_distutils/spawn.py", line 70, in spawn
    raise DistutilsExecError(
distutils.errors.DistutilsExecError: command '/usr/bin/clang' failed with exit code 1
  File "/opt/anaconda3/envs/fenicsx-0.5.1/lib/python3.9/site-packages/cffi/ffiplatform.py", line 51, in _build
    dist.run_command('build_ext')
  File "/opt/anaconda3/envs/fenicsx-0.5.1/lib/python3.9/site-packages/setuptools/dist.py", line 1217, in run_command
    super().run_command(command)
  File "/opt/anaconda3/envs/fenicsx-0.5.1/lib/python3.9/site-packages/setuptools/_distutils/dist.py", line 987, in run_command
    cmd_obj.run()
  File "/opt/anaconda3/envs/fenicsx-0.5.1/lib/python3.9/site-packages/setuptools/command/build_ext.py", line 84, in run
    _build_ext.run(self)
  File "/opt/anaconda3/envs/fenicsx-0.5.1/lib/python3.9/site-packages/setuptools/_distutils/command/build_ext.py", line 346, in run
    self.build_extensions()
  File "/opt/anaconda3/envs/fenicsx-0.5.1/lib/python3.9/site-packages/setuptools/_distutils/command/build_ext.py", line 466, in build_extensions
    self._build_extensions_serial()
  File "/opt/anaconda3/envs/fenicsx-0.5.1/lib/python3.9/site-packages/setuptools/_distutils/command/build_ext.py", line 492, in _build_extensions_serial
    self.build_extension(ext)
  File "/opt/anaconda3/envs/fenicsx-0.5.1/lib/python3.9/site-packages/setuptools/command/build_ext.py", line 246, in build_extension
    _build_ext.build_extension(self, ext)
  File "/opt/anaconda3/envs/fenicsx-0.5.1/lib/python3.9/site-packages/setuptools/_distutils/command/build_ext.py", line 547, in build_extension
    objects = self.compiler.compile(
  File "/opt/anaconda3/envs/fenicsx-0.5.1/lib/python3.9/site-packages/setuptools/_distutils/ccompiler.py", line 599, in compile
    self._compile(obj, src, ext, cc_args, extra_postargs, pp_opts)
  File "/opt/anaconda3/envs/fenicsx-0.5.1/lib/python3.9/site-packages/setuptools/_distutils/unixccompiler.py", line 188, in _compile
    raise CompileError(msg)
distutils.errors.CompileError: command '/usr/bin/clang' failed with exit code 1
  File "/Users/varunkumar/Documents/FEniCSx Codes/SteadyThermal.py", line 27, in <module>
  File "/opt/anaconda3/envs/fenicsx-0.5.1/lib/python3.9/site-packages/dolfinx/fem/function.py", line 457, in __init__
    (self._ufcx_element, self._ufcx_dofmap), module, code = jit.ffcx_jit(
  File "/opt/anaconda3/envs/fenicsx-0.5.1/lib/python3.9/site-packages/dolfinx/jit.py", line 56, in mpi_jit
  File "/opt/anaconda3/envs/fenicsx-0.5.1/lib/python3.9/site-packages/dolfinx/jit.py", line 206, in ffcx_jit
    r = ffcx.codegeneration.jit.compile_elements([ufl_object], parameters=p_ffcx, **p_jit)
  File "/opt/anaconda3/envs/fenicsx-0.5.1/lib/python3.9/site-packages/ffcx/codegeneration/jit.py", line 126, in compile_elements
    impl = _compile_objects(decl, elements, names, module_name, p, cache_dir,
  File "/opt/anaconda3/envs/fenicsx-0.5.1/lib/python3.9/site-packages/ffcx/codegeneration/jit.py", line 252, in _compile_objects
    ffibuilder.compile(tmpdir=cache_dir, verbose=True, debug=cffi_debug)
  File "/opt/anaconda3/envs/fenicsx-0.5.1/lib/python3.9/site-packages/cffi/api.py", line 725, in compile
    return recompile(self, module_name, source, tmpdir=tmpdir,
  File "/opt/anaconda3/envs/fenicsx-0.5.1/lib/python3.9/site-packages/cffi/recompiler.py", line 1564, in recompile
    outputfilename = ffiplatform.compile('.', ext,
  File "/opt/anaconda3/envs/fenicsx-0.5.1/lib/python3.9/site-packages/cffi/ffiplatform.py", line 22, in compile
    outputfilename = _build(tmpdir, ext, compiler_verbose, debug)
  File "/opt/anaconda3/envs/fenicsx-0.5.1/lib/python3.9/site-packages/cffi/ffiplatform.py", line 58, in _build
    raise VerificationError('%s: %s' % (e.__class__.__name__, e))
cffi.VerificationError: CompileError: command '/usr/bin/clang' failed with exit code 1
Sometimes it threw an error during the assembly of the problem. Please tell me what should be done to fix it. Also, I made the mistake of deleting V 0.5.0. Please let me know if there is a way to install V 0.5.0 in conda.
This error seems Mac specific. @jackhale , @chris do you have any suggestions?
Could it be due to the Ventura OS update I installed right before this started? Also, I deleted conda and reinstalled it along V 0.5.2 today, which also gives the same error.
Could be, see for instance OS Ventura update - Source tree xcrun error
and
[fix] macOS Ventura - Python3 xcrun: error: invalid active developer path missing xcrun at CommandLineTools | Code2care
Thank you so much. The tutorial codes are working now. But from dolfinx.io.gmshio import read_from_msh doesn’t seem to work in V 0.5.2.
print('Reading mesh')
mesh, cell_tags, facet_tags = read_from_msh("fins.msh", MPI.COMM_WORLD, 0, gdim=3)
print('Plotting mesh using PyVista')
import pyvista
topology, cell_types, geometry = plot.create_vtk_mesh(mesh, 3)
grid = pyvista.UnstructuredGrid(topology, cell_types, geometry)
plotter.view_xy()
plotter.show()
This code gives an error :
  File "/Users/varunkumar/Documents/FEniCSx Codes/SteadyThermal.py", line 7, in <module>
ImportError: cannot import name 'read_from_msh' from 'dolfinx.io.gmshio' (/Users/varunkumar/opt/anaconda3/envs/fenicsx/lib/python3.10/site-packages/dolfinx/io/gmshio.py)
Do you have Gmsh installed? read_from_msh uses the Gmsh Python API to read msh files
